AW: [Mapserver-users] scaling labels
Michael Schulz
mschulz at webgis.de
Wed Nov 5 02:59:10 EST 2003
Good Morning,
What were the problems with truetype? Although i couldn't find anything
in the docs that said scaling of text labels is only possible with
truetype fonts, i couldn't scale bitmap fonts either.
You should try it with truetype fonts. They work definitely.
Cheers, Michael
Spalting, Hermann (Kreis Lippe) schrieb:
> Hi,
> the use of SYMBOLSCALE,MINSIZE and MAXSIZE has no effect. I tryed to use
> truetype Fonds but had problems with it. Here is a part of the map-file.
> Maybe i did not understand the real meaning of SYMBOLSCALE,MINSIZE and
> MAXSIZE.
> LAYER
> NAME 'Beschriftung'
> GROUP 'Beschriftung'
> DATA 'D:/Inetpub/www100UMNMapServer/daten/Kalletal_1/shape/O_m_schrift'
> STATUS default
> TYPE ANNOTATION
> CLASSITEM 'Id'
> LABELITEM 'Z9pt'
> LABELCACHE OFF
> # LABELMAXSCALE 30000
> SYMBOLSCALE 5000
> CLASS # Beschr class
> COLOR -1 -1 -1
> LABEL
> POSITION UC
> OFFSET 0 3
> COLOR 0 0 0
> # TYPE TRUETYPE
> # FONT "arial"
> SIZE MEDIUM
> MINSIZE 5
> MAXSIZE 255
> END # end of label
> END # end of class object
> END # END OF LAYERFILE
> -----Ursprüngliche Nachricht-----
> Von: Michael Schulz [mailto:mschulz at webgis.de]
> Gesendet: Dienstag, 4. November 2003 10:25
> An: Spalting, Hermann (Kreis Lippe)
> Cc: 'mapserver-users at lists.gis.umn.edu'
> Betreff: Re: [Mapserver-users] scaling labels
> Hello,
> scaling of symbols and labels is done using SYMBOLSCALE on the layerobj
> together with MINSIZE and MAXSIZE on styleobj/symbolobj and labelobj, to
> limit dynamic sizing between these values.
> Not 100% sure, but i don't think Truetype is required.
> More information:
> http://mapserver.gis.umn.edu/doc40/mapfile-reference.html#layer
> Cheers und Grüße,
> Michael
>>I want my labels to be scaled like in a photocopy. Becomming bigger and
>>bigger when zooming in.
>>How does that work? Are truetypes required?
>>Hermann Spalting
>>Kreis Lippe
>>FG 4.4
>>Felix-Fechenbach-Straße 5
>>32756 Detmold
>>email: <<mailto:h.spalting at lippe.de>>
>>Tel: 05231/62-625 (oder -7827)
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
