[Mapserver-users] TrueType fonts problem -- help needed
Frieso ter Haseborg
ter-haseborg at sf-datentechnik.de
Mon Nov 10 11:15:09 EST 2003
try to add the following line
>$img = $myMap->draw();
$myMap->drawLabelCache ( $img ); // <=!!! new line
>$image_url = $img->saveWebImage(GIF,1,1,0);
HTH,
Frieso
>-----Original Message-----
>From: Murat Isik [mailto:muratisik at megatek.com.tr]
>Sent: Monday, November 10, 2003 3:50 PM
>To: Frieso ter Haseborg
>Cc: mapserver-users at lists.gis.umn.edu
>Subject: Re: [Mapserver-users] TrueType fonts problem -- help needed
>Thank you for answering:) I cant thank you enough....
>I have again forgotten to cc to the list, but now I will do
>it. I am sorry.
>I dont know how to use drawLableCache, since I am both a php-newbei and
>mapscript-newbei at the same time (it is killing me...)
>I hope it is ok for you, I am pasting my whole code. It can read mysql
>coordinates and print points acordingly, zoom, pan and
>navigate the map. I
>hope this code can help some other newbeier-than-me newbei someday...
>ERENKOY_ORNEKSOKAK_PL_polyline is my streets layer.
>php code:
><HEAD>
><TITLE>MEGATEK</TITLE>
></HEAD>
><CENTER>
><FORM METHOD=POST ACTION=<?php echo $PHP_SELF?>>
><H1>TEST SERVER</H1>
><IMG SRC="yeni_ust.gif">
><P>
><?php
>dl("php_mapscript.so");
>mysql_connect("localhost","root","sqlpass") or
> die ("Could not connect to database");
>mysql_select_db("pointtrack") or
> die("Could not select database");
>$val_zsize=3;
>//$check_pan="CHECKED";
>$shpFname = "target1";
>$shpFile = ms_newShapeFileObj($shpFname, MS_SHP_POINT);
>$shpFname1 = "target2";
>$shpFile1 = ms_newShapeFileObj($shpFname1, MS_SHP_POINT);
>$pt = ms_newPointObj();
>$i = 0;
>$result = mysql_query("select * from track4") or
> die (mysql_error());
>$x[0]=0;
>$y[0]=0;
>while ($row = mysql_fetch_array($result))
>++$i;
>$test_x[$i] = $row["lodegrees"]+$row["lominutes"]/60;
>$test_y[$i] = $row["ldegrees"]+$row["lminutes"]/60;
>if($test_x[$i]==$x[$i-1] || $test_y[$i]==$y[$i-1])
>--$i;
>}else
>$x[$i] = $test_x[$i];
>$y[$i] = $test_y[$i];
>mysql_free_result($result);
>for($k=1;$k<=$i-1;++$k)
>$pt->setXY($x[$k], $y[$k]);
>$shpFile->addPoint($pt);
>$pt->setXY($x[$i], $y[$i]);
>$shpFile1->addPoint($pt);
>$shpFile->free();
>$shpFile1->free();
>$def =array(array("UNIQID", "C", 13),array("NOM", "C", 128));
>$dbfFile = dbase_create($shpFname.".dbf", $def);
>dbase_add_record($dbfFile, array("1","TEST"));
>$dbfFile = dbase_create($shpFname1.".dbf", $def);
>$myMap = ms_newMapObj("demo_try.map");
>//$myLayer = $myMap->getLayerByName("target1");
>//$myLayer->set("data", $shpFname);
>//$myLayer->set('status', MS_ON);
>if ( isset($HTTP_POST_VARS["mapa_x"]) &&
>isset($HTTP_POST_VARS["mapa_y"])
> && !isset($HTTP_POST_VARS["full"]) ) {
>$extent_to_set = explode(" ",$HTTP_POST_VARS["extent"]);
>$myMap->setextent($extent_to_set[0],$extent_to_set[1],$extent_t
>o_set[2],$ex
>tent_to_set[3]);
> $my_point = ms_newpointObj();
>$my_point->setXY($HTTP_POST_VARS["mapa_x"],$HTTP_POST_VARS["mapa_y"]);
> $my_extent = ms_newrectObj();
> $my_extent->setextent($extent_to_set[0],$extent_to_set[1],
> $extent_to_set[2],$extent_to_set[3]);
>$zoom_factor = $HTTP_POST_VARS["zoom"]*$HTTP_POST_VARS["zsize"];
> if ($zoom_factor == 0) {
> $zoom_factor = 1;
> $check_pan = "CHECKED";
> $check_zout = "";
> $check_zin = "";
> $check_right = "";
> $check_left = "";
> } else if ($zoom_factor < 0) {
> $check_pan = "";
> $check_zout = "CHECKED";
> $check_zin = "";
> $check_right = "";
> $check_left = "";
> } else {
> $check_pan = "";
> $check_zout = "";
> $check_zin = "CHECKED";
> $check_right = "";
> $check_left = "";
> $val_zsize = abs($zoom_factor);
>$myMap->zoompoint($zoom_factor,$my_point,$myMap->width,$myMap->height,
> $my_extent);
>if($HTTP_POST_VARS["zoom"] == 2)
> $xmin = $extent_to_set[0];
> $xmax = $extent_to_set[2];
> $ymin = $extent_to_set[1];
> $ymax = $extent_to_set[3];
> $xinc = ($xmax - $xmin ) / 2;
> $myMap->setextent( ($xmin + 0.01), $ymin, ($xmax +
>0.01), $ymax);
> $check_pan = "";
> $check_zout = "";
> $check_zin = "";
> $check_right = "CHECKED";
> $check_left = "";
>if($HTTP_POST_VARS["zoom"] == 3)
> $myMap->setextent( ($xmin - 0.01), $ymin, ($xmax -
>0.01), $ymax);
> $check_pan = "";
> $check_zout = "";
> $check_zin = "";
> $check_right = "";
> $check_left = "CHECKED";
>if($HTTP_POST_VARS["zoom"] == 4)
> $myMap->setextent( $xmin, ($ymin - 0.01), $xmax,
>($ymax - 0.01));
> $check_pan = "";
> $check_zout = "";
> $check_zin = "";
> $check_right = "";
> $check_left = "";
> $check_up = "CHECKED";
> $check_down = "";
>if($HTTP_POST_VARS["zoom"] == 5)
> $myMap->setextent( $xmin, ($ymin + 0.01), $xmax,
>($ymax + 0.01));
> $check_pan = "";
> $check_zout = "";
> $check_zin = "";
> $check_right = "";
> $check_left = "";
> $check_up = "";
> $check_down = "CHECKED";
>$extent_to_html = $myMap->extent->minx." ".$myMap->extent->miny." "
> .$myMap->extent->maxx." ".$myMap->extent->maxy;
><BODY>
><center>
><table border=0 cellspacing=0 cellpadding=4 bgcolor="#FFFFFF">
><tr>
><td valign="top" align=center>
> <table cellpadding="0" cellspacing="5" border="5">
> <tr><td colspan="2"><INPUT NAME="mapa" TYPE="image" SRC="<?php echo
>$image_url; ?>" width=600 height=600 border=0></td></tr>
> <tr>
> <TR>
> <TD>
> Pan
> </TD>
> <TD>
> <INPUT TYPE=RADIO NAME="zoom" VALUE=0 <?php echo
>$check_pan?>>
> </TD>
> </TR>
> <TR>
> <TD>
> Zoom In
> </TD>
> <TD>
> <INPUT TYPE=RADIO NAME="zoom" VALUE=1 <?php echo
>$check_zin?>>
> </TD>
> </TR>
> <TR>
> <TD>
> Zoom Out
> </TD>
> <TD>
> <INPUT TYPE=RADIO NAME="zoom" VALUE=-1 <?php echo
>$check_zout?>>
> </TD>
> </TR>
> <TR>
> <TD>
> Right
> </TD>
> <TD>
> <INPUT TYPE=RADIO NAME="zoom" VALUE=2 <?php echo
>$check_right?>>
> </TD>
> </TR>
> <TR>
> <TD>
> Left
> </TD>
> <TD>
> <INPUT TYPE=RADIO NAME="zoom" VALUE=3 <?php echo
>$check_left?>>
> </TD>
> </TR>
> <TR>
> <TD>
> Up
> </TD>
> <TD>
> <INPUT TYPE=RADIO NAME="zoom" VALUE=4 <?php echo
>$check_up?>>
> </TD>
> </TR>
> <TR>
> <TD>
> Down
> </TD>
> <TD>
> <INPUT TYPE=RADIO NAME="zoom" VALUE=5 <?php echo
>$check_down?>>
> </TD>
> </TR>
> <TR>
> <TD>
> Zoom Size
> </TD>
> <TD>
> <INPUT TYPE=TEXT NAME="zsize" VALUE="<?php echo
>$val_zsize?>"
> SIZE=2>
> </TD>
> </TR>
> <TR>
> <TD>
> Full Extent
> </TD>
> <TD>
> <INPUT TYPE=SUBMIT NAME="full" VALUE="Go"
> SIZE=2>
> </TD>
></TABLE>
><INPUT TYPE=HIDDEN NAME="extent" VALUE="<?php echo $extent_to_html?>">
></FORM>
></CENTER>
></BODY>
></HTML>
>map file at the moment: (the one I use for mapscript)
># Start of map file
>NAME ERENKOY
>STATUS ON
>SIZE 600 600
>EXTENT 29.057 40.954 29.143 40.999
>UNITS DD
>SHAPEPATH "/var/www/html/mapserver/itasca/"
>IMAGECOLOR 255 255 255
>FONTSET font.list
>#OUTPUTFORMAT
># NAME PNG
># DRIVER "GD/PNG"
># MIMETYPE "image/png"
># IMAGEMODE PC256
># EXTENSION "png"
>#END
>IMAGETYPE GIF
>WEB
> MINSCALE 1000
> MAXSCALE 1550000
> IMAGEPATH "/var/www/html/mapserver/tmp3/"
> IMAGEURL "/mapserver/tmp3/"
> END
>SYMBOL
> NAME 'circle'
> TYPE ELLIPSE
> POINTS 1 1 END
> FILLED TRUE
>END
>LAYER
> NAME 'ERENKOY_ORNEKILCE_PG_region'
> TYPE polygon
> STATUS DEFAULT
> DATA ERENKOY_ORNEKILCE_PG_region
> CLASSITEM 'ID'
> CLASS
> EXPRESSION '3'
> OUTLINECOLOR 128 128 128
> COLOR 225 225 185
> END
> CLASS
> EXPRESSION /./
> COLOR 255 255 255
> END
>END
>#LAYER
># NAME ERENKOY_ORNEKMAHALLE_PG_region
># GROUP cities
># TYPE polygon
># DATA ERENKOY_ORNEKMAHALLE_PG_region
># STATUS ON
># CLASSITEM 'ID'
># CLASS
># EXPRESSION /./
># EXPRESSION /./
># COLOR 255 225 185
># OUTLINECOLOR 0 0 0
># END
>#END
>#LAYER
># NAME ERENKOY_ORNEKSOKAK_PL_polyline
># GROUP sokaklar
># TYPE line
># DATA ERENKOY_ORNEKSOKAK_PL_polyline
># STATUS ON
># CLASSITEM 'ID'
># CLASS
># EXPRESSION /./
># COLOR 66 34 249
># END
>#END
>LAYER
> TYPE line
> GROUP sokaklar
> STATUS ON
>CLASSITEM 'ID'
> CLASS
> EXPRESSION /./
> COLOR 66 34 249
> END
>#LABELCACHE on
>LABELITEM 'ADI'
> CLASS
> NAME 'ADI'
>EXPRESSION /./
> COLOR 161 02 110
> LABEL
> TYPE truetype
># FORCE true
> FONT arial
> COLOR 0 0 0
> ANGLE AUTO
> BACKGROUNDCOLOR 250 250 250 #WIT
> POSITION AUTO
> SIZE 0
> MINSIZE 2
> SIZE 8
> END
> END
>END
>LAYER
> NAME ERENKOY_ORNEKOTOBAN_PL_polyline
> GROUP otoban
> TYPE line
> DATA ERENKOY_ORNEKOTOBAN_PL_polyline
> STATUS OFF
> CLASSITEM 'ID'
> CLASS
> EXPRESSION /./
> COLOR 66 34 249
> END
>END
>LAYER
> NAME ERENKOY_ORNEKCADDE_PL_polyline
> GROUP otoban
> TYPE line
> DATA ERENKOY_ORNEKCADDE_PL_polyline
> STATUS OFF
> CLASSITEM 'ID'
> CLASS
> EXPRESSION /./
> COLOR 66 34 249
> END
>END
>LAYER
> NAME ERENKOY_ORNEKBULVAR_PL_polyline
> GROUP otoban
> TYPE line
> DATA ERENKOY_ORNEKBULVAR_PL_polyline
> STATUS OFF
> CLASSITEM 'ID'
> CLASS
> EXPRESSION /./
> COLOR 66 34 249
> END
>END
>LAYER
> NAME ERENKOY_ORNEKKAVSAK2_PL_polyline
> GROUP otoban
> TYPE line
> DATA ERENKOY_ORNEKKAVSAK2_PL_polyline
> STATUS OFF
> CLASSITEM 'ID'
> CLASS
> EXPRESSION /./
> COLOR 66 34 249
> END
>END
>LAYER
> NAME ERENKOY_ORNEKKAVSAK_PL_polyline
> GROUP otoban
> TYPE line
> DATA ERENKOY_ORNEKKAVSAK_PL_polyline
> STATUS OFF
> CLASSITEM 'ID'
> CLASS
> EXPRESSION /./
> COLOR 66 34 249
> END
>END
>LAYER
> NAME ERENKOY_ORNEKDENIZ_PG_region
> GROUP otoban
> TYPE polygon
> DATA ERENKOY_ORNEKDENIZ_PG_region
> STATUS OFF
> CLASSITEM 'ID'
> CLASS
> EXPRESSION /./
> COLOR 66 34 249
> END
>END
>LAYER
> NAME 'target2'
> TYPE point
> DATA target2
> STATUS ON
> CLASS
> SYMBOL 'circle'
> COLOR 255 255 0
> SIZE 20
> LABEL
> COLOR 0 0 0
> END
> END
>END
>LAYER
> NAME 'target1'
> TYPE point
> DATA target1
> STATUS ON
> CLASS
> SYMBOL 'circle'
> COLOR 255 0 0
> SIZE 4
> LABEL
> COLOR 0 0 0
> END
> END
>END
>END # end of map file
>----- Original Message -----
>From: "Frieso ter Haseborg" <ter-haseborg at sf-datentechnik.de>
>To: "Murat Isik" <muratisik at megatek.com.tr>
>Cc: <mapserver-users at lists.gis.umn.edu>
>Sent: Monday, November 10, 2003 4:38 PM
>Subject: RE: [Mapserver-users] TrueType fonts problem -- help needed
>> Hi,
>> there should be no difference between a mapfile for direct-use in MS
>> and a mapfile used with MS/mapscript. IMHO you should check
>your php for
>> the problem first (post the relevant part of the code too, if the
>> problem continues).
>> => Do you execute the drawLabelCache-method (e.g.
>map->drawLabelCache (
>> $image ))?
>> Don't forget the cc to the list!
>> HTH,
>> Frieso
>> >Sent: Monday, November 10, 2003 3:22 PM
>> >Thank you for your reply.
>> >after my last mail, I have started to play around with labelling and
>> >achieved good results with mapserver.
>> >However when I copy the related layer's part from mapserver
>map file to
>> >mapscripts mapfile, it first stopped rendering. then I added
>> >the CLASSITEM
>> >'ID' line and it started to produce image without labels. Can
>> >you please
>> >help me? I am stuck...
>> >original layer from mapscript mapfile:
>> >LAYER
>> > GROUP sokaklar
>> > TYPE line
>> > STATUS ON
>> > CLASSITEM 'ID'
>> > CLASS
>> > EXPRESSION /./
>> > COLOR 66 34 249
>> > END
>> >END
>> >instead of the above I copied this and labelling did not work:
>> >LAYER
>> > TYPE line
>> > GROUP sokaklar
>> > STATUS ON
>> >CLASSITEM 'ID'
>> > CLASS
>> > EXPRESSION /./
>> > COLOR 66 34 249
>> > END
>> >#LABELCACHE on
>> >LABELITEM 'ADI'
>> > CLASS
>> > NAME 'ADI'
>> > COLOR 161 02 110
>> > LABEL
>> > TYPE truetype
>> ># FORCE true
>> > FONT arial
>> > COLOR 0 0 0
>> > ANGLE AUTO
>> > POSITION AUTO
>> > SIZE 0
>> > MINSIZE 2
>> > SIZE 8
>> > END
>> > END
>> >Should I do something with the php part too?
>> >Have a nice day:)
>> >Murat Isik
>> >Sent: Monday, November 10, 2003 12:06 PM
>> >> Hi,
>> >> try to use an absolute path in your "fonts.list".
>> >> HTH,
>> >> Frieso ter Haseborg
>> >> - Software Development -
>> >> S&F Datentechnik GmbH&Co.KG
>> >> Reimersstr. 41b
>> >> 26789 Leer, Germany
>> >> Sent: Monday, November 10, 2003 10:27 AM
>> >> To: mapserver-users at lists.gis.umn.edu
>> >> Subject: [Mapserver-users] TrueType fonts problem -- help needed
>> >> Hello,
>> >> I am having a problem with TrueType fonts. This is the
>error I get:
>> >> msGetLabelSize(): TrueType Font error. Could not find/open font
>> >> And this is what I do to get this error:
>> >> I have these in my mapfile:
>> >> NAME ERENKOY
>> >> STATUS ON
>> >> SIZE 600 600
>> >> SHAPEPATH "data"
>> >> FONTSET font.list
>> >> and
>> >> LAYER
>> >> TYPE LINE
>> >> GROUP sokaklar
>> >> STATUS ON
>> >> LABELITEM "ADI"
>> >> CLASS
>> >> NAME "ADI"
>> >> COLOR 161 02 110
>> >> LABEL
>> >> TYPE truetype
>> >> FORCE true
>> >> FONT arial
>> >> COLOR 0 0 0
>> >> POSITION cc
>> >> SIZE 8
>> >> END
>> >> END
>> >> END
>> >> This ERENKOY_ORNEKSOKAK_PL_polyline layer's dbf file includes two
>> >> coloumns, ID and ADI (name). This is a street layer and I am
>> >trying to
>> >> get the name of the streets written next to their lines.
>> >> font.list include:
>> >> arial arial.ttf
>> >> arial-bold arialbd.ttf
>> >> arial-italic ariali.ttf
>> >> arial-bold-italic arialbi.ttf
>> >> I have all the related ttf files in the same directory as
>font.list
>> >> text, mapfile and the html page calling these fonts. However
>> >I get the
>> >> error. May it be that my mapserver is not truetype
>compiled? I must
>> >> admit that I installed mapserver and mapscript through
>rpms so I dont
>> >> know the trutype situation of my mapserver 3.6. If I can get this
>> >> labelling to work then I am going to use th same mapfile for
>> >a mapscript
>> >> page.
>> >> Have a nice day.
>> >> Murat Isik
