[Mapserver-users] Re: itemquery problem -- I'm pulling my hair out.
Mac Birch
mac at mbirch.com
Wed Nov 19 16:06:30 EST 2003
--- In mapserver-users at yahoogroups.com, "David Fawcett"
<David.Fawcett at s...> wrote:
> Mac,
> This is really low hanging fruit, and your problem may lie much
higher
> in the tree....but, try stating your qitem in all uppercase e.g.
> [NAME].
> I have found this to be necessary for all shapefile based
queries.
> David.
> David J. Fawcett
> MN Office of Environmental Assistance
> >>> "Mac Birch" <mac at m...> 11/19/2003 12:51:39 PM >>>
> Has anyone had any success using itemquery with MS 4.0 with IIS on
> XP-Professional?
> My map file extents have been carefully defined to include a box
> that is much, much larger than the theme coverage I'm searching.
> All other aspects of the system work, but I still am getting the
> dreaded "Search returned no results. No matching record(s) found,
> layer and area of interest do not overlap." message.
> Here's the .map file I'm using:
> # Start of map file
> NAME TESTQuery
> STATUS ON
> SIZE 480 520
> EXTENT 1300000 1443024 4126986 -682424
> SHAPEPATH "c:\myApplicationPath\buckscounty\GIS\data"
> OUTPUTFORMAT
> NAME png
> DRIVER "GD/PNG"
> MIMETYPE "image/png"
> IMAGEMODE RGBA
> EXTENSION "png"
> END
> # Start of web interface definition
> WEB
> #EMPTY ../../buckscounty/gis/RecNotFound.htm
> TEMPLATE queryResult.htm
> IMAGEPATH "e:\myimagepath\buckscounty\tmp\"
> # LOG "testQuery.log"
> END
> QUERYMAP
> STATUS ON
> STYLE HILITE
> COLOR 255 255 0
> END
> LAYER
> NAME boundaries
> DATA townBoundaries
> STATUS DEFAULT
> TYPE polygon
> CLASS
> COLOR 212 212 212
> OUTLINECOLOR 0 0 0
> END
> END
> END # Map File
> Here's the essence of the form I'm submitting:
> <form action="http://www.mydomain.com/gis/mapserver40-
> png/mapserv.exe" method="get">
> <input type="hidden" name="map"
> value="../../mapPath/buckscounty/gis/testQuery.map">
> <input type="hidden" name="mode" value="itemquery">
> <input type="hidden" name="savequery" value="true">
> <input type="hidden" name="qlayer" value="boundaries">
> <input type="hidden" name="qitem" value="Name">
> <input type="hidden" name="mapext" value="shapes">
> <input type="submit" value="Submit Query">
> <input name="qstring" size="45">
> </form>
> I have tried submitting just about every possible combination of
> qstring options I can think of. for example,
> ([Name] EQ 'Doylestown')
> ([Name] EQ "Doylestown")
> ('[Name]' IN 'Doylestown')
> ([Name] = 'Doylestown')
> ([Name] = "Doylestown")
> ('[Name]' EQ "Doylestown")
> ('[Name]' EQ 'Doylestown')
> ('[Name]' EQ Doylestown) -- Yikes!!
> etc. (I think you get the picture)
> Upper/lower cases of the "Name" variable and "Doylestown" are
> identical to those that appear in the shapefile.dbf table
> It appears that MS is simply not finding the requested variable in
> the qstring, so I even tried submitting strings that would always
> evaluate to TRUE, such as
> (1 EQ 1)
> (1 = 1)
> (2 GE 1)
> (2 <= 1)
> ([Name] EQ [Name] etc.
> Still, the same result.
> Where have I gone wrong? Please share your success stories.
> Much Appreciated
> --Mac--
> Mapserver-users mailing list
> Mapserver-users at l...
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
