[Mapserver-users] mapserv does not work.
Mahinn Zahoor
MZahoor at lmkr.com
Thu Nov 6 02:16:04 EST 2003
This is a multipart message in MIME format.
--=_alternative 0027A9F945256DD6_=
Content-Type: text/plain; charset="US-ASCII"
Hello all
i am a new one to install maperver on linux environment.
i have installed all the packages successfully required for mapserver,
under the maperver directory i issue the following command
./configure --with-gd=/usr/local --with-proj=/usr/local/
--with-gdal=/usr/local/bin/gdal-config --with-jpg=/usr/local
it gets configured all ok.
then i run
make
things go successfully
but when i run
./mapserv i get the following error regarding libgd.so.2
Cannot open shared file
No such file or directory
i am running Apache 2.0.48 and there is nothing in its error log.
Please reply asap.
Regards
Mahinn
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">Hello all</font>
<br><font size=2 face="sans-serif">i am a new one to install maperver on
linux environment.</font>
<br><font size=2 face="sans-serif">i have installed all the packages successfully
required for mapserver, under the maperver directory i issue the following
command</font>
<br>
<br><font size=2 face="sans-serif"><b>./configure --with-gd=/usr/local
--with-proj=/usr/local/ --with-gdal=/usr/local/bin/gdal-config --with-jpg=/usr/local</b></font>
<br>
<br><font size=2 face="sans-serif">it gets configured all ok.</font>
<br><font size=2 face="sans-serif">then i run</font>
<br>
<br><font size=2 face="sans-serif"><b>make </b></font>
<br><font size=2 face="sans-serif">things go successfully</font>
<br>
<br><font size=2 face="sans-serif">but when i run </font>
<br><font size=2 face="sans-serif"><b>./mapserv</b> i get the following
error regarding <b>libgd.so.2</b></font>
<br><font size=2 face="sans-serif">Cannot open shared file </font>
<br><font size=2 face="sans-serif">No such file or directory</font>
<br>
<br>
<br><font size=2 face="sans-serif">i am running Apache 2.0.48 and there
is nothing in its error log.</font>
<br>
<br><font size=2 face="sans-serif">Please reply asap.</font>
<br>
<br><font size=2 face="sans-serif">Regards</font>
<br><font size=2 face="sans-serif">Mahinn</font>
<br>
<br><font size=2 face="sans-serif"><br>
</font>
--=_alternative 0027A9F945256DD6_=--
