[Mapserver-users] dynamic labeling -- help needed
Murat Isik
muratisik at megatek.com.tr
Thu Nov 6 03:17:23 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_009B_01C3A44F.2B920F70
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: quoted-printable
Thank you:)
I dont know any French, but visually I can see that it is a superb =
work...
I didnot understand how I can relate it to street-name-printing :(
Something else attracted my attention. If I am not wrong, you have some =
sort of radio buttons which move the map up-down-right-left. I need =
something like that more than I need street-name-printing. I cant really =
get the map to move anywhere either panned or zoomed. How did you get =
that done?
Thank you.
Have a nice day
Murat Isik
----- Original Message -----=20
To: mapserver-users at lists.gis.umn.edu ; Murat Isik=20
Sent: Thursday, November 06, 2003 11:07 AM
Subject: Re: [Mapserver-users] dynamic labeling -- help needed
hello Murat
i have used mif/mid file instead of shpefileobj
i have written a php function which write new mif/mid file when i have =
to refresh car position.
fx gamoy
http://www.mapxplore.com/
To: mapserver-users at lists.gis.umn.edu=20
Sent: Thursday, November 06, 2003 7:42 AM
Subject: [Mapserver-users] dynamic labeling -- help needed
Hello,
I am working on a mapscript project, it is a car tracking project.
Coordinates data comes to mysql, and my mapscript reads the data and =
prints
points on the map accordingly. However I am given a new task which =
is truely
above me...
I am handed a new layer for my project, a layer about streets. I am =
supposed
to add this layer to the map (which is easy) and have the php code
dynamicaly query this layer (which is "????" for me) I have used =
some free
map tools to "look
into" the layer. The database coloumn has two coloumns: an ID and an =
ADI
coloumn. ADI means "its name" in Turkish. Every time this php code =
is
called, it should not only print the streets on the map but next to =
each
street, it
should also write its name. Even if it is zoomed, it should still =
maintain
the names of the streets within the picture on the page. I have no =
idea
about how to do this, it is way above me...
One problem might be that while ID coloumn is all numbers, ADI =
coloumn has a
lot of Turkish characters (8859-9 named code set I believe, UTF-9 =
might be
another name too.) I dont know if php/mapscript supports this one. =
This is
not a big problem anyway. If I can get the ID coloumn to be printed, =
then I
can use ArcView or some other windows tool to open up the .dbf file =
and
rewrite the names with international characters and then change it =
to ID to
ADI.
But I dont have any ideas about how to get anything read out of the =
static
layer and properly printed on the page. I have searched the net and =
mail
list archieve but didnot understand much. Please help me...:)
Have a nice day:)
Murat Isik
=20
current php code:
=20
<HEAD>
<TITLE>Displaying a Point</TITLE>
</HEAD>
<CENTER>
<FORM METHOD=3DPOST ACTION=3D<?php echo $PHP_SELF?>>
<H1>DYNAMIC POINT</H1>
<P>
<?php
dl("php_mapscript.so");
mysql_connect("localhost","root","sqlpass") or
die ("Could not connect to database");
mysql_select_db("gpstrack") or
die("Could not select database");
$val_zsize=3D3;
$check_pan=3D"CHECKED";
$shpFname =3D "target1";
$shpFile =3D ms_newShapeFileObj($shpFname, MS_SHP_POINT);
$shpFname1 =3D "target2";
$shpFile1 =3D ms_newShapeFileObj($shpFname1, MS_SHP_POINT);
$pt =3D ms_newPointObj();
$i =3D 0;
$result =3D mysql_query("select * from track2") or
die (mysql_error());
$x[0]=3D0;
$y[0]=3D0;
while ($row =3D mysql_fetch_array($result))
++$i;
$test_x[$i] =3D $row["lodegrees"]+$row["lominutes"]/60;
$test_y[$i] =3D $row["ldegrees"]+$row["lminutes"]/60;
if($test_x[$i]=3D=3D$x[$i-1] || $test_y[$i]=3D=3D$y[$i-1])
--$i;
}else
$x[$i] =3D $test_x[$i];
$y[$i] =3D $test_y[$i];
mysql_free_result($result);
for($k=3D1;$k<=3D$i-1;++$k)
$pt->setXY($x[$k], $y[$k]);
$shpFile->addPoint($pt);
$pt->setXY($x[$i], $y[$i]);
$shpFile1->addPoint($pt);
$shpFile->free();
$shpFile1->free();
$def =3Darray(array("UNIQID", "C", 13),array("NOM", "C", 128));
$dbfFile =3D dbase_create($shpFname.".dbf", $def);
dbase_add_record($dbfFile, array("1","TEST"));
$dbfFile =3D dbase_create($shpFname1.".dbf", $def);
$myMap =3D ms_newMapObj("demo_try.map");
#$myLayer =3D $myMap->getLayerByName("target1");
#$myLayer->set("data", $shpFname);
#$myLayer->set('status', MS_ON);
if ( isset($HTTP_POST_VARS["mapa_x"]) && =
isset($HTTP_POST_VARS["mapa_y"])
&& !isset($HTTP_POST_VARS["full"]) ) {
// $extent_to_set =3D explode(" ",$HTTP_POST_VARS["extent"]);
$extent_to_set[0] =3D 29.057;
$extent_to_set[1] =3D 40.954;
$extent_to_set[2] =3D 29.143;
$extent_to_set[3] =3D 40.999;
$myMap->setextent($extent_to_set[0],$extent_to_set[1],
$extent_to_set[2],$extent_to_set[3]);
$my_point =3D ms_newpointObj();
$my_point->setXY($HTTP_POST_VARS["mapa_x"],$HTTP_POST_VARS["mapa_y"]);
$my_extent =3D ms_newrectObj();
$my_extent->setextent($extent_to_set[0],$extent_to_set[1],
$zoom_factor =3D =
$HTTP_POST_VARS["zoom"]*$HTTP_POST_VARS["zsize"];
if ($zoom_factor =3D=3D 0) {
$zoom_factor =3D 1;
$check_pan =3D "CHECKED";
$check_zout =3D "";
$check_zin =3D "";
} else if ($zoom_factor < 0) {
$check_pan =3D "";
$check_zout =3D "CHECKED";
$check_zin =3D "";
} else {
$check_pan =3D "";
$check_zout =3D "";
$check_zin =3D "CHECKED";
$val_zsize =3D abs($zoom_factor);
$myMap->zoompoint($zoom_factor,$my_point,$myMap->width,$myMap->height,
$my_extent);
$img =3D $myMap->draw();
$image_url =3D $img->saveWebImage(GIF,1,1,0);
<BODY>
<center>
<table border=3D0 cellspacing=3D0 cellpadding=3D4 =
bgcolor=3D"#FFFFFF">
<tr>
<td valign=3D"top" align=3Dcenter>
<table cellpadding=3D"0" cellspacing=3D"5" border=3D"5">
<tr><td colspan=3D"2"><INPUT NAME=3D"mapa" TYPE=3D"image" =
SRC=3D"<?php echo
$image_url; ?>" width=3D600 height=3D600 border=3D0></td></tr>
<tr>
<TR>
<TD>
Pan
</TD>
<TD>
<INPUT TYPE=3DRADIO NAME=3D"zoom" VALUE=3D0 <?php echo =
$check_pan?>>
</TD>
</TR>
<TR>
<TD>
Zoom In
</TD>
<TD>
<INPUT TYPE=3DRADIO NAME=3D"zoom" VALUE=3D1 <?php echo =
$check_zin?>>
</TD>
</TR>
<TR>
<TD>
Zoom Out
</TD>
<TD>
<INPUT TYPE=3DRADIO NAME=3D"zoom" VALUE=3D-1 <?php =
echo
$check_zout?>>
</TD>
</TR>
<TR>
<TD>
Zoom Size
</TD>
<TD>
<INPUT TYPE=3DTEXT NAME=3D"zsize" VALUE=3D"<?php echo =
$val_zsize?>"
SIZE=3D2>
</TD>
</TR>
<TR>
<TD>
Full Extent
</TD>
<TD>
<INPUT TYPE=3DSUBMIT NAME=3D"full" VALUE=3D"Go"
SIZE=3D2>
</TD>
</TABLE>
<INPUT TYPE=3DHIDDEN NAME=3D"extent" VALUE=3D"<?php echo =
$extent_to_html?>">
</FORM>
</CENTER>
</BODY>
</HTML>
current map file:
# Start of map file
NAME ERENKOY
STATUS ON
SIZE 600 600
EXTENT 29.057 40.954 29.143 40.999
UNITS DD
SHAPEPATH "/var/www/html/mapserver/itasca/"
IMAGECOLOR 255 255 255
#OUTPUTFORMAT
# NAME PNG
# DRIVER "GD/PNG"
# MIMETYPE "image/png"
# IMAGEMODE PC256
# EXTENSION "png"
#END
IMAGETYPE GIF
WEB
MINSCALE 1000
MAXSCALE 1550000
IMAGEPATH "/var/www/html/mapserver/tmp3/"
IMAGEURL "/mapserver/tmp3/"
END
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
LAYER
NAME 'ERENKOY_ORNEKILCE_PG_region'
TYPE polygon
STATUS DEFAULT
DATA ERENKOY_ORNEKILCE_PG_region
CLASSITEM 'ID'
CLASS
EXPRESSION '3'
OUTLINECOLOR 128 128 128
COLOR 225 225 185
END
CLASS
EXPRESSION /./
COLOR 255 255 255
END
END
LAYER
NAME ERENKOY_ORNEKMAHALLE_PG_region
GROUP cities
TYPE polygon
DATA ERENKOY_ORNEKMAHALLE_PG_region
STATUS ON
CLASSITEM 'ID'
CLASS
EXPRESSION /./
COLOR 255 225 185
OUTLINECOLOR 0 0 0
END
END
LAYER
NAME 'target2'
TYPE point
DATA target2
STATUS ON
CLASS
SYMBOL 'circle'
COLOR 255 255 0
SIZE 20
LABEL
COLOR 0 0 0
END
END
END
LAYER
NAME 'target1'
TYPE point
DATA target1
STATUS ON
CLASS
SYMBOL 'circle'
COLOR 255 0 0
SIZE 4
LABEL
COLOR 0 0 0
END
END
END
END # end of map file
Content-Type: text/html;
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META content=3D"text/html; charset=3Diso-8859-1" =
http-equiv=3DContent-Type>
<META content=3D"MSHTML 5.00.3700.6699" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>Thank you:)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I dont know any French, but visually I =
can see that=20
it is a superb work...</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>I didnot understand how I can relate it =
to=20
street-name-printing :(</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Something else attracted my attention. =
If I am not=20
wrong, you have some sort of radio buttons which move the map=20
up-down-right-left. I need something like that more than I need=20
street-name-printing. I cant really get the map to move anywhere either =
panned=20
or zoomed. How did you get that done?</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Thank you.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>Have a nice day</FONT></DIV>
<DIV> </DIV>
<DIV><FONT face=3DArial size=3D2>Murat Isik</FONT></DIV>
<BLOCKQUOTE dir=3Dltr=20
style=3D"BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: =
0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
<DIV style=3D"FONT: 10pt arial">----- Original Message ----- </DIV>
<DIV=20
style=3D"BACKGROUND: #e4e4e4; FONT: 10pt arial; font-color: =
black"><B>From:</B>=20
<A href=3D"mailto:fx.gamoy at mapxplore.com" =
title=3Dfx.gamoy at mapxplore.com>fx=20
gamoy</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>To:</B> <A=20
href=3D"mailto:mapserver-users at lists.gis.umn.edu"=20
title=3Dmapserver-users at lists.gis.umn.edu>mapserver-users at lists.gis.umn.e=
du</A>=20
; <A href=3D"mailto:muratisik at megatek.com.tr"=20
title=3Dmuratisik at megatek.com.tr>Murat Isik</A> </DIV>
<DIV style=3D"FONT: 10pt arial"><B>Sent:</B> Thursday, November 06, =
2003 11:07=20
AM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> Re: [Mapserver-users] =
dynamic=20
labeling -- help needed</DIV>
<DIV><BR></DIV>
<DIV><FONT face=3DArial size=3D2>hello Murat</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>i have used mif/mid file instead of=20
shpefileobj</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>i have written a php function which =
write new=20
mif/mid file when i have to refresh car position.</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>fx gamoy</FONT></DIV>
<DIV><FONT face=3DArial size=3D2><A=20
href=3D"http://www.mapxplore.com/">http://www.mapxplore.com/</A></FONT></=
DIV>
style=3D"BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; =
MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
<DIV=20
du</A>=20
</DIV>
2003 7:42=20
AM</DIV>
<DIV style=3D"FONT: 10pt arial"><B>Subject:</B> [Mapserver-users] =
dynamic=20
<DIV><BR></DIV>
<DIV><FONT face=3DArial size=3D2>Hello,<BR>I am working on a =
mapscript project,=20
it is a car tracking project.<BR>Coordinates data comes to mysql, =
and my=20
mapscript reads the data and prints<BR>points on the map =
accordingly.=20
However I am given a new task which is truely<BR>above me...<BR>I am =
handed=20
supposed<BR>to add=20
this layer to the map (which is easy) and have the php =
code<BR>dynamicaly=20
query this layer (which is "????" for me) I have used some =
free<BR>map tools=20
to "look<BR>into" the layer. The database coloumn has two coloumns: =
an ID=20
and an ADI<BR>coloumn. ADI means "its name" in Turkish. Every time =
this php=20
code is<BR>called, it should not only print the streets on the map =
but next=20
to each<BR>street, it<BR>should also write its name. Even if it is =
zoomed,=20
it should still maintain<BR>the names of the streets within the =
picture on=20
the page. I have no idea<BR>about how to do this, it is way above=20
me...<BR><BR>One problem might be that while ID coloumn is all =
numbers, ADI=20
coloumn has a<BR>lot of Turkish characters (8859-9 named code set I =
believe,=20
UTF-9 might be<BR>another name too.) I dont know if php/mapscript =
supports=20
this one. This is<BR>not a big problem anyway. If I can get the ID =
coloumn=20
to be printed, then I<BR>can use ArcView or some other windows tool =
to open=20
up the .dbf file and<BR>rewrite the names with international =
characters and=20
then change it to ID to<BR>ADI.<BR><BR>But I dont have any ideas =
about how=20
to get anything read out of the static<BR>layer and properly printed =
on the=20
page. I have searched the net and mail<BR>list archieve but didnot=20
understand much. Please help me...:)<BR><BR>Have a nice =
day:)<BR><BR>Murat=20
Isik</FONT></DIV>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2>current php code:</FONT></DIV>
<DIV><FONT face=3DArial =
size=3D2><HEAD><BR><TITLE>Displaying a=20
Point</TITLE><BR></HEAD><BR><CENTER><BR><FORM=20
METHOD=3DPOST ACTION=3D<?php echo =
$PHP_SELF?>><BR><H1>DYNAMIC=20
POINT</H1><BR><P><BR><?php<BR>dl("php_mapscript.so");<BR><=
BR>mysql_connect("localhost","root","sqlpass")=20
or<BR> die ("Could not =
connect to=20
database");<BR><BR>mysql_select_db("gpstrack")=20
or<BR> die("Could not =
select=20
database");<BR><BR>$val_zsize=3D3;<BR>$check_pan=3D"CHECKED";<BR><BR>$shp=
Fname =3D=20
"target1";<BR>$shpFile =3D ms_newShapeFileObj($shpFname,=20
MS_SHP_POINT);<BR><BR>$shpFname1 =3D "target2";<BR>$shpFile1 =3D=20
ms_newShapeFileObj($shpFname1, MS_SHP_POINT);<BR><BR>$pt =3D=20
ms_newPointObj();<BR><BR>$i =3D 0;<BR><BR>$result =3D =
mysql_query("select * from=20
track2") or<BR> die=20
(mysql_error());<BR><BR><BR>$x[0]=3D0;<BR>$y[0]=3D0;<BR><BR>while =
($row =3D=20
mysql_fetch_array($result))<BR>{<BR>++$i;<BR>$test_x[$i] =3D=20
$row["lodegrees"]+$row["lominutes"]/60;<BR>$test_y[$i] =3D=20
$row["ldegrees"]+$row["lminutes"]/60;<BR><BR><BR>if($test_x[$i]=3D=3D$x[$=
i-1] ||=20
$test_y[$i]=3D=3D$y[$i-1])<BR>{<BR>--$i;<BR>}else<BR>{<BR><BR>$x[$i] =
=3D=20
$test_x[$i];<BR>$y[$i] =3D=20
$test_y[$i];<BR><BR>}<BR><BR>}<BR>mysql_free_result($result);<BR><BR><BR>=
for($k=3D1;$k<=3D$i-1;++$k)<BR>{<BR>$pt->setXY($x[$k],=20
$y[$k]);<BR>$shpFile->addPoint($pt);<BR>};<BR><BR>$pt->setXY($x[$i]=
,=20
$y[$i]);<BR>$shpFile1->addPoint($pt);<BR><BR><BR>$shpFile->free();<=
BR>$shpFile1->free();<BR><BR>$def=20
=3Darray(array("UNIQID", "C", 13),array("NOM", "C", =
128));<BR>$dbfFile =3D=20
dbase_create($shpFname.".dbf", $def);<BR>dbase_add_record($dbfFile,=20
array("1","TEST"));<BR><BR>$def =3Darray(array("UNIQID", "C", =
13),array("NOM",=20
"C", 128));<BR>$dbfFile =3D dbase_create($shpFname1.".dbf",=20
$def);<BR>dbase_add_record($dbfFile, =
array("1","TEST"));<BR><BR>$myMap =3D=20
ms_newMapObj("demo_try.map");<BR><BR>#$myLayer =3D=20
$myMap->getLayerByName("target1");<BR>#$myLayer->set("data",=20
$shpFname);<BR>#$myLayer->set('status', MS_ON);<BR><BR><BR>if (=20
isset($HTTP_POST_VARS["mapa_x"]) &&=20
isset($HTTP_POST_VARS["mapa_y"])<BR> =20
&& !isset($HTTP_POST_VARS["full"]) )=20
{<BR><BR> // $extent_to_set =3D =
explode("=20
",$HTTP_POST_VARS["extent"]);<BR><BR><BR>$extent_to_set[0] =3D=20
29.057;<BR>$extent_to_set[1] =3D 40.954;<BR>$extent_to_set[2] =3D=20
29.143;<BR>$extent_to_set[3] =3D 40.999;<BR><BR><BR> =20
$myMap->setextent($extent_to_set[0],$extent_to_set[1],<BR> =
nbsp; =20
$extent_to_set[2],$extent_to_set[3]);<BR><BR> &nbs=
p;=20
$my_point =3D ms_newpointObj();<BR> =20
$my_point->setXY($HTTP_POST_VARS["mapa_x"],$HTTP_POST_VARS["mapa_y"]);=
<BR><BR> =20
$my_extent =3D =
ms_newrectObj();<BR><BR> =20
$my_extent->setextent($extent_to_set[0],$extent_to_set[1],<BR> &n=
bsp; &nb=
sp; &nbs=
p; =20
p;=20
$zoom_factor =3D=20
$HTTP_POST_VARS["zoom"]*$HTTP_POST_VARS["zsize"];<BR> &n=
bsp; =20
if ($zoom_factor =3D=3D 0)=20
{<BR> &n=
bsp; =20
$zoom_factor =3D=20
1;<BR> &=
nbsp; =20
$check_pan =3D=20
"CHECKED";<BR>  =
; =20
$check_zout =3D=20
"";<BR> =
=20
$check_zin =3D "";<BR> } else if =
($zoom_factor=20
< 0)=20
{<BR> &n=
bsp; =20
$check_pan =3D=20
"";<BR> =
=20
$check_zout =3D=20
"CHECKED";<BR>  =
; =20
$check_zin =3D "";<BR> } else=20
{<BR> &n=
bsp; =20
$check_pan =3D=20
"";<BR> =
=20
$check_zout =3D=20
"";<BR> =
=20
$check_zin =3D "CHECKED";<BR> =20
}<BR><BR> $val_zsize =3D=20
abs($zoom_factor);<BR><BR> =20
$myMap->zoompoint($zoom_factor,$my_point,$myMap->width,$myMap->h=
eight,<BR> &nb=
sp; =20
$my_extent);<BR><BR>}<BR>$img =3D $myMap->draw();<BR>$image_url =
=3D=20
$img->saveWebImage(GIF,1,1,0);<BR><BR>?><BR><BODY><BR><cen=
ter><BR><table=20
border=3D0 cellspacing=3D0 cellpadding=3D4=20
bgcolor=3D"#FFFFFF"><BR><tr><BR><td valign=3D"top"=20
align=3Dcenter><BR> <table cellpadding=3D"0" =
cellspacing=3D"5"=20
border=3D"5"><BR> <tr><td=20
SRC=3D"<?php=20
echo<BR>$image_url; ?>" width=3D600 height=3D600=20
border=3D0></td></tr><BR> =20
<tr><BR> <TR><BR> =20
<TD><BR>  =
; =20
Pan<BR> =20
</TD><BR> =20
<TD><BR>  =
; =20
<INPUT TYPE=3DRADIO NAME=3D"zoom" VALUE=3D0 <?php echo=20
$check_pan?>><BR> =20
</TD><BR> </TR><BR> <TR><BR>  =
; =20
<TD><BR>  =
; =20
Zoom In<BR> =20
</TD><BR> =20
<TD><BR>  =
; =20
<INPUT TYPE=3DRADIO NAME=3D"zoom" VALUE=3D1 <?php echo=20
$check_zin?>><BR> =20
; =20
<TD><BR>  =
; =20
Zoom Out<BR> =20
</TD><BR> =20
<TD><BR>  =
; =20
<INPUT TYPE=3DRADIO NAME=3D"zoom" VALUE=3D-1 <?php=20
echo<BR>$check_zout?>><BR> =20
; =20
<TD><BR>  =
; =20
Zoom Size<BR> =20
</TD><BR> =20
<TD><BR>  =
; =20
<INPUT TYPE=3DTEXT NAME=3D"zsize" VALUE=3D"<?php echo=20
$val_zsize?>"<BR>  =
; =20
SIZE=3D2><BR> =20
; =20
<TD><BR>  =
; =20
Full Extent<BR> =20
</TD><BR> =20
<TD><BR>  =
; =20
<INPUT TYPE=3DSUBMIT NAME=3D"full"=20
VALUE=3D"Go"<BR> &nb=
sp; =20
SIZE=3D2><BR> =20
</TD><BR></TABLE><BR><INPUT TYPE=3DHIDDEN =
NAME=3D"extent"=20
$extent_to_html?>"><BR></FORM><BR></CENTER><BR><BR><=
/BODY><BR></HTML><BR><BR><BR>current=20
map file:<BR><BR>#<BR># Start of map file<BR>#<BR>NAME =
ERENKOY<BR>STATUS=20
ON<BR>SIZE 600 600<BR>EXTENT 29.057 40.954 29.143 40.999<BR>UNITS=20
DD<BR>SHAPEPATH "/var/www/html/mapserver/itasca/"<BR>IMAGECOLOR 255 =
255=20
255<BR><BR>#OUTPUTFORMAT<BR># NAME PNG<BR># DRIVER=20
"GD/PNG"<BR># MIMETYPE "image/png"<BR># IMAGEMODE=20
PC256<BR># EXTENSION "png"<BR>#END<BR><BR>IMAGETYPE=20
GIF<BR><BR><BR>WEB<BR> MINSCALE 1000<BR> MAXSCALE=20
1550000<BR> IMAGEPATH =
"/var/www/html/mapserver/tmp3/"<BR> =20
IMAGEURL "/mapserver/tmp3/"<BR> END<BR><BR><BR>SYMBOL<BR> =
NAME=20
'circle'<BR> TYPE ELLIPSE<BR> POINTS 1 1 END<BR> =
FILLED=20
TRUE<BR>END<BR><BR><BR>LAYER<BR> NAME=20
'ERENKOY_ORNEKILCE_PG_region'<BR> TYPE polygon<BR> =
STATUS=20
DEFAULT<BR> DATA ERENKOY_ORNEKILCE_PG_region<BR><BR> =
CLASSITEM=20
'ID'<BR> CLASS<BR> EXPRESSION=20
'3'<BR> OUTLINECOLOR 128 128 =
128<BR> =20
COLOR 225 225 185<BR> END<BR> =
CLASS<BR> =20
EXPRESSION /./<BR> OUTLINECOLOR 128 128=20
128<BR> COLOR 255 255 255<BR> =20
END<BR>END<BR><BR>LAYER<BR> NAME=20
ERENKOY_ORNEKMAHALLE_PG_region<BR> GROUP cities<BR> TYPE =
polygon<BR> DATA ERENKOY_ORNEKMAHALLE_PG_region<BR> =
STATUS=20
ON<BR> CLASSITEM=20
'ID'<BR> CLASS<BR> =
EXPRESSION=20
/./<BR>COLOR 255 225 =
185<BR> =20
OUTLINECOLOR 0 0 0<BR><BR> =
END<BR><BR><BR>END<BR><BR>LAYER<BR> =20
NAME 'target2'<BR> TYPE point<BR> DATA target2<BR> =
STATUS=20
ON<BR> CLASS<BR> SYMBOL=20
'circle'<BR> COLOR 255 255 0<BR> =
SIZE=20
20<BR> =
LABEL<BR> COLOR=20
0 0 0<BR> END<BR> =20
END<BR><BR><BR>END<BR><BR>LAYER<BR> NAME 'target1'<BR> =
TYPE=20
point<BR> DATA target1<BR> STATUS ON<BR> =20
CLASS<BR> SYMBOL 'circle'<BR> =
COLOR 255=20
0 0<BR> SIZE 4<BR> =20
LABEL<BR> COLOR 0 0=20
0<BR> END<BR> =20
END<BR><BR><BR>END<BR><BR>END # end of map=20
file<BR><BR><BR></DIV></BLOCKQUOTE></BLOCKQUOTE></FONT></BODY></HTML>
------=_NextPart_000_009B_01C3A44F.2B920F70--
