[Mapserver-users] Help me!
Lowell Filak
lfilak at medinaco.org
Tue Nov 18 05:57:47 PST 2003
The first thing is to make sure the rpm you have for gd is for mandrake.
I believe gd-2.0.12-1.3.0.i386.rpm is a redhat rpm and although it could
work it will be looking for dependencies that may exist in pakages by
different names under mandrake.
I think the rpm for libpgn for mandrake is:
libpng-devel-1.0.9-1.2mdk.i586.rpm
And the gd2 rpm is:
libgd2-devel-2.0.15-3mdk.i586.rpm
You should be able to locate them at either:
http://rpm.pbone.net
http://rpmfind.net
HTH
Lowell
The following message was sent by "Tran Anh Tu" <trantu at vnu.edu.vn> on
Tue, 18 Nov 2003 15:03:10 +0700.
> Tran Anh Tu:
> when I install gd-2.0.12-1.3.0.i386.rpm, the screen displayed errors:
> error: failed dependencies:
> libpng10.so.0 is needed by gd-2.0.12-1.3.0
> and I had typed the command:
> rpm -qa | grep libpng
> the screen displayed:
> libpng2-1.0.9-1mdk
> libpng2-devel-1.0.9-1mdk
> what I have to do next. Please show me! Thank you.
> > Did the failed 'rpm -i' command for gd-2.0.12-1.3.0.i386.rpm produce an
> > error message with information that could help diagnose why the install
> > failed?
> > Lowell
> > Mon, 17 Nov 2003 13:40:28 +0700.
> > > Hi all!
> > > My system is mandrake 8.0, when I install MapServer 4.0 on it, there
> > is
> > > some following errors:
> > > checking for gdImageSetAntiAliased in -lgd... no
> > > checking for gdImageSetAntiAliased in -lgd... (cached) no
> > > configure: error: Could not find gd.h or libgd.a/libgd.so in
> > /usr/local. Make
> > > sure GD 2.0.12 or higher is compiled before calling configure.
> > > I had tried to install gd-2.0.12-1.3.0.i386.rpm but it didn't work.
> > Please
> > > show me how I can do to install it on my system. Thanks!
> > > Tran Anh Tu
> > > Vien CNTT - DHQG Ha Noi
> > > Phone: 047680417-25 Email trantu at vnu.edu.vn
> > > _______________________________________________
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
More information about the MapServer-users
