[Mapserver-users] 4.0.1 compile problem with php 4.3.4
Prashanth Ram
pram at pramcentral.com
Wed Nov 12 10:58:31 EST 2003
--------------A385157232AE20973B22C0BF
Content-Type: text/plain; charset=us-ascii
Content-Transfer-Encoding: 7bit
Aaron:
I had the same problem w/php 4.3.3 and mapserver. I have 2
suggestions for u.
1) Remove config.cache, config.status from the php install
directory and recompile using these options:
PHP:: './configure' '--with-mysql' '--with-dbase'
'--with-gd=/home/mapserver/' '--with-regex=system' '--with-zlib'
'--with-expat' '--with-xml'
Mapserver: /configure --without-tiff
--with-proj=/home/mapserver/ --with-gdal=/home/mapserver/bin/gdal-config
--with-ogr=/home/mapserver/gdal-1.1.9 --with-jpeg --with-wmsclient
--with-freetype=/home/mapserver/ --with-gd=/home/mapserver/
--with-php=/usr/local/src/php-4.3.4/
--with-curl-config=/home/mapserver/bin/curl-config
--with-ming=/home/mapserver/ming-0.2a
I found out that the gd library specified with the php
configure HAS to be the SAME as the mapserv gd ..
2) This suggestion, I know will bring the wrath of a slew of ppl.
on the list... but here goes.. Do this ONLY TO TEST:
Mapserver: Edit ./configure and comment out the exit 1; ..
after the change it should look like this:
<code>
!!! and then re-configure and re-compile
MapServer. !!!" 1>&2
; # exit 1;
</code>
See if it complies.. and works correctly.. if it
does.. remove the comment, make clean, and recompile.. it worked for
me.. I think it has something to do w/caching, but I could be wrong.
Good luck..
-Prashanth
"Aaron D. Hunt" wrote:
> When I try to configure mapserver with php I get the error bellow
> about --with-regex=system when my php is configured with it. Am I
> missing something? I have php configured with './configure'
> '--with-mysql' '--with-dbase' '--with-gd' '--with-system-regex'
> '--with-zlib' '--with-expat' '--with-xml' mapserver configure
> with./configure --without-tiff --with-proj=/home/mapserver/
> --with-ming=/home/mapserver/ming-0.2a I get!!! The current version of
> PHP MapScript has some problems with !!!
> !!! PHP4's bundled regex. Until we figure the solution to the
> !!! problem, the workaround is to compile PHP4 with the system regex
> !!! Please re-configure and re-compile PHP4 with --with-regex=system
> !!! and then re-configure and re-compile MapServer.
> !!! Aaron D. Hunt
> Technical Manager
> ZedX Inc.
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
<body bgcolor="#FFFFFF">
Aaron:
<br> I had the same problem w/php 4.3.3 and mapserver.
I have 2 suggestions for u.
<br> 1) Remove config.cache,
config.status from the php install directory and recompile using these
options:
<br>
PHP:: './configure' '<font face="Arial"><font size=-1>--with-mysql' '--with-dbase'
'<b>--with-gd=/home/mapserver/'</b> <b>'--with-regex=system'</b> '--with-zlib'
'--with-expat' '--with-xml'</font></font>
<br>
Mapserver: <font face="Arial"><font size=-1>/configure --without-tiff --with-proj=/home/mapserver/
--with-gdal=/home/mapserver/bin/gdal-config --with-ogr=/home/mapserver/gdal-1.1.9
--with-jpeg --with-wmsclient --with-freetype=/home/mapserver/ --with-gd=/home/mapserver/
--with-php=/usr/local/src/php-4.3.4/ --with-curl-config=/home/mapserver/bin/curl-config
--with-ming=/home/mapserver/ming-0.2a</font></font>
<br><font face="Arial"><font size=-1> </font></font>
I found out that the gd library specified with the php configure HAS to
be the SAME as the mapserv gd ..</font></font>
<br><font face="Arial"><font size=-1></font></font> <font face="Arial"><font size=-1></font></font>
<p><font face="Arial"><font size=-1> 2) This
suggestion, I know will bring the wrath of a slew of ppl. on the list...
but here goes.. Do this ONLY TO TEST:</font></font>
Mapserver: Edit ./configure and comment out the <i>exit 1; .. </i>
after the change it should look like this:</font></font>
<code></font></font>
!!!" 1>&2</font></font>
; # exit 1;</font></font>
}</font></font>
</code></font></font>
See if it complies.. and works correctly.. if it does.. remove the comment,
make clean, and recompile.. it worked for me.. I think it has something
to do w/caching, but I could be wrong.</font></font><font face="Arial"><font size=-1></font></font>
<p><font face="Arial"><font size=-1>Good luck..</font></font>
<br><font face="Arial"><font size=-1>-Prashanth</font></font>
<p>"Aaron D. Hunt" wrote:
<blockquote TYPE=CITE><style></style>
<font face="Arial"><font size=-1>When
I try to configure mapserver with php I get the error bellow about --with-regex=system
when my php is configured with it. Am I missing something?</font></font> <font face="Arial"><font size=-1>I
have php configured with './configure' '--with-mysql' '--with-dbase' '--with-gd'
'--with-system-regex' '--with-zlib' '--with-expat' '--with-xml'</font></font> <font face="Arial"><font size=-1>mapserver
configure with</font></font><font face="Arial"><font size=-1>./configure
--without-tiff --with-proj=/home/mapserver/ --with-gdal=/home/mapserver/bin/gdal-config
--with-ogr=/home/mapserver/gdal-1.1.9 --with-jpeg --with-wmsclient --with-freetype=/home/mapserver/
--with-gd=/home/mapserver/ --with-php=/usr/local/src/php-4.3.4/ --with-curl-config=/home/mapserver/bin/curl-config
--with-ming=/home/mapserver/ming-0.2a</font></font> <font face="Arial"><font size=-1>I
get</font></font><font face="Arial"><font size=-1>!!! The current version
of PHP MapScript has some problems with
!!!</font></font>
<br><font face="Arial"><font size=-1>!!! PHP4's bundled regex. Until
!!!</font></font>
<br><font face="Arial"><font size=-1>!!! problem, the workaround is to
compile PHP4 with the system regex !!!</font></font>
<br><font face="Arial"><font size=-1>!!! Please re-configure and re-compile
PHP4 with --with-regex=system !!!</font></font>
<br><font face="Arial"><font size=-1>!!! and then re-configure and re-compile
MapServer.
!!!</font></font> <font face="Arial"><font size=-1>Aaron D.
Hunt</font></font>
<br><font face="Arial"><font size=-1>Technical Manager</font></font>
<br><font face="Arial"><font size=-1>ZedX Inc.</font></font></blockquote>
</body>
</html>
--------------A385157232AE20973B22C0BF--
