Fwd: Re: [Mapserver-users] Help me!
Lowell Filak
lfilak at medinaco.org
Wed Nov 19 11:42:22 EST 2003
At this point I think your best off to download the source for at least
gd and compile it because you probably don't want to remove or go
through upgrading all the conflicting packages to satisfy the RPM
dependencies.
You will probably also need to compile libpng3 as I'm not even sure if
the libpng3 rpm is good for Mandrake 8 - that may be a 9 thing.
There is also the option of upgrading from 8->9 and allow all the
upgrades to happen.
HTH
Lowell
The following message was sent by "Tran Anh Tu" <trantu at vnu.edu.vn> on
Wed, 19 Nov 2003 14:41:27 +0700.
> Hi!
> I already tried to install libgd2-2.0.15-3mdk.i586.rpm. The errors of my
> screen are as follows:
> libpng.so.3 is needed by libgd2-2.0.15-3mdk
> Next step, I installed:
> rpm -ivh libpng3-1.2.4-3.2mdk.i586.rpm
> but had some errors:
> error: failed dependencies:
> gdk-pixbuf < 0.11.0-6mdk conflicts with libpng3-1.2.4-3.2mdk
> gdk-pixbuf-loaders < 0.16.0-1mdk conflicts with
> gnome-core < 1.4.0.6-1mdk conflicts with libpng3-1.2.4-3.2mdk
> kdebase < 2.2.2-37mdk conflicts with libpng3-1.2.4-3.2mdk
> kdegraphics < 2.2.2-4mdk conflicts with libpng3-1.2.4-3.2mdk
> kdelibs < 2.2.2-29mdk conflicts with libpng3-1.2.4-3.2mdk
> kdelibs-sound < 2.2.2-29mdk conflicts with libpng3-1.2.4-3.2mdk
> kdemultimedia < 2.2.2-3mdk conflicts with libpng3-1.2.4-3.2mdk
> kdenetwork < 2.2.2-11mdk conflicts with libpng3-1.2.4-3.2mdk
> kdepim < 2.2.2-2mdk conflicts with libpng3-1.2.4-3.2mdk
> kdetoys < 2.2.2-6mdk conflicts with libpng3-1.2.4-3.2mdk
> kdeutils < 2.2.2-6mdk conflicts with libpng3-1.2.4-3.2mdk
> kvirc < 2.1.1-5mdk conflicts with libpng3-1.2.4-3.2mdk
> libcups1 < 1.1.12-3mdk conflicts with libpng3-1.2.4-3.2mdk
> libgd1 < 1.8.4-4mdk conflicts with libpng3-1.2.4-3.2mdk
> libgtkxmhtml1 < 1.4.1.4-1mdk conflicts with libpng3-1.2.4-3.2mdk
> libimlib1 < 1.9.11-8mdk conflicts with libpng3-1.2.4-3.2mdk
> libqt2 < 2.3.1-24mdk conflicts with libpng3-1.2.4-3.2mdk
> linuxconf < 1.26r5-2mdk conflicts with libpng3-1.2.4-3.2mdk
> nautilus < 1.0.6-8mdk conflicts with libpng3-1.2.4-3.2mdk
> sawfish < 1.0-7mdk conflicts with libpng3-1.2.4-3.2mdk
> can you help me? Thanks!
> -----Original Message-----
> From: "Lowell Filak" <lfilak at medinaco.org>
> To: "Tran Anh Tu" <trantu at vnu.edu.vn>, Mapserver-
> users at lists.gis.umn.edu
> Date: Tue, 18 Nov 2003 08:57:47 -0500
> Subject: Re: [Mapserver-users] Help me!
> > The first thing is to make sure the rpm you have for gd is for
> > mandrake.
> > I believe gd-2.0.12-1.3.0.i386.rpm is a redhat rpm and although it
> > could
> > work it will be looking for dependencies that may exist in pakages by
> > different names under mandrake.
> > I think the rpm for libpgn for mandrake is:
> > libpng-devel-1.0.9-1.2mdk.i586.rpm
> > And the gd2 rpm is:
> > libgd2-devel-2.0.15-3mdk.i586.rpm
> > You should be able to locate them at either:
> > http://rpm.pbone.net
> > http://rpmfind.net
> > HTH
> > Lowell
> > Tue, 18 Nov 2003 15:03:10 +0700.
> > > Tran Anh Tu:
> > > when I install gd-2.0.12-1.3.0.i386.rpm, the screen displayed errors:
> > > libpng10.so.0 is needed by gd-2.0.12-1.3.0
> > > and I had typed the command:
> > > rpm -qa | grep libpng
> > > the screen displayed:
> > > libpng2-1.0.9-1mdk
> > > libpng2-devel-1.0.9-1mdk
> > > what I have to do next. Please show me! Thank you.
> > > > Did the failed 'rpm -i' command for gd-2.0.12-1.3.0.i386.rpm
> > produce an
> > > > error message with information that could help diagnose why the
> > install
> > > > failed?
> > > > Lowell
> > > > Mon, 17 Nov 2003 13:40:28 +0700.
> > > > > Hi all!
> > > > > My system is mandrake 8.0, when I install MapServer 4.0 on it,
> > there
> > > > is
> > > > > some following errors:
> > > > > checking for gdImageSetAntiAliased in -lgd... no
> > > > > checking for gdImageSetAntiAliased in -lgd... (cached) no
> > > > > configure: error: Could not find gd.h or libgd.a/libgd.so in
> > > > /usr/local. Make
> > > > > sure GD 2.0.12 or higher is compiled before calling configure.
> > > > > I had tried to install gd-2.0.12-1.3.0.i386.rpm but it didn't
> > work.
> > > > Please
> > > > > show me how I can do to install it on my system. Thanks!
> > > > > Tran Anh Tu
> > > > > Vien CNTT - DHQG Ha Noi
> > > > > Phone: 047680417-25 Email trantu at vnu.edu.vn
> > > > > _______________________________________________
> > > > > Mapserver-users mailing list
> > > > > Mapserver-users at lists.gis.umn.edu
> > > > > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
