[Mapserver-users] Rasters cause map to display in greyscale
Chris Storozuk
cstorozuk at shaw.ca
Tue Nov 18 09:54:03 EST 2003
Thanks Frieso,
That did the trick. An I am using 4.0.
Chris
----- Original Message -----
From: "Frieso ter Haseborg" <ter-haseborg at sf-datentechnik.de>
To: "Chris Storozuk" <cstorozuk at shaw.ca>
Cc: <mapserver-users at lists.gis.umn.edu>
Sent: Tuesday, November 18, 2003 7:35 AM
Subject: RE: [Mapserver-users] Rasters cause map to display in greyscale
sounds like the greyscale-rasters consume the whole color palette.
If you use MS 4.0 you could try the COLOR_MATCH_THRESHOLD-option on the
responsible greyscale-raster (I don't know if this option also exists in
MS 3.x).
LAYER
NAME "xyz"
TYPE RASTER
PROCESSING "COLOR_MATCH_THRESHOLD=3" # <= insert this
END
HTH,
Frieso ter Haseborg
- Software Development -
S&F Datentechnik GmbH&Co.KG
Reimersstr. 41b
26789 Leer, Germany
-----Original Message-----
Sent: Monday, November 17, 2003 7:29 PM
To: MapServer Mailing List
Subject: [Mapserver-users] Rasters cause map to display in greyscale
I have been displaying some raster images in my map, and started
noticing that some datasets cause the rest of my features to display in
greyscale, ignoring the colors set. This includes point symbols, labels
and outlines.
Does anyone know why this might happen? This seems to happen using JPGs
or TIFs of the same area. As well, I've processed down the raster images
from 8-bit color down to greyscale (according to
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0211/msg00594.h
tml
<http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0211/msg00594.
html> ), but this didn't work.
Thanks,
Chris
