RES: [Mapserver-users] Re: Mapserver-users digest, Vol 1 #335 - 41 msgs
Murilo Lacerda Yoshida
murilo.yoshida at agx.com.br
Fri Nov 7 12:51:23 EST 2003
Emilio,
I found the problem ... I found it on the bug 370 of the bugzilla in the
mapserver page. It says that there was a problem with libpng and
libpdf...
Now it is working. Thaks for the help,
Murilo
-----Mensagem original-----
De: Emilio Mayorga [mailto:emiliom at u.washington.edu]
Enviada em: sexta-feira, 7 de novembro de 2003 04:24
Para: mapserver-users at lists.gis.umn.edu
Assunto: [Mapserver-users] Re: Mapserver-users digest, Vol 1 #335 - 41
msgs
Murilo,
I'm not a Mapserver expert at all. I just started using it. Other people
in this list can give you more intelligent advice.
Did you say you're using RedHat 8? That's what I have. When I compiled
GDAL, it was installed under /usr/local by default. In the mapserver
configure options, I didn't specify a path for gdal, like you're doing;
I just used "--with-gdal", and that worked, mapserver was able to find
it. I don't know much about libtiff and libgeotiff, but I don't see why
you'd need to use them in mapserver and GDAL if GDAL can use its own
libraries. It's one thing to have libtiff and libgeotiff in your linux
install to use with other tools, but with mapserver, GDAL seems to do
the trick pretty nicely. I would try compiling GDAL like I did:
--with-libtiff=internal
--with-geotiff=internal
I really can't help beyond that, I'm just a beginner. Good luck!
-Emilio
From: "Murilo Lacerda Yoshida" <murilo.yoshida at agx.com.br>
To: <mapserver-users at lists.gis.umn.edu>
Subject: RES: [Mapserver-users] problem displaying raster layers; GDAL?
Date: Thu, 6 Nov 2003 01:08:34 -0200
Olá Emilio,
Yes, I'm using libtiff and libgeotiff, but I guess that this isn't the
problem here. Unless I cannot use gdal and libtiff and libgeotiff at the
same time, but I think that's not the case.
Here are my configure strings:
For mapserver
./configure --without-tiff --without-eppl --without-jpeg --with-threads
--with-proj --with-gdal=/usr/local/bin/gdal-config
--with-php=../php-4.3.3 --with-gd=/usr/local --with-freetype=/usr/bin
--with-pdf --with-ogr --with-ming --with-wmsclient --with-wfs
--with-wfs-client
For PHP
./configure --enable-force-cgi-redirect
--with-config-file-path=/etc/httpd/ --with-gd=/usr/local
--with-jpeg-dir=/usr --with-png-dir=/usr --with-zlib
--with-freetype-dir=/usr --without-ttf --with-pdflib --with-mysql
--with-regex=system --with-ming --enable-dbase --enable-dbx
--enable-versioning --with-oci8 --enable-shared
--with-config-file-path=/usr/local/php433/ --prefix=/usr/local/php433
For gdal
./configure --with-libz --with-png --with-libtiff=/usr/local
--with-geotiff=/usr/local --with-jpeg --without-jasper --without-python
And I changed the mapserver configure string to --without-tiff after
I
read your message, but nothing changed ...
Thanks,
Murilo
Enviada em: quinta-feira, 6 de novembro de 2003 00:09
Assunto: RES: [Mapserver-users] problem displaying raster layers; GDAL?
Oi Murilo,
What I did is exactly what I mentioned in my message, I added
--without-tiff to the configure line. Here is my complete mapserver
configuration line:
./configure --with-gd --with-proj --with-gdal --with-ogr --without-tiff
--with-wmsclient --with-threads --enable-runpath --enable-debug
I ran a make clean before doing that, to clean up the previous make
file; I'm no expert installing programs on Linux, so it took me some
effort to figure that out!
Here's the GDAL configuration line (I'm using GDAL 1.1.9):
./configure --with-libz --with-png --with-libtiff=internal
--with-geotiff=internal --with-jpeg --without-jasper
From a previous message you posted, it looks like you're trying to use
libtiff and libgeotiff, not GDAL. I think the --without-tiff mapserver
option specifies NOT to use other tiff libraries (--with-gdal tells it
to use GDAL, obviously), and the --with-libtiff=internal and
--with-geotiff=internal in the GDAL configuration tell GDAL to use its
own tiff/geotiff libraries. Could that be the problem?
Boa sorte!
-Emilio
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
