[Mapserver-users] Shape problems
Rodrigo Zanato Tripodi
rodrigotripodi at bol.com.br
Wed Nov 12 12:47:43 EST 2003
Hi Fernando,
Whatzup?
Maybe you found a bug at php mapscript.
file: mapscript_i.c
function: lineObj_add
code:
self->point[self->numpoints].x = p->x;
self->point[self->numpoints].y = p->y;
self->point[self->numpoints].m = p->m;
self->numpoints++;
With this, the last point is equal to the first.
Right?
It need to be disabled at MS_SHAPE_LINE?
[]'s
----- Original Message -----
To: <mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, November 12, 2003 10:33 AM
Subject: [Mapserver-users] Shape problems
> Dear list,
> I'm having difficulty to create line type shapefiles, the problems is
> the Mapserver closing the shape.
> The script closes the line, the first point with the last point of
> line. How can I fix this?
> I'm using this code to generate the shape:
> <?php
> set_time_limit(0);
> include_once( "dual/oci.inc" );
> dl( 'php_mapscript.so' );
> ociConectar(); //database conection
> function createShape($programId, $pname )
> GLOBAL $shpFile,$dbfFile;
> $query = "select x.* from hidrografia_sc h, table (SELECT
> h.COORDENADA.SDO_ORDINATES FROM hidrografia_sc h WHERE h.codigo_ott =
> 83851000) x"; //query
> ociExecutar($query); //execute query
> $oShp = ms_newShapeObj(MS_SHAPE_LINE);
> $oLine = ms_newLineObj();
> while (list($x) = ociTupla())
> list($y) = ociTupla();
> $point = ms_newPointObj();
> $point->setXY( $x, $y );
> $oLine->add($point);
> $oShp->add($oLine);
> $shpFile->addShape($oShp);
> dbase_add_record($dbfFile, array($programId, $pname ));
> $shpFname = "/home/apache/htdocs/tmp/pol";
> $shpFile = ms_newShapeFileObj( $shpFname, MS_SHP_ARC);
> $dbfFile =
dbase_create($shpFname.".dbf",array(array("ID","N",5,0),array("NAME","C",10)
> createShape(1,"River");
> echo "Shapes Created.<BR>";
> $shpFile->free();
> echo "Shape File ($shpFname) closed.<BR>";
> dbase_close($dbfFile);
> echo "Dbase file closed. <br>";
> ociEncerrar(); //close connection
> ociDesconectar();
> Fernando Simon
> simon at cttmar.univali.br
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
