[Mapserver-users] getFeatureInfo on dynamic layer -emptyexception
Frieso ter Haseborg
ter-haseborg at sf-datentechnik.de
Wed Nov 5 06:52:01 EST 2003
Hi Daniel,
thanx a lot for the explanation of this MS-behaviour. So MS doesn't
cascade getFeatureInfo-requests. That brings me to another question: How
do I build a _cascading_ wms-server-architecture capable of
getFeatureInfo-requests?
I'm not sure if I understood the handling of the
getWMSFeatureInfoURL()-method correctly, but I think this only helps me
on the client-side. What do I do with another WMS-server, which tries to
access the dynamic layers on a remote mapserver created by my
php-component?
So far, I didn't manage to get a working sample of a
getWMSFeatureInfoURL, so excuse my perhaps premature disbelief: What
would be the result of the getWMSFeatureInfoURL()-method? Wouldn't that
be an URL, where again a getFeatureInfo-request is launched against my
dynamic layer? The only way to solve this I can imagine so far, is to
create an URL which refers directly to a php, which processes a kind of
getFeatureInfo-operation and returns the desired data. Perhaps I've a
major misunderstanding of the underlying concept.
TIA,
Frieso ter Haseborg
- Software Development -
S&F Datentechnik GmbH&Co.KG
Reimersstr. 41b
26789 Leer, Germany
>-----Original Message-----
>From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
>Sent: Wednesday, November 05, 2003 3:03 AM
>To: Frieso ter Haseborg
>Cc: mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] getFeatureInfo on dynamic layer
>-emptyexception
>Frieso ter Haseborg wrote:
>> I want MS to call my php like this:
>> http://my.ip/kmvims/test4.php?version=1.1.0&request=GetMap. This part
>> works!
>This works because MapServer is able to cascade GetMap requests...
>> When calling
>http://my.ip/cgi-bin/mapserv.exe?map=../htdocs/kmvims/test.map&
>version=1
>.1.0&request=GetFeatureInfo&query_layers=wms&x=251&y=329&INFO_F
>ORMAT=tex
>> t/plain
http://my.ip/kmvims/test4.php?version=1.1.0&request=GetFeatureInfo&query
> _layers=wms&x=251&y=329&INFO_FORMAT=text/plain
> So I could do the getFeatureInfo-processing in my php and just return
a
> plain text, html or whatever MS needs to process. But MS refuses to
call
> the php at all on doing a getFeatureInfo-req.
... and this doesn't work because MapServer doesn't cascade
GetFeatureInfo requests. The main reason behind this is that the output
of GetFeatureInfo requests is not clearly defined by WMS so MapServer
would no know what to expect from the remote server.
Instead MapScript offers a $layer->getWMSFeatureInfoURL() method that
will return you the GetFeatureInfo url for a click at a specified
location on a WMS layer and it's up to your client application (PHP
script) to call this URL and try to make sense of the result.
Daniel
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
