[Mapserver-users] link problem proj4 on VC7
Pericles S. Nacionales
nacional at cbs.umn.edu
Tue Nov 11 12:41:16 EST 2003
Please download and compile proj version 4.4.7.
-Perry
On Tue, 2003-11-11 at 06:04, Yvain Ballini wrote:
> Hello,
> I'm trying to compile Mapserver with Visual Studio 2003 (precisely
> VC7) on Windows 2000, and I've got everything except the Proj.4
> library. I've downloaded at
> ftp://ftp.remotesensing.org/pub/proj/proj-4.4.3.zip., like i'ts said
> it on the page
> http://mapserver.gis.umn.edu/doc40/win32_compile-howto.html.
> When I try to compile this library (proj4.lib), I' meet a linking
> problem that I can't explain. It gives me the following error:
> proj.obj : error LNK2022: metadata operation failed (8013118D) :
> Inconsistent layout information in duplicated types (PJconsts)
> I've controlled that the structure PJconsts is defined and declared
> only one time (in the header projects.h) and I don't find where is the
> problem.
> Do you know if there is some patch or these files to make the
> compilation without problem?
> Thank you very much for your help.
> Best regards.
> Yvain.
