[Mapserver-users] CGI / expression assistance
Andrew Koebrick
Andrew.Koebrick at state.mn.us
Wed Nov 19 17:30:13 EST 2003
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C3AEEC.B2CE1130
Content-Type: text/plain
Can anyone tell me if what I am attempting is possible, and perhaps share
with me the required syntax?
I am attempting to use the CGI version of mapserver to create a map
highlighting one or more counties (or townships, cities...) based upon a
dynamically generated URL. I am able to highlight single counties with this
syntax:
http://www.mba.state.mn.us/cgi-bin/mapserv?map=/home/httpd/html-MBA/maps/cou
nty.map
<http://www.mba.state.mn.us/cgi-bin/mapserv?map=/home/httpd/html-MBA/maps/co
unty.map&map_county_class_expression(NAME_LOWER=Hennepin)&mode=map>
Changing the county name changes what is mapped. How, however, do I make it
do multiple counties? I have tried lots of variants of the syntax suggested
in the documentation
(http://mapserver.gis.umn.edu/doc36/mapfile-reference.html#class
<http://mapserver.gis.umn.edu/doc36/mapfile-reference.html#class> ) such as:
nty.map&map_county_class_expression(NAME_LOWER='Lake'
or[NAME_LOWER]='hennepin')&mode=map
Many thanks for any assistance.
Cheers,
Andrew Koebrick
Web Coordinator / Librarian
Dept. of Administration
State of Minnesota
658 Cedar St.
St. Paul, MN 55102
651-296-4156
http://server.admin.state.mn.us
Content-Type: text/html
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3AEBB.3DC6EC30">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"PostalCode"/>
<o:SmartTagType =
name=3D"City"/>
<o:SmartTagType =
name=3D"Street"/>
<o:SmartTagType =
name=3D"address"/>
<o:SmartTagType =
name=3D"State"/>
<o:SmartTagType =
name=3D"place"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Can anyone tell me if what I am attempting is =
possible, and
perhaps share with me the required syntax?<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>I am attempting to use the CGI version of <span
class=3DSpellE>mapserver</span> to create a map highlighting one or =
more counties
(or townships, cities...) based upon a dynamically generated URL.<span
style=3D'mso-spacerun:yes'> </span>I am able to highlight single =
counties
with this syntax:<o:p></o:p></span></font></p>
font-family:Arial'><a
href=3D"http://www.mba.state.mn.us/cgi-bin/mapserv?map=3D/home/httpd/htm=
l-MBA/maps/county.map&map_county_class_expression(NAME_LOWER=3DHenne=
pin)&mode=3Dmap">http://www.mba.state.mn.us/cgi-bin/mapserv?map=3D/h=
ome/httpd/html-MBA/maps/county.map&map_county_class_expression(NAME_=
LOWER=3DHennepin)&mode=3Dmap</a><o:p></o:p></span></font></p>
font-family:Arial'>Changing the county name changes what is =
mapped.<span
style=3D'mso-spacerun:yes'> </span>How, however, do I make it do =
multiple
counties?<span style=3D'mso-spacerun:yes'> </span>I have tried =
lots of variants
of the syntax suggested in the documentation (<a
href=3D"http://mapserver.gis.umn.edu/doc36/mapfile-reference.html#class"=
>http://mapserver.gis.umn.edu/doc36/mapfile-reference.html#class</a>)
such as:<o:p></o:p></span></font></p>
font-family:Arial'>http://www.mba.state.mn.us/cgi-bin/mapserv?map=3D/hom=
e/httpd/html-MBA/maps/county.map&map_county_class_<span
class=3DGramE>expression(</span>NAME_LOWER=3D'</span></font><st1:place><=
font
style=3D'font-size:10.0pt;font-family:Arial'>Lake</span></font></st1:pla=
ce><font
style=3D'font-size:10.0pt;font-family:Arial'>' or[NAME_LOWER]=3D'<span
class=3DSpellE>hennepin</span>')&mode=3Dmap<o:p></o:p></span></font>=
</p>
font-family:Arial'>Many thanks for any =
assistance.<o:p></o:p></span></font></p>
font-family:Arial'><br>
Cheers,<o:p></o:p></span></font></p>
font-family:Arial'>Andrew <span =
class=3DSpellE>Koebrick</span><o:p></o:p></span></font></p>
font-family:Arial'>Web Coordinator / =
Librarian<o:p></o:p></span></font></p>
font-family:Arial'>Dept. of Administration<o:p></o:p></span></font></p>
font-family:Arial'>State of </span></font><st1:State><st1:place><font =
size=3D2
style=3D'font-size:10.0pt;font-family:Arial'>Minnesota</span></font></st=
1:place></st1:State><font
style=3D'font-size:10.0pt;font-family:Arial'><br>
</span></font><st1:Street><st1:address><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>658 Cedar =
St</span></font></st1:address></st1:Street><font
style=3D'font-size:10.0pt;font-family:Arial'>. <br>
</span></font><st1:place><st1:City><font size=3D2 face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>St. =
Paul</span></font></st1:City><font
style=3D'font-size:10.0pt;font-family:Arial'>, </span></font><st1:State>=
<font
style=3D'font-size:10.0pt;font-family:Arial'>MN</span></font></st1:State=
><font
style=3D'font-size:10.0pt;font-family:Arial'> =
</span></font><st1:PostalCode><font
style=3D'font-size:10.0pt;font-family:Arial'>55102</span></font></st1:Po=
stalCode></st1:place><font
style=3D'font-size:10.0pt;font-family:Arial'><o:p></o:p></span></font></=
p>
font-family:Arial'>651-296-4156<o:p></o:p></span></font></p>
font-family:Arial'>http://server.admin.state.mn.us<o:p></o:p></span></fo=
nt></p>
</div>
</body>
</html>
------_=_NextPart_001_01C3AEEC.B2CE1130--
