[Mapserver-users] querybyattributes with Postgres/Postgis Layer
Nicol Hermann
mapserver at geochem.de
Wed Nov 26 13:32:06 EST 2003
Dear List,
i trying to do a querybyattributes Query with a Postgres/Postgis layer
and get the following error:
Warning: [MapServer Error]: prep_DB(): Error executing POSTGIS DECLARE
(the actual query) statement: 'DECLARE mycursor BINARY CURSOR FOR SELECT
plzort01::text,asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from plz_gebiete WHERE (Mutterstadt) and (the_geom && setSRID( 'BOX3D(5.865627 46.57242768,15.039879 55.75900832)'::BOX3D,find_srid('','plz_gebiete','the_geom') ))'
here is the relevant part of my code:
$layer = $Map ->getLayerbyname("Regionen");
$layer -> set("status", MS_ON );
$status = $layer->querybyattributes("plzort01", "Mutterstadt",
MS_MULTIPLE);
It seems that the 'qitem' (plzort01) won't be evaluated because it is
not present in the SQL statement.
I also tried the qitem with upper case. The same error appears.
The debugging message on my shell says:
ERROR: Attribute "mutterstadt" not found
My Postgis Version is: Mappostgis.c - version of June 12/2003.
and i`am using Mapserver 4.0.1 on a Linux box.
Does anybody know how I can solve this problem?
Many thanks
Nicol
Nicol Hermann <mapserver at geochem.de>
