[Mapserver-users] compiling regex on windows
bean at vt.edu
agillesp at vt.edu
Tue Nov 4 12:17:26 EST 2003
i tried "vsvars32.bat" for vs.net once. and i tried "vcvars32.bat" for vc 6.0
once. neither worked. is this what you mean by "Setvars?"
-abe
>===== Original Message From "Swaminathan, Gayathri" <gayathri at ou.edu> =====
>Did you "Setvars" for your VC++ environment?
>-----Original Message-----
>From: bean at vt.edu [mailto:agillesp at vt.edu]
>Sent: Tuesday, November 04, 2003 11:05 AM
>To: Swaminathan, Gayathri; Mapserver-users at lists.gis.umn.edu
>Subject: RE: [Mapserver-users] compiling regex on windows
>now i'm getting:
> for d in doc test; do (cd $d; nmake CPPFLAGS='-DHAVE_STRING_H
>-DREGEX_M
>ALLOC' CFLAGS='-Ox -G6' CC='cl' DEFS='' LDFLAGS='' LOADLIBES='' default);
>done
>d was unexpected at this time.
>NMAKE : fatal error U1077: 'for' : return code '0x1'
>Stop.
>-abe
>>===== Hello,
>>Here goes as an attachment my complete regex dir in the attached zip.
>>Unzip it,
>>Setvars in command...for VC++ compile
>>And then do a 'nmake /f makefile.vc'
>>Good luck! That should work
>>Gayathri
>>Sent: Tuesday, November 04, 2003 10:00 AM
>>To: Mapserver-users; Stephen Clark
>>i'm now getting this:
>>Makefile.vc(50) : fatal error U1086: inference rule cannot have
>>dependents Stop.
>>-abe
