[Mapserver-users] Further postgis mapserv vs shp2img
Lowell Filak
lfilak at medinaco.org
Tue Nov 18 09:34:21 EST 2003
I'm not sure if I understand the question correctly.
Yes, you could compile one mapserv executable with certain options and
then a different mapscript compilation with different options - there
lies the problem, no?
Lowell
The following message was sent by Randy James <rjames57 at yahoo.com> on
Mon, 17 Nov 2003 17:01:32 -0500 (EST).
> Hi
> For some reason i always thought that you can compile the
> cgi or the mapscript libary independant of each other. You
> can compile your cgi without postgis and than your
> mapscript with postgis. Am i wrong?
> Cheers
> Randy
> --- Lowell Filak <lfilak at medinaco.org> wrote: > Do you
> know if there is more than one mapserv executable
> > on your system?
> > Is it possible that the /var/www/cgi-bin/mapserv
> > executable is not the
> > same executable that mapscript was compiled with?
> > Lowell
> > The following message was sent by "Matthew Haines"
> > <mhaines94108 at hotmail.com> on Sun, 16 Nov 2003 20:59:25
> > -0500.
> > > Further to my previous two messages
> > > # /var/www/cgi-bin/mapserv -v
> > > MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> > OUTPUT=WBMP
> > > SUPPORTS=FREETYPE INPUT=EPPL7 INPUT=JPEG INPUT=POSTGIS
> > INPUT=OGR
> > INPUT=GDAL
> > > INPUT=SHAPEFILE
> > > And yet when I try to draw a map with perl/mapscript, I
> > get this
> > error:
> > > Sun Nov 16 17:57:40 2003 - msPOSTGISLayerOpen(): Query
> > error.
> > > msPOSTGISLayerOpen called but unimplemented!
> > (mapserver not compiled
> > with
> > > postgis support)
> > > Sun Nov 16 17:57:40 2003 - msDrawMap(): Image handling
> > error. Failed
> > to draw
> > > layer named 'bk_taxlots'.
> > > Sun Nov 16 17:57:40 2003 - msPOSTGISLayerClose(): Query
> > error.
> > > msPOSTGISLayerClose called but unimplemented!(mapserver
> > not compiled
> > with
> > > postgis support)
> > > Thanks,
> > > Matthew
> _________________________________________________________________
> > > Crave some Miles Davis or Grateful Dead? Your old
> > favorites are
> > always
> > > playing on MSN Radio Plus. Trial month free!
> > > http://join.msn.com/?page=offers/premiumradio
> > > Mapserver-users mailing list
> > > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> ______________________________________________________________________
> Post your free ad now! http://personals.yahoo.ca
