[Mapserver-users] Raster layers are all gray
Dan Harris
coronadh at coronasolutions.com
Tue Nov 11 13:50:45 EST 2003
Thanks very much for your responses!
Yes, you're right. It is a Terraserver image. However, the original
world file was in UTM coordinates but everything else in my map is based
on DD. So I converted the coordinates in the world file to DD. When I
left them in UTM, the image didn't appear on the map anywhere, but after
converting to DD, I saw *something* at least! So I thought I was on the
right track.
So if I can't mix the two, how can I remedy this? The map file UNITS is
DD as are all my layers and points. Do I need to do something else to
the world file to tell it to register as DD or do I have to get a
different image from another source?
Thanks again for your help, I'm still a newbie with rasters.
-Dan
Ed McNierney wrote:
>Dan -
>Frank's right, and your map request almost certainly does not intersect the defined image. That's because your world file is wrong.
>This seems to be a Microsoft TerraServer image download. The first and fourth lines in the file seem to be plausible, if your data is 16 meters per pixel in UTM projection. But the last two lines are certainly not UTM coordinates and appear to be decimal degrees of latitude and longitude. You can't mix the two, and you need to correct your world file.
> - Ed
