[Mapserver-users] Creating dynamic shapefiles with Python Mapscript
Bjoern Platzen
bplatzen at sosnetz.de
Tue Nov 18 03:45:38 EST 2003
Hi Folks,
I have some point-data in a MySQL database. Just showing them was not a
problem. But now I also want to make them queryable. As far as I found
out in the ML-archive, in that case, I'll have to create a new
(temporary) shapefile and a corresponding dbf, right?
So I tried to write a funtion for my class to produce these shapefiles:
def _makeDynamicLayer(self, layer, queryfile):
shpName = 'dds_data/'+layer
#define a new shapefile object
myShape = mapscript.shapefileObj(shpName,
mapscript.MS_SHAPE_POINT)
myLayer = self.mymap.getLayerByName(layer)
#open the sql-file
query = open('sql/'+queryfile+'.sql', 'r').read()
#querying the database
r = self.Conn.get_result(query)
if r[0]>0:#r=(numrecords,[[k1,k2],[k3,k4],[k5,k6],...]
#define a new shape object
newShape = mapscript.shapeObj(mapscript.MS_SHAPE_POINT)
for l in r[1]:
#define a lineobject
part = mapscript.lineObj()
#make the pointobject
newPoint = mapscript.pointObj()
newPoint.x = l[0]
newPoint.y = l[1]
#add the point to the line
part.add(newPoint)
#add the line to the shapeobject
newShape.add(part)
#print myShape
#add the shapeobject to the shapefileobject
myShape.add(newShape)
myLayer.status = mapscript.MS_ON
myShape=None
Now I get the following Error:
Traceback (innermost last):
File "/usr/local/httpd/htdocs/bauinfo/mapwindow.py", line 32, in ?
theMap = map.Map(mapfile, 'png', webargs=dct, Conn=dbConn,
dynamic=dynamic_layer)
File "/usr/local/httpd/htdocs/bauinfo/ms/map.py", line 150, in __init__
self.processMap()
File "/usr/local/httpd/htdocs/bauinfo/ms/map.py", line 237, in
processMap self._makeDynamicLayer(lay[0], lay[1])
File "/usr/local/httpd/htdocs/bauinfo/ms/map.py", line 400, in
_makeDynamicLayer myShape.add(newShape)
File "/usr/lib/python2.2/site-packages/mapscript.py", line 336, in add
def add(*args): return apply(_mapscript.shapefileObj_add,args)
TypeError: Type error. Expected _p_shapefileObj
print myShape returns <C shapefileObj instance at None>
What am I missing?? What goes wrong here??
Any help would be great!
Bye,
Bjoern
small office solutions
info at sosnetz.de - http://www.sosnetz.de
