[Mapserver-users] map positioning -- help needed
Murat Isik
muratisik at megatek.com.tr
Wed Nov 5 09:04:27 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0110_01C3A3B6.7CF7DD20
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Thank you, but I dont think neither my web page nor my php can handle =
javascripts. I use mapserver 3.6, php 4.2.2 and while compiling I did =
nothing about java...
Unfornunately java is out of my league...
Maybe a php/mapscript code will be better.
Thanks anyway:)
Hvae a nice day.
Murat Isik
----- Original Message -----=20
To: Murat Isik=20
Sent: Wednesday, November 05, 2003 3:57 PM
Subject: RE: [Mapserver-users] map positioning -- help needed
There is a sample code in the Mpaserver users meeting,=20
=20
Here is how you do it in using javascript:
=20
<SCRIPT LANGUAGE=3D"JavaScript">
=20
function setbox_handler(name, minx, miny, maxx, maxy, redraw) {
document.mapserv.imgbox.value =3D minx + " " + miny + " " + maxx + =
" " + maxy;
document.mapserv.imgxy.value =3D minx + " " + miny;
if (redraw) {
document.mapserv.submit();
} =20
function seterror_handler(message) {
alert(message);
} =20
=20
function newWindow(w){
var =
win=3Dwindow.open(w,"New_Window","height=3D500,width=3D650,resizable,scro=
llbars,toolbar");
win.window.focus();
=20
var pansize =3D 0.80;
=20
function pan(direction) { =20
var x, y;
=20
if(direction =3D=3D 'n') {
x =3D ([mapwidth]-1)/2.0;
y =3D 0 - [mapheight]*pansize + [mapheight]/2.0;
} else if(direction =3D=3D 'nw') {
x =3D 0 - [mapwidth]*pansize + [mapwidth]/2.0;
} else if(direction =3D=3D 'ne') {
x =3D ([mapwidth]-1) + [mapwidth]*pansize - [mapwidth]/2.0;
} else if(direction =3D=3D 's') {
y =3D ([mapheight]-1) + [mapheight]*pansize - [mapheight]/2.0;
} else if(direction =3D=3D 'sw') {
} else if(direction =3D=3D 'se') {
} else if(direction =3D=3D 'e') {
y =3D ([mapheight]-1)/2.0;
} else if(direction =3D=3D 'w') {
=20
document.mapserv.zoomdir[1].checked =3D true; // force pan
document.mapserv.imgxy.value =3D x + " " + y;
} =20
=20
</SCRIPT>
=20
=20
and in side your <html><body>
=20
<table width=3D"390" border=3D"0" cellspacing=3D"0" cellpadding=3D"0" =
align=3D"center" bgcolor=3D"#666666">
<tr>
<td align=3D"right" width=3D"18"><a =
href=3D"javascript:pan('nw')"><img src=3D"[root]/graphics/nw.gif" =
width=3D"18" height=3D"18" border=3D"0" alt=3D"pan northwest"></a></td>
<td align=3D"center"><a href=3D"javascript:pan('n')"><img =
src=3D"[root]/graphics/n.gif" width=3D"23" height=3D"18" border=3D"0" =
alt=3D"pan north"></a></td>
<td align=3D"left" width=3D"18"><a =
href=3D"javascript:pan('ne')"><img src=3D"[root]/graphics/ne.gif" =
width=3D"18" height=3D"18" border=3D"0" alt=3D"pan northeast"></a></td>
</tr>
<tr>
href=3D"javascript:pan('w')"><img src=3D"[root]/graphics/w.gif" =
width=3D"18" height=3D"23" border=3D"0" alt=3D"pan west"></a></td>
<table cellpadding=3D"0" cellspacing=3D"0" border=3D"0">
<tr>
<td colspan=3D"2">
<applet codebase=3D"/java/jBox" code=3D"jBox.class" =
width=3D"600" height=3D"600" name=3D"jBox" MAYSCRIPT>
<param name=3D"image" value=3D"http://[host][img]">
</applet>
</td>
</tr>
</table>
<td>
href=3D"javascript:pan('e')"><img src=3D"[root]/graphics/e.gif" =
width=3D"18" height=3D"23" border=3D"0" alt=3D"pan east"></a></td>
</tr>
<tr>
href=3D"javascript:pan('sw')"><img src=3D"[root]/graphics/sw.gif" =
width=3D"18" height=3D"18" border=3D"0" alt=3D"pan southwest"></a></td>
<td align=3D"center"><a href=3D"javascript:pan('s')"><img =
src=3D"[root]/graphics/s.gif" width=3D"23" height=3D"18" border=3D"0" =
alt=3D"pan south"></a></td>
href=3D"javascript:pan('se')"><img src=3D"[root]/graphics/se.gif" =
width=3D"18" height=3D"18" border=3D"0" alt=3D"pan southeast"></a></td>
</tr>
</table>
=20
Giri
=20
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Murat Isik
Sent: Wednesday, November 05, 2003 8:50 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] map positioning -- help needed
=20
Hello,
=20
I have the following code at my hand and I am supposed to add map =
positioning property to it. It's like there will be more four buttons, =
right, left, up, down. When user presses any of them the map will move =
slightly to selected direction without changing the zoom factor. How do =
I add this to the code? Any ideas? Please, I urgently need help...
=20
Thanks in advance..
=20
Murat Isik
=20
=20
<HEAD>
<TITLE>MEGATEK</TITLE>
</HEAD>
<CENTER>
<FORM METHOD=3DPOST ACTION=3D<?php echo $PHP_SELF?>>
<H1>TEST SERVER</H1>
<IMG SRC=3D"yeni_ust.gif">
<P>
<?php
dl("php_mapscript.so");
=20
mysql_connect("213.74.112.162","root","sqlpass") or
die ("Could not connect to database");
=20
mysql_select_db("gpstrack") or
die("Could not select database");
=20
$val_zsize=3D3;
$check_pan=3D"CHECKED";
=20
$shpFname =3D "target1";
$shpFile =3D ms_newShapeFileObj($shpFname, MS_SHP_POINT);
=20
$shpFname1 =3D "target2";
$shpFile1 =3D ms_newShapeFileObj($shpFname1, MS_SHP_POINT);
=20
$pt =3D ms_newPointObj();
=20
$i =3D 0;
=20
$result =3D mysql_query("select * from track3") or
die (mysql_error());
=20
$x[0]=3D0;
$y[0]=3D0;
=20
while ($row =3D mysql_fetch_array($result))
++$i;
$test_x[$i] =3D $row["lodegrees"]+$row["lominutes"]/60;
$test_y[$i] =3D $row["ldegrees"]+$row["lminutes"]/60;
file://echo $row["lominutes"];
file://echo "<br>\n";
=20
if($test_x[$i]=3D=3D$x[$i-1] || $test_y[$i]=3D=3D$y[$i-1])
--$i;
}else
=20
$x[$i] =3D $test_x[$i];
$y[$i] =3D $test_y[$i];
=20
=20
mysql_free_result($result);
=20
for($k=3D1;$k<=3D$i-1;++$k)
$pt->setXY($x[$k], $y[$k]);
$shpFile->addPoint($pt);
=20
$pt->setXY($x[$i], $y[$i]);
$shpFile1->addPoint($pt);
=20
$shpFile->free();
$shpFile1->free();
=20
$def =3Darray(array("UNIQID", "C", 13),array("NOM", "C", 128));
$dbfFile =3D dbase_create($shpFname.".dbf", $def);
dbase_add_record($dbfFile, array("1","TEST"));
=20
$dbfFile =3D dbase_create($shpFname1.".dbf", $def);
=20
$myMap =3D ms_newMapObj("demo_try.map");
=20
#$myLayer =3D $myMap->getLayerByName("target1");
#$myLayer->set("data", $shpFname);
#$myLayer->set('status', MS_ON);
=20
if ( isset($HTTP_POST_VARS["mapa_x"]) && =
isset($HTTP_POST_VARS["mapa_y"])
&& !isset($HTTP_POST_VARS["full"]) ) {
=20
// $extent_to_set =3D explode(" ",$HTTP_POST_VARS["extent"]);
=20
$extent_to_set[0] =3D 29.057;
$extent_to_set[1] =3D 40.954;
$extent_to_set[2] =3D 29.143;
$extent_to_set[3] =3D 40.999;
=20
$myMap->setextent($extent_to_set[0],$extent_to_set[1],
$extent_to_set[2],$extent_to_set[3]);
=20
$my_point =3D ms_newpointObj();
$my_point->setXY($HTTP_POST_VARS["mapa_x"],$HTTP_POST_VARS["mapa_y"]);
=20
$my_extent =3D ms_newrectObj();
=20
$my_extent->setextent($extent_to_set[0],$extent_to_set[1],
=20
$zoom_factor =3D =
$HTTP_POST_VARS["zoom"]*$HTTP_POST_VARS["zsize"];
if ($zoom_factor =3D=3D 0) {
$zoom_factor =3D 1;
$check_pan =3D "CHECKED";
$check_zout =3D "";
$check_zin =3D "";
} else if ($zoom_factor < 0) {
$check_pan =3D "";
$check_zout =3D "CHECKED";
$check_zin =3D "";
} else {
$check_pan =3D "";
$check_zout =3D "";
$check_zin =3D "CHECKED";
=20
$val_zsize =3D abs($zoom_factor);
=20
$myMap->zoompoint($zoom_factor,$my_point,$myMap->width,$myMap->height,
$my_extent);
=20
$img =3D $myMap->draw();
$image_url =3D $img->saveWebImage(GIF,1,1,0);
=20
<BODY>
<center>
<table border=3D0 cellspacing=3D0 cellpadding=3D4 bgcolor=3D"#FFFFFF">
<tr>
<td valign=3D"top" align=3Dcenter>
<table cellpadding=3D"0" cellspacing=3D"5" border=3D"5">
<tr><td colspan=3D"2"><INPUT NAME=3D"mapa" TYPE=3D"image" =
SRC=3D"<?php echo $image_url; ?>" width=3D600 height=3D600 =
border=3D0></td></tr>
<tr>
<TR>
<TD>
Pan
</TD>
<TD>
<INPUT TYPE=3DRADIO NAME=3D"zoom" VALUE=3D0 <?php echo =
$check_pan?>>
</TD>
</TR>
<TR>
<TD>
Zoom In
</TD>
<TD>
<INPUT TYPE=3DRADIO NAME=3D"zoom" VALUE=3D1 <?php echo =
$check_zin?>>
</TD>
</TR>
<TR>
<TD>
Zoom Out
</TD>
<TD>
<INPUT TYPE=3DRADIO NAME=3D"zoom" VALUE=3D-1 <?php echo =
$check_zout?>>
</TD>
</TR>
<TR>
<TD>
Zoom Size
</TD>
<TD>
<INPUT TYPE=3DTEXT NAME=3D"zsize" VALUE=3D"<?php echo =
$val_zsize?>"
SIZE=3D2>
</TD>
</TR>
<TR>
<TD>
Full Extent
</TD>
<TD>
<INPUT TYPE=3DSUBMIT NAME=3D"full" VALUE=3D"Go"
SIZE=3D2>
</TD>
</TABLE>
<INPUT TYPE=3DHIDDEN NAME=3D"extent" VALUE=3D"<?php echo =
$extent_to_html?>">
</FORM>
</CENTER>
=20
</BODY>
</HTML>
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META content=3D"text/html; charset=3Diso-8859-1" =
http-equiv=3DContent-Type>
<META content=3D"MSHTML 5.00.3700.6699" name=3DGENERATOR>
<STYLE>@font-face {
font-family: Sendnya;
@font-face {
font-family: Tahoma;
P.MsoNormal {
FONT-FAMILY: "Times New Roman"; FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt
LI.MsoNormal {
DIV.MsoNormal {
A:link {
COLOR: blue; TEXT-DECORATION: underline
SPAN.MsoHyperlink {
A:visited {
SPAN.MsoHyperlinkFollowed {
P.MsoAutoSig {
LI.MsoAutoSig {
DIV.MsoAutoSig {
SPAN.EmailStyle17 {
COLOR: navy; FONT-FAMILY: Arial
DIV.Section1 {
page: Section1
</STYLE>
</HEAD>
<BODY bgColor=3Dwhite lang=3DEN-US link=3Dblue vLink=3Dblue>
<DIV><FONT face=3DArial size=3D2>Thank you, but I dont think neither my =
web page nor=20
my php can handle javascripts. I use mapserver 3.6, php 4.2.2 and while=20
compiling I did nothing about java...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Unfornunately java is out of my=20
league...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Maybe a php/mapscript code will be=20
better.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Thanks anyway:)</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Hvae a nice day.</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Murat Isik</FONT></DIV>
<BLOCKQUOTE=20
style=3D"BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: =
0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
<DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
<A href=3D"mailto:palanisamyg at ornl.gov" =
title=3Dpalanisamyg at ornl.gov>Palanisamy,=20
Giri</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A=20
href=3D"mailto:muratisik at megatek.com.tr" =
title=3Dmuratisik at megatek.com.tr>Murat=20
Isik</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Wednesday, November 05, =
2003 3:57=20
PM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> RE: [Mapserver-users] =
map=20
positioning -- help needed</DIV>
<DIV><BR></DIV>
<DIV class=3DSection1>
<P class=3DMsoNormal><FONT color=3Dnavy face=3DArial size=3D2><SPAN=20
style=3D"COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt">There is a =
sample=20
code in the Mpaserver users meeting, </SPAN></FONT></P>
style=3D"COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: =
10pt"> </SPAN></FONT></P>
style=3D"COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt">Here is how =
you do it=20
in using javascript:</SPAN></FONT></P>
10pt"> =20
</SPAN></FONT></P>
style=3D"COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt"><SCRIPT=20
LANGUAGE=3D"JavaScript"></SPAN></FONT></P>
style=3D"COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt"> =
function=20
setbox_handler(name, minx, miny, maxx, maxy, redraw) =
{</SPAN></FONT></P>
10pt"> =20
document.mapserv.imgbox.value =3D minx + " " + miny + " " + maxx + " " =
+=20
maxy;</SPAN></FONT></P>
10pt"> =20
document.mapserv.imgxy.value =3D minx + " " + miny;</SPAN></FONT></P>
10pt"> if=20
(redraw) {</SPAN></FONT></P>
10pt"> =20
document.mapserv.submit();</SPAN></FONT></P>
10pt"> =20
} </SPAN></FONT></P>
style=3D"COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt"> =20
}</SPAN></FONT></P>
function=20
seterror_handler(message) {</SPAN></FONT></P>
10pt"> =20
alert(message);</SPAN></FONT></P>
10pt"> =20
</SPAN></FONT></P>
function=20
newWindow(w){</SPAN></FONT></P>
10pt"> =20
var=20
llbars,toolbar");</SPAN></FONT></P>
10pt"> =20
win.window.focus();</SPAN></FONT></P>
}</SPAN></FONT></P>
style=3D"COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt"> var =
pansize =3D=20
0.80;</SPAN></FONT></P>
function=20
pan(direction) { </SPAN></FONT></P>
10pt"> =20
var x, y;</SPAN></FONT></P>
10pt"> =20
if(direction =3D=3D 'n') {</SPAN></FONT></P>
10pt"> =20
x =3D ([mapwidth]-1)/2.0;</SPAN></FONT></P>
10pt"> =20
y =3D 0 - [mapheight]*pansize + [mapheight]/2.0;</SPAN></FONT></P>
10pt"> }=20
else if(direction =3D=3D 'nw') {</SPAN></FONT></P>
10pt"> =20
x =3D 0 - [mapwidth]*pansize + [mapwidth]/2.0;</SPAN></FONT></P>
10pt"> =20
10pt"> }=20
else if(direction =3D=3D 'ne') {</SPAN></FONT></P>
10pt"> =20
x =3D ([mapwidth]-1) + [mapwidth]*pansize - =
10pt"> =20
10pt"> }=20
else if(direction =3D=3D 's') {</SPAN></FONT></P>
10pt"> =20
10pt"> =20
y =3D ([mapheight]-1) + [mapheight]*pansize - =
10pt"> }=20
else if(direction =3D=3D 'sw') {</SPAN></FONT></P>
10pt"> =20
10pt"> =20
10pt"> }=20
else if(direction =3D=3D 'se') {</SPAN></FONT></P>
10pt"> =20
10pt"> =20
10pt"> }=20
else if(direction =3D=3D 'e') {</SPAN></FONT></P>
10pt"> =20
10pt"> =20
y =3D ([mapheight]-1)/2.0;</SPAN></FONT></P>
10pt"> }=20
else if(direction =3D=3D 'w') {</SPAN></FONT></P>
10pt"> =20
10pt"> =20
10pt"> =20
}</SPAN></FONT></P>
10pt"> =20
document.mapserv.zoomdir[1].checked =3D true; // force =
pan</SPAN></FONT></P>
10pt"> =20
document.mapserv.imgxy.value =3D x + " " + y;</SPAN></FONT></P>
10pt"> =20
</SPAN></FONT></P>
10pt"> </SCRIPT></SPAN></FONT></P>
style=3D"COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt">and in side =
your=20
<html><body></SPAN></FONT></P>
style=3D"COLOR: navy; FONT-FAMILY: Arial; FONT-SIZE: 10pt"><table =
width=3D"390"=20
border=3D"0" cellspacing=3D"0" cellpadding=3D"0" align=3D"center"=20
bgcolor=3D"#666666"></SPAN></FONT></P>
10pt"> =20
<tr></SPAN></FONT></P>
10pt"> =20
<td align=3D"right" width=3D"18"><a=20
href=3D"javascript:pan('nw')"><img =
src=3D"[root]/graphics/nw.gif" width=3D"18"=20
height=3D"18" border=3D"0" alt=3D"pan=20
northwest"></a></td></SPAN></FONT></P>
10pt"> =20
<td align=3D"center"><a =
href=3D"javascript:pan('n')"><img=20
alt=3D"pan=20
north"></a></td></SPAN></FONT></P>
10pt"> =20
href=3D"javascript:pan('ne')"><img=20
src=3D"[root]/graphics/ne.gif" width=3D"18" height=3D"18" border=3D"0" =
alt=3D"pan=20
northeast"></a></td></SPAN></FONT></P>
10pt"> =20
</tr></SPAN></FONT></P>
10pt"> =20
10pt"> =20
href=3D"javascript:pan('w')"><img=20
src=3D"[root]/graphics/w.gif" width=3D"18" height=3D"23" border=3D"0" =
alt=3D"pan=20
10pt"> =20
<td align=3D"center"></SPAN></FONT></P>
10pt"> =
<table cellpadding=3D"0" cellspacing=3D"0" =
border=3D"0"></SPAN></FONT></P>
10pt"> &=
nbsp; =20
10pt"> &=
nbsp; =20
<td colspan=3D"2"></SPAN></FONT></P>
10pt"> &=
nbsp; =20
<applet codebase=3D"/java/jBox" code=3D"jBox.class" width=3D"600" =
height=3D"600"=20
name=3D"jBox" MAYSCRIPT></SPAN></FONT></P>
10pt"> &=
nbsp; =20
<param name=3D"image" =
value=3D"http://[host][img]"></SPAN></FONT></P>
10pt"> &=
nbsp; =20
</applet></SPAN></FONT></P>
10pt"> &=
nbsp; =20
10pt"> &=
nbsp;=20
10pt"> =20
</table></SPAN></FONT></P>
10pt"> =20
<td></SPAN></FONT></P>
10pt"> =20
href=3D"javascript:pan('e')"><img=20
src=3D"[root]/graphics/e.gif" width=3D"18" height=3D"23" border=3D"0" =
alt=3D"pan=20
10pt"> =20
10pt"> =20
10pt"> =20
href=3D"javascript:pan('sw')"><img =
src=3D"[root]/graphics/sw.gif" width=3D"18"=20
southwest"></a></td></SPAN></FONT></P>
10pt"> =20
href=3D"javascript:pan('s')"><img=20
alt=3D"pan=20
south"></a></td></SPAN></FONT></P>
10pt"> =20
href=3D"javascript:pan('se')"><img=20
src=3D"[root]/graphics/se.gif" width=3D"18" height=3D"18" border=3D"0" =
alt=3D"pan=20
southeast"></a></td></SPAN></FONT></P>
10pt"> =20
10pt"> =20
<DIV>
<P class=3DMsoAutoSig><FONT color=3Dnavy face=3D"Times New Roman" =
size=3D3><SPAN=20
style=3D"COLOR: navy; FONT-SIZE: 12pt">Giri</SPAN></FONT></P></DIV>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><FONT face=3DTahoma =
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Tahoma; FONT-SIZE: 10pt">-----Original=20
Message-----<BR><B><SPAN style=3D"FONT-WEIGHT: bold">From:</SPAN></B>=20
mapserver-users-admin at lists.gis.umn.edu=20
[mailto:mapserver-users-admin at lists.gis.umn.edu] <B><SPAN=20
style=3D"FONT-WEIGHT: bold">On Behalf Of </SPAN></B>Murat =
Isik<BR><B><SPAN=20
style=3D"FONT-WEIGHT: bold">Sent:</SPAN></B> Wednesday, November 05, =
2003 8:50=20
AM<BR><B><SPAN style=3D"FONT-WEIGHT: bold">To:</SPAN></B>=20
mapserver-users at lists.gis.umn.edu<BR><B><SPAN=20
style=3D"FONT-WEIGHT: bold">Subject:</SPAN></B> [Mapserver-users] map=20
positioning -- help needed</SPAN></FONT></P>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><FONT face=3D"Times =
New Roman"=20
size=3D3><SPAN style=3D"FONT-SIZE: 12pt"> </SPAN></FONT></P>
<DIV>
<P class=3DMsoNormal style=3D"MARGIN-LEFT: 0.5in"><FONT face=3DArial =
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: =
10pt">Hello,</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
size=3D3><SPAN style=3D"FONT-SIZE: =
12pt"> </SPAN></FONT></P></DIV>
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">I have the following =
code at my=20
hand and I am supposed to add map positioning property to it. =
It's like=20
there will be more four buttons, right, left, up, down. When user =
presses any=20
of them the map will move slightly to selected direction without =
changing the=20
zoom factor. How do I add this to the code? Any ideas? Please, I =
urgently need=20
help...</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">Thanks in=20
advance..</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">Murat =
Isik</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"><HEAD><BR><TITLE>MEGATEK</TITLE><BR></HEAD>=
<BR><CENTER><BR><FORM=20
METHOD=3DPOST ACTION=3D<?php echo =
$PHP_SELF?>><BR><H1>TEST=20
SERVER</H1><BR><IMG=20
SRC=3D"yeni_ust.gif"><BR><P><BR><?php<BR>dl("php_mapscript.so=
");</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt">mysql_connect("213.74.112.162","root","sqlpass")=20
or<BR> die ("Could not =
connect to=20
database");</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt">mysql_select_db("gpstrack")=20
or<BR> die("Could not select =
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt">$val_zsize=3D3;<BR>$check_pan=3D"CHECKED";</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">$shpFname =3D =
"target1";<BR>$shpFile=20
=3D ms_newShapeFileObj($shpFname, =
MS_SHP_POINT);</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">$shpFname1 =3D=20
"target2";<BR>$shpFile1 =3D ms_newShapeFileObj($shpFname1,=20
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">$pt =3D=20
ms_newPointObj();</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">$i =3D =
0;</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">$result =3D =
mysql_query("select *=20
from track3") or<BR> die=20
(mysql_error());</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"><BR>$x[0]=3D0;<BR>$y[0]=3D0;</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">while ($row =3D=20
mysql_fetch_array($result))<BR>{<BR>++$i;<BR>$test_x[$i] =3D=20
$row["lodegrees"]+$row["lominutes"]/60;<BR>$test_y[$i] =3D=20
$row["ldegrees"]+$row["lminutes"]/60;<BR><A=20
href=3D"file:///\\echo">file://echo</A> $row["lominutes"];<BR><A=20
href=3D"file:///\\echo">file://echo</A> =
"<br>\n";</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"><BR>if($test_x[$i]=3D=3D$x[$i-1] ||=20
$test_y[$i]=3D=3D$y[$i-1])<BR>{<BR>--$i;<BR>}else<BR>{</SPAN></FONT></P><=
/DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">$x[$i] =3D =
$test_x[$i];<BR>$y[$i] =3D=20
$test_y[$i];</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt">}</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt">}<BR>mysql_free_result($result);</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"><BR>for($k=3D1;$k<=3D$i-1;++$k)<BR>{<BR>$pt->setXY($x[$k],=20
$y[$k]);<BR>$shpFile->addPoint($pt);<BR>};</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">$pt->setXY($x[$i],=20
$y[$i]);<BR>$shpFile1->addPoint($pt);</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"><BR>$shpFile->free();<BR>$shpFile1->free();</SPAN></FONT></P>=
</DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">$def =
=3Darray(array("UNIQID", "C",=20
13),array("NOM", "C", 128));<BR>$dbfFile =3D =
dbase_create($shpFname.".dbf",=20
$def);<BR>dbase_add_record($dbfFile,=20
array("1","TEST"));</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
dbase_create($shpFname1.".dbf",=20
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">$myMap =3D=20
ms_newMapObj("demo_try.map");</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">#$myLayer =3D=20
$myMap->getLayerByName("target1");<BR>#$myLayer->set("data",=20
$shpFname);<BR>#$myLayer->set('status', =
MS_ON);</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt"><BR>if (=20
isset($HTTP_POST_VARS["mapa_x"]) &&=20
isset($HTTP_POST_VARS["mapa_y"])<BR> =
&&=20
!isset($HTTP_POST_VARS["full"]) ) {</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"> // =20
$extent_to_set =3D explode("=20
",$HTTP_POST_VARS["extent"]);</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt"><BR>$extent_to_set[0] =
=3D=20
29.057;<BR>$extent_to_set[1] =3D 40.954;<BR>$extent_to_set[2] =3D=20
29.143;<BR>$extent_to_set[3] =3D 40.999;</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt"><BR> =20
$myMap->setextent($extent_to_set[0],$extent_to_set[1],<BR> =
nbsp; =20
$extent_to_set[2],$extent_to_set[3]);</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"> =20
$my_point =3D ms_newpointObj();<BR> =20
$my_point->setXY($HTTP_POST_VARS["mapa_x"],$HTTP_POST_VARS["mapa_y"]);=
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"> =20
$my_extent =3D ms_newrectObj();</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"> =20
$my_extent->setextent($extent_to_set[0],$extent_to_set[1],<BR> &n=
bsp; &nb=
sp; &nbs=
p; =20
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"> =20
$zoom_factor =3D=20
$HTTP_POST_VARS["zoom"]*$HTTP_POST_VARS["zsize"];<BR> &n=
bsp; =20
if ($zoom_factor =3D=3D 0)=20
{<BR> &n=
bsp; =20
$zoom_factor =3D=20
1;<BR> &=
nbsp; =20
$check_pan =3D=20
"CHECKED";<BR>  =
; =20
$check_zout =3D=20
"";<BR> =
=20
$check_zin =3D "";<BR> } else if =
($zoom_factor=20
< 0)=20
{<BR> &n=
bsp; =20
$check_pan =3D=20
"";<BR> =
=20
$check_zout =3D=20
"CHECKED";<BR>  =
; =20
$check_zin =3D "";<BR> } else=20
{<BR> &n=
bsp; =20
$check_pan =3D=20
"";<BR> =
=20
$check_zout =3D=20
"";<BR> =
=20
$check_zin =3D "CHECKED";<BR> =20
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"> =20
$val_zsize =3D abs($zoom_factor);</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"> =20
$myMap->zoompoint($zoom_factor,$my_point,$myMap->width,$myMap->h=
eight,<BR> &nb=
sp; =20
$my_extent);</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
style=3D"FONT-FAMILY: Arial; FONT-SIZE: 10pt">}<BR>$img =3D=20
$myMap->draw();<BR>$image_url =3D=20
$img->saveWebImage(GIF,1,1,0);</SPAN></FONT></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt">?><BR><BODY><BR><center><BR><table=20
border=3D0 cellspacing=3D0 cellpadding=3D4=20
bgcolor=3D"#FFFFFF"><BR><tr><BR><td valign=3D"top"=20
align=3Dcenter><BR> <table cellpadding=3D"0" =
cellspacing=3D"5"=20
border=3D"5"><BR> <tr><td =
colspan=3D"2"><INPUT=20
NAME=3D"mapa" TYPE=3D"image" SRC=3D"<?php echo $image_url; ?>" =
width=3D600=20
height=3D600 =
border=3D0></td></tr><BR> =20
<tr><BR> <TR><BR> =20
<TD><BR>  =
; =20
Pan<BR> =20
</TD><BR> =20
<TD><BR>  =
; =20
<INPUT TYPE=3DRADIO NAME=3D"zoom" VALUE=3D0 <?php echo=20
$check_pan?>><BR> =20
</TD><BR> </TR><BR> <TR><BR>  =
; =20
<TD><BR>  =
; =20
Zoom In<BR> =20
</TD><BR> =20
<TD><BR>  =
; =20
<INPUT TYPE=3DRADIO NAME=3D"zoom" VALUE=3D1 <?php echo=20
$check_zin?>><BR> =20
; =20
<TD><BR>  =
; =20
Zoom Out<BR> =20
</TD><BR> =20
<TD><BR>  =
; =20
<INPUT TYPE=3DRADIO NAME=3D"zoom" VALUE=3D-1 <?php echo=20
$check_zout?>><BR> =20
; =20
<TD><BR>  =
; =20
Zoom Size<BR> =20
</TD><BR> =20
<TD><BR>  =
; =20
<INPUT TYPE=3DTEXT NAME=3D"zsize" VALUE=3D"<?php echo=20
$val_zsize?>"<BR>  =
; =20
SIZE=3D2><BR> =20
; =20
<TD><BR>  =
; =20
Full Extent<BR> =20
</TD><BR> =20
<TD><BR>  =
; =20
<INPUT TYPE=3DSUBMIT NAME=3D"full"=20
VALUE=3D"Go"<BR> &nb=
sp; =20
SIZE=3D2><BR> =20
</TD><BR></TABLE><BR><INPUT TYPE=3DHIDDEN =
NAME=3D"extent"=20
$extent_to_html?>"><BR></FORM><BR></CENTER></SPAN></FON=
T></P></DIV>
<DIV>
New Roman"=20
<DIV>
size=3D2><SPAN=20
10pt"></BODY><BR></HTML></SPAN></FONT></P></DIV></DIV></BLOCK=
QUOTE></BODY></HTML>
------=_NextPart_000_0110_01C3A3B6.7CF7DD20--
