[Mapserver-users] PostGIS fails with mapscript but not shp2img
Matthew Haines
mhaines94108 at hotmail.com
Sun Nov 16 09:39:53 EST 2003
I am just starting to experiment with PostGIS and have run into a problem I
can't solve. I started with a non-PostGIS map file that renders fine
whether called from mapscript or by shp2img. Then I modified it to take its
date from a database through PostGIS. It still renders with shp2img but
doesn't return an image when called from mapscript.
My system is as follows:
MapServer 4.0
PostGIS & PostgreSQL -- latest versions (downloaded yesterday)
Mandrake Linux 9.1
Apace web server
My perl/mapscript program is being invoked from Apache, and here is the code
that draws the maps:
my $map = new mapscript::mapObj($mapfile);
print "Map: $map<br>\n";
... [ set extent, height width]
my $img = $map->draw ();
print "Image: $img<br>\n";
my $return = mapscript::msSaveImage($map, $img, $imgfile);
print "Return: $return<br>\n";
Comparing the old map file to the new, I can see that the $map->draw()
method is returning NULL with the new map file.
I have checked the PostgreSQL log and get nothing there. The mapserver log
doesn't seem to capture mapscript errors. The apache logs aren't relevant
here. How can I debug something like this? I can't find an angle from
which to get diagnostic information. Works fine from shp2img, and works
fine when drawing from a .shp file directly, but I get nothing when I switch
to PostGIS.
Thanks,
Matthew
Here is the layer that I changed in the .map file:
WEB
... [snip]
LOG "/var/www/html/tmp/mapserver_access.log"
END
... [snip]
LAYER
CONNECTIONTYPE postgis
CONNECTION "user=matthew dbname=maps host=localhost"
DATA "the_geom from brooklyn_taxlots"
TYPE POLYGON
NAME "bk_taxlots"
MAXSCALE 25000
STATUS DEFAULT
CLASSITEM "bldgclass"
CLASS
NAME "Residential, 1-2 Fam"
EXPRESSION /A|B/
COLOR 192 192 255 # Blue
OUTLINECOLOR 32 32 32
END
... [etc, lot more classes]
_________________________________________________________________
Concerned that messages may bounce because your Hotmail account is over
limit? Get Hotmail Extra Storage! http://join.msn.com/?PAGE=features/es
