[Mapserver-users] Shapefile problem ...
    Murilo Lacerda Yoshida
    murilo.yoshida at agx.com.br
    Mon Nov 10 11:46:45 PST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0001_01C3A7B2.9C2BCF80
Content-Type: text/plain;
	charset="us-ascii"
Content-Transfer-Encoding: 7bit
  Hi all,
  I have this problem: I have an area, a farm, for example, that I have
to show on the page, using php and mapscript. But I have to divide this
farm into several tiles, and these tiles should be in the shapefile,
because I have data to display for each tile. And I wanted to specify
these tiles dynamically.
  Until now I was doing this shapefiles with maplab. But now I want to
do it this way. Can you guys help me? I was wondering if there is a
function in mapscript to do this, or a function in another library that
would help me do this.
  Thanks in advance,
     Murilo
Content-Type: text/html;
	charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3A7B2.9BF04D20">
<!--[if gte mso 9]><xml>
 <o:OfficeDocumentSettings>
  <o:DoNotRelyOnCSS/>
 </o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
 <w:WordDocument>
  <w:SpellingState>Clean</w:SpellingState>
  <w:GrammarState>Clean</w:GrammarState>
  <w:DocumentKind>DocumentEmail</w:DocumentKind>
  <w:HyphenationZone>21</w:HyphenationZone>
  <w:EnvelopeVis/>
  <w:Compatibility>
   <w:BreakWrappedTables/>
   <w:SnapToGridInCell/>
   <w:WrapTextWithPunct/>
   <w:UseAsianBreakRules/>
  </w:Compatibility>
  <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
 </w:WordDocument>
</xml><![endif]-->
<style>
 /* Style Definitions */
 p.MsoNormal, li.MsoNormal, div.MsoNormal
	{mso-style-parent:"";
	margin:0cm;
	margin-bottom:.0001pt;
	mso-pagination:widow-orphan;
	font-size:12.0pt;
	font-family:"Times New Roman";
	mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
	{color:blue;
	text-decoration:underline;
	text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
	{color:purple;
span.EstiloDeEmail17
	{mso-style-type:personal-compose;
	mso-style-noshow:yes;
	mso-ansi-font-size:10.0pt;
	mso-bidi-font-size:10.0pt;
	font-family:Arial;
	mso-ascii-font-family:Arial;
	mso-hansi-font-family:Arial;
	mso-bidi-font-family:Arial;
	color:windowtext;}
span.SpellE
	{mso-style-name:"";
	mso-spl-e:yes;}
@page Section1
	{size:612.0pt 792.0pt;
	margin:70.85pt 3.0cm 70.85pt 3.0cm;
	mso-header-margin:35.4pt;
	mso-footer-margin:35.4pt;
	mso-paper-source:0;}
div.Section1
	{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
 /* Style Definitions */=20
 table.MsoNormalTable
	{mso-style-name:"Tabela normal";
	mso-tstyle-rowband-size:0;
	mso-tstyle-colband-size:0;
	mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
	mso-para-margin:0cm;
	mso-para-margin-bottom:.0001pt;
	font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DPT-BR link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:35.4pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span lang=3DEN-US =
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'><span
style=3D'mso-spacerun:yes'>  </span>Hi =
all,<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>  </span>I have this problem: I have an =
area, a
farm, for example, that I have to show on the page, using <span =
class=3DSpellE>php</span>
and <span class=3DSpellE>mapscript</span>. But I have to divide this =
farm into
several tiles, and these tiles should be in the <span =
class=3DSpellE>shapefile</span>,
because I have data to display for each tile. And I wanted to specify =
these
tiles dynamically.<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>  </span>Until now I was doing this =
<span
class=3DSpellE>shapefiles</span> with <span =
class=3DSpellE>maplab</span>. But now I
want to do it this way. Can you guys help me? I was wondering if there =
is a
function in <span class=3DSpellE>mapscript</span> to do this, or a =
function in
another library that would help me do =
this…<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>  </span>Thanks in =
advance,<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'mso-spacerun:yes'>     =
</span>Murilo<o:p></o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_0001_01C3A7B2.9C2BCF80--
More information about the MapServer-users
