[Mapserver-users] GDAL/libgeotiff configure problem on Solaris 2.8/gcc 3.3
richard.roger at agric.nsw.gov.au
Mon Nov 10 01:28:52 EST 2003
This is a multipart message in MIME format.
--=_alternative 00239949CA256DDA_=
Content-Type: text/plain; charset="us-ascii"
I have built mapserver-4.0.1 successfully (but with some trouble) on
Solaris 2.8 using gcc 3.3.
I had already successfully built and installed libgd-2.0.15, libjpeg,
libpng-1.2.5, libtiff-3.6.0, libgeotiff-1.2.1, libgdal-1.1.9,
libcurl-7.10.8 but I got a "configure" error related to using gdal / ogr,
caused by a dependence on libgeotiff.
[I have not managed to include xercesc support in GDAL, but use GDAL for
its OGR library. When I installed the built GDAL libraries, they went
into the install directory as "gdal.a", "ogr.a", "ogrsf_frmts.a", and
"libgdal.1.1.so". Under Solaris, should the first three all be prefixed
with "lib", please? ]
On running ./configure in my Mapserver directory (with appropriate
options), I got this error.
configure:4664: checking whether we should include OGR support...
configure:4724: checking for OGRRegisterAll in -lgdal.1.1
configure:4743: gcc -o conftest -g -O2 conftest.c -lgdal.1.1 -lm
-lstdc++ -L/riu/links/local/lib -lgdal.1.1 1>&5
Undefined first referenced
symbol in file
__eprintf /riu/links/local/lib/libgeotiff.so
ld: fatal: Symbol referencing errors. No output written to conftest
collect2: ld returned 1 exit status
configure: failed program was:
#line 4732 "configure"
#include "confdefs.h"
/* Override any gcc2 internal prototype to avoid an error. */
/* We use char because int might match the return type of a gcc2
builtin and then its argument prototype would still apply. */
char OGRRegisterAll();
int main() {
OGRRegisterAll()
; return 0; }
I isolated the "conftest.c" program
int main() {
OGRRegisterAll()
; return 0; }
and built it with the "gcc" command above. It failed, of course.
The build failed, too, with the simpler command :
gcc -o conftest conftest.c -lgdal.1.1
but it succeeded with
gcc -o conftest conftest.c -lgdal.1.1 -lgeotiff
The "-lgdal.1.1" is essentially the library switch that is reported by the
installed "gdal-config".
I'm not sure whether this error is because "configure" is not correctly
set up, or whether this is to do with the dependence of "gdal" on
libtiff/libgeotiff, or a mistake on my part.
I have worked around this problem by changing line 4721 of "configure"
from
LIBS="$LIBS `$GDAL_CONFIG --libs`"
to
LIBS="$LIBS `$GDAL_CONFIG --libs` -lgeotiff"
"configure" now runs to completion, and builds a "Makefile" which works.
I hope this information might be of use to others. Any ideas for a
permanent fix to "configure" would be welcomed, I'm sure.
Regards
Richard E. Roger
Dr. R. E. Roger NSW Agriculture
Spatial Information Officer Systems 161 Kite St
Resource Information Unit Locked Bag 21
ORANGE NSW 2800
Australia
ph: +61 2 6391 3697 fax: +61 2 6391 3740
This message is intended for the addressee named and may contain
confidential information. If you are not the intended recipient or
received it in error, please delete the message and notify sender. Views
expressed are those of the individual sender and are not necessarily the
views of their organisation.
Content-Type: text/html; charset="us-ascii"
<br><font size=2 face="sans-serif">I have built mapserver-4.0.1 successfully (but with some trouble) on Solaris 2.8 using gcc 3.3.</font>
<br>
<br><font size=2 face="sans-serif">I had already successfully built and installed libgd-2.0.15, libjpeg, libpng-1.2.5, libtiff-3.6.0, libgeotiff-1.2.1, libgdal-1.1.9, libcurl-7.10.8 but I got a "configure" error related to using gdal / ogr, caused by a dependence on libgeotiff.</font>
<br>
<br><font size=2 face="sans-serif">[I have not managed to include xercesc support in GDAL, but use GDAL for its OGR library. When I installed the built GDAL libraries, they went into the install directory as "gdal.a", "ogr.a", "ogrsf_frmts.a", and "libgdal.1.1.so". Under Solaris, should the first three all be prefixed with "lib", please? ]</font>
<br>
<br><font size=2 face="sans-serif">On running ./configure in my Mapserver directory (with appropriate options), I got this error.</font>
<br>
<br><font size=2 face="Courier">configure:4664: checking whether we should include OGR support...</font>
<br><font size=2 face="Courier">configure:4724: checking for OGRRegisterAll in -lgdal.1.1</font>
<br><font size=2 face="Courier">configure:4743: gcc -o conftest -g -O2 conftest.c -lgdal.1.1 -lm -lstdc++ -L/riu/links/local/lib -lgdal.1.1 1>&5</font>
<br><font size=2 face="Courier">Undefined first referenced</font>
<br><font size=2 face="Courier"> symbol in file</font>
<br><font size=2 face="Courier">__eprintf /riu/links/local/lib/libgeotiff.so</font>
<br><font size=2 face="Courier">ld: fatal: Symbol referencing errors. No output written to conftest</font>
<br><font size=2 face="Courier">collect2: ld returned 1 exit status</font>
<br><font size=2 face="Courier">configure: failed program was:</font>
<br><font size=2 face="Courier">#line 4732 "configure"</font>
<br><font size=2 face="Courier">#include "confdefs.h"</font>
<br><font size=2 face="Courier">/* Override any gcc2 internal prototype to avoid an error. */</font>
<br><font size=2 face="Courier">/* We use char because int might match the return type of a gcc2</font>
<br><font size=2 face="Courier"> builtin and then its argument prototype would still apply. */</font>
<br><font size=2 face="Courier">char OGRRegisterAll();</font>
<br>
<br><font size=2 face="Courier">int main() {</font>
<br><font size=2 face="Courier">OGRRegisterAll()</font>
<br><font size=2 face="Courier">; return 0; }</font>
<br>
<br><font size=2 face="sans-serif">I isolated the "conftest.c" program</font>
<br>
<br>
<br><font size=2 face="sans-serif">and built it with the "gcc" command above. It failed, of course.</font>
<br>
<br><font size=2 face="sans-serif">The build failed, too, with the simpler command :</font>
<br>
<br><font size=2 face="Courier">gcc -o conftest conftest.c -lgdal.1.1</font>
<br>
<br><font size=2 face="sans-serif">but it succeeded with</font>
<br>
<br><font size=2 face="Courier">gcc -o conftest conftest.c -lgdal.1.1 -lgeotiff</font>
<br>
<br><font size=2 face="sans-serif">The "-lgdal.1.1" is essentially the library switch that is reported by the installed "gdal-config".</font>
<br>
<br><font size=2 face="sans-serif">I'm not sure whether this error is because "configure" is not correctly set up, or whether this is to do with the dependence of "gdal" on libtiff/libgeotiff, or a mistake on my part.</font>
<br>
<br><font size=2 face="sans-serif">I have worked around this problem by changing line 4721 of "configure" from</font>
<br>
<br><font size=2 face="Courier">LIBS="$LIBS `$GDAL_CONFIG --libs`"</font>
<br>
<br><font size=2 face="sans-serif">to</font>
<br>
<br><font size=2 face="Courier">LIBS="$LIBS `$GDAL_CONFIG --libs` -lgeotiff"</font>
<br>
<br><font size=2 face="sans-serif">"configure" now runs to completion, and builds a "Makefile" which works. </font>
<br>
<br><font size=2 face="sans-serif">I hope this information might be of use to others. Any ideas for a permanent fix to "configure" would be welcomed, I'm sure.</font>
<br>
<br><font size=2 face="sans-serif">Regards</font>
<br>
<br><font size=2 face="sans-serif">Richard E. Roger</font>
<br>
<br><font size=2 face="sans-serif">Dr. R. E. Roger NSW Agriculture<br>
Spatial Information Officer Systems 161 Kite St<br>
Resource Information Unit Locked Bag 21<br>
ORANGE NSW 2800</font>
<br><font size=2 face="sans-serif"> Australia<br>
ph: +61 2 6391 3697 fax: +61 2 6391 3740<br>
<br>
This message is intended for the addressee named and may contain confidential information. If you are not the intended recipient or received it in error, please delete the message and notify sender. Views expressed are those of the individual sender and are not necessarily the views of their organisation.</font>
--=_alternative 00239949CA256DDA_=--
