[Mapserver-users] How to empty the TMP directory
Gregory S. Williamson
gsw at globexplorer.com
Tue Nov 4 16:03:03 EST 2003
Guillaume ,
Mapserver seems to be done with the process once it puts the output files in the directory; you'll have to write a utility program to periodically delete old files. There used to be a utility on the MMS site for doing this under windows; I think a search of the list's archive would turn up the code. Unders *nix you'll want a cron job that runs a script that deletes all files that are older than some amount of time. I can provide a snippet that works under Solarix but don't know about the linux variants.
HTH,
Greg Williamson
DBA
GlobeXplorer LLC
-----Original Message-----
From: Guillaume MOCCAND [mailto:moccand at ensg.ign.fr]
Sent: Tue 11/4/2003 10:50 AM
To: mapserver-users at lists.gis.umn.edu
Cc:
Subject: [Mapserver-users] How to empty the TMP directory
hi,
i wonder how i can empty the TMP directory that contains all the files created
by Mapserver.
do i need to configure Mapserver or do i need to proceed without using
Mapserver.
Thanks
Guillaume MOCCAND
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
