AW: [Mapserver-users] scaling labels
Till Adams
adams at terrestris.de
Wed Nov 5 02:38:19 EST 2003
Dear Mr. Spalting,
I put in some code from a point layer, we're labeling with a symbol and
use both, maxscale and symbolscale and it works:
LAYER
NAME 'Foto'
DATA 'pathto_and_name_of_data'
STATUS ON
TYPE ANNOTATION
LABELMAXSCALE 1000
SYMBOLSCALE 500
METADATA
WMS_SRS 'epsg:31493'
WMS_TITLE 'Foto'
END
PROJECTION
'init=epsg:31493'
END
CLASSITEM 'id'
LABELITEM 'winkel'
LABELANGLEITEM 'Rotation'
CLASS
NAME 'Photo'
EXPRESSION /^foto/
LABEL
TYPE TRUETYPE
FONT "symbol"
SIZE 15
COLOR 0 0 0
END
END # CLASS
END # END LAYERFILE
If you comment this:
> # TYPE TRUETYPE
> # FONT "arial"
> SIZE MEDIUM
There is nothing to be displayed. At least use
TYPE BITMAP
SIZE MEDIUM
Hope that helps,
Till
Spalting, Hermann (Kreis Lippe) schrieb:
> Hi,
> the use of SYMBOLSCALE,MINSIZE and MAXSIZE has no effect. I tryed to use
> truetype Fonds but had problems with it. Here is a part of the map-file.
> Maybe i did not understand the real meaning of SYMBOLSCALE,MINSIZE and
> MAXSIZE.
> LAYER
> NAME 'Beschriftung'
> GROUP 'Beschriftung'
> DATA 'D:/Inetpub/www100UMNMapServer/daten/Kalletal_1/shape/O_m_schrift'
> STATUS default
> TYPE ANNOTATION
> CLASSITEM 'Id'
> LABELITEM 'Z9pt'
> LABELCACHE OFF
> # LABELMAXSCALE 30000
> SYMBOLSCALE 5000
> CLASS # Beschr class
> COLOR -1 -1 -1
> LABEL
> POSITION UC
> OFFSET 0 3
> COLOR 0 0 0
> # TYPE TRUETYPE
> # FONT "arial"
> SIZE MEDIUM
> MINSIZE 5
> MAXSIZE 255
> END # end of label
> END # end of class object
> END # END OF LAYERFILE
> -----Ursprüngliche Nachricht-----
> Von: Michael Schulz [mailto:mschulz at webgis.de]
> Gesendet: Dienstag, 4. November 2003 10:25
> An: Spalting, Hermann (Kreis Lippe)
> Cc: 'mapserver-users at lists.gis.umn.edu'
> Betreff: Re: [Mapserver-users] scaling labels
> Hello,
> scaling of symbols and labels is done using SYMBOLSCALE on the layerobj
> together with MINSIZE and MAXSIZE on styleobj/symbolobj and labelobj, to
> limit dynamic sizing between these values.
> Not 100% sure, but i don't think Truetype is required.
> More information:
> http://mapserver.gis.umn.edu/doc40/mapfile-reference.html#layer
> Cheers und Grüße,
> Michael
>>I want my labels to be scaled like in a photocopy. Becomming bigger and
>>bigger when zooming in.
>>How does that work? Are truetypes required?
>>Hermann Spalting
>>Kreis Lippe
>>FG 4.4
>>Felix-Fechenbach-Straße 5
>>32756 Detmold
>>email: <<mailto:h.spalting at lippe.de>>
>>Tel: 05231/62-625 (oder -7827)
***** Besuchen Sie uns auf der acqua alta *****
***** vom 24.-27. November in München *****
Dipl. Geogr. Till Adams
terrestris, Paulsen&Adams GbR
Siemensstr. 8 * 53121 Bonn
Tel.: 0228 962 899 52 * Fax.: 0228 962 899 57
info at terrestris.de * www.terrestris.de
