[Mapserver-users] TypeError-Problem with Python Mapscript
Michael Schulz
mschulz at webgis.de
Thu Nov 20 11:22:53 EST 2003
Hi Bjoern,
Just some thoughts...:
Are all paths to your data, etc. the same on both machines?
What about the permissions of the mapfile and or data and related files?
Hmm, what is the output of dir(mapscript)?
Cheers, Michael
Bjoern Platzen schrieb:
> Hi List,
> I just loaded my PyMapScript application onto the webserver.
> But now I get Errors, that I didn't get on my machine (They're both SuSE
> Linux 8.0, Mapserver 3.6.5 & Mapscript compiled with the same options).
> This is what I get on the shell:
>>>>import mapscript
>>>>mymap =
> mapscript.mapObj('/usr/local/httpd/htdocs/bauinfo/bauinfo.map')
>>>>mymap
> <C mapObj instance at None>
>>>>ip=mymap.web.imagepath
> Traceback (most recent call last):
> File "<stdin>", line 1, in ?
> TypeError: Type error. Expected _p_mapObj
>>>>mymap.__dict__
> {'this': None, 'thisown': 1}
>>>>mymap.extent.minx
> It seems as if the mapObj() isn't built properly
> -> <C mapObj instance at None>
> I think there should be something like
> -> <C mapObj instance at _08d0a240_p_mapObj>
> Has anyone an idea, of what could cause that the mapObj() isn't build
> right?
> Any help would be great!
> Thanks,
> Bjoern.
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
