[Mapserver-users] MS4.0 and Raster (GeoTiff) assistance needed
Phil Shevlin
pshevlin at cityftmyers.com
Fri Nov 21 15:16:05 EST 2003
Yes it does (mostly). We use MapInfo here. And it is:
US State Plane Coord System (1983, Feet)
-- Florida 0902, Western Zone (1983, US Survey Feet)
I'm just learning MS. And this is my first foray into projections...
-Phil
-----Original Message-----
Sent: Thursday, November 20, 2003 1:30 PM
To: Phil Shevlin
Subject: RE: [Mapserver-users] MS4.0 and Raster (GeoTiff) assistance
needed
Phil -
They would most likely, then, be in Florida State Plane (East Zone)
coordinates, which may be either in feet or meters, but from the numbers I'm
going to guess that they are feet. That would mean that the image is at a
resolution of four feet per pixel - does that sound right?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
From: Phil Shevlin [mailto:pshevlin at cityftmyers.com]
Sent: Thursday, November 20, 2003 1:11 PM
To: Ed McNierney
needed
Thanks for the reply.
The raster is of a city in Florida (Ft. Myers).
Sent: Wednesday, November 19, 2003 6:33 PM
To: Phil Shevlin; mapserver-users at lists.gis.umn.edu
needed
Phil -
If you can tell us what part of the Earth this raster file represents,
it will help us interpret the proper projection for it. It is clearly
NOT in degrees, and the 4.0 and -4.0 lines *probably* refer to meters.
- Ed
Ed McNierney
TopoZone.com
ed at topozone.com
Sent: Wednesday, November 19, 2003 5:04 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] MS4.0 and Raster (GeoTiff) assistance needed
I have a map with a number of layers working. I am trying to include a
raster layer (.tif). When I include the layer:
LAYER
NAME "Test"
STATUS ON
DATA "E:/Inetpub/wwwroot/mapserver/raster/4424.tif"
TYPE RASTER
TEMPLATE "template_hi.html"
END
The map shows but the layer does not appear. I am assuming that it is a
projection problem. My extent is in degrees:
EXTENT -81.917574 26.569844 -81.755026 26.691756
But the .tfw file appears otherwise:
4.00000000000000
0.00000000000000
0.00000000000000
-4.00000000000000
669000.00000000000000
855000.00000000000000
How do I go about including this layer? Or, can someone point me to
some
tutorials (I have found one that helps me).
Thanks
Phil Shevlin
I am using:
Win2K server
Mapserver 4.0
OGR => MapInfo .tab's
E:\Inetpub\wwwroot\cgi-bin>mapserv40 -v
MapServer version 4.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER
SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=EPPL7
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
