[Mapserver-users] Problems with tab files in MapLab
Stephen Wallace
gis at gisrs.com
Fri Nov 28 11:19:29 PST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_0053_01C3B5BA.A641A3D0
Content-Type: text/plain;
charset="US-ASCII"
Content-Transfer-Encoding: 7bit
To the list
I am having difficulties getting MapInfo tab files working with my setup
of Mapserver/MapLab.
I have set up the map using MapEdit and got the following error when I
tried to open the map in MapBrowser.
Error Parsing DundasSub.map
Description
Open failed for OGR connection `DundasHome.TAB'. File not found or
unsupported format. in /maplab/common/wrapper/drawmap.php
Failed to draw layer named 'DundasHomeTab'. in
In MapEdit I set the following parameters
Data - left blank
Type - polygon
Connection Type - OGR
Connection - DundasHome.TAB
The map has 3 other files, two shape files and 1 ecw file which worked
correctly until the tab file was added.
I installed MapLab (2.1RC3) using ms4w
Thanks
Stephen Wallace
Content-Type: text/html;
charset="US-ASCII"
Content-Transfer-Encoding: quoted-printable
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<TITLE>Message</TITLE>
<META content=3D"MSHTML 6.00.2800.1264" name=3DGENERATOR></HEAD>
<BODY>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D062304818-28112003>To the =
list</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN=20
class=3D062304818-28112003></SPAN></FONT> </DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D062304818-28112003>I am =
having=20
difficulties getting MapInfo tab files working with my setup of=20
Mapserver/MapLab.</SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN =
class=3D062304818-28112003><!--StartFragment --><STRONG><FONT=20
face=3D"Times New Roman" =
size=3D3> </FONT></STRONG></SPAN></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D062304818-28112003>I have =
set up the=20
map using MapEdit and got the following error when I tried to open the =
map in=20
MapBrowser.</SPAN></FONT></DIV>
class=3D062304818-28112003><!--StartFragment --><STRONG><TR><TD =
valign=3D"middle"=20
height=3D"30" bgcolor=3D"#b2c4c4"><FONT =
face=3DArial,Helvetica,sans-serif size=3D2>Error=20
Parsing DundasSub.map</FONT></STRONG></TD><FONT size=3D3><FONT=20
face=3D"Times New Roman"> </TR><TR><TD></FONT></FONT>
<TABLE cellSpacing=3D0 cellPadding=3D2 border=3D0>
<TBODY>
<TR>
<TD colSpan=3D2><FONT size=3D2>Description</FONT></TD></TR>
<TR>
<TD colSpan=3D2><FONT color=3D#ff3333 size=3D2>Open failed for OGR =
connection=20
`DundasHome.TAB'. File not found or unsupported format. in=20
/maplab/common/wrapper/drawmap.php</FONT></TD></TR>
<TR>
<TD colSpan=3D2>
<DIV><FONT color=3D#ff3333 size=3D2>Failed to draw layer named=20
'DundasHomeTab'. in =
/maplab/common/wrapper/drawmap.php</FONT></DIV>
<DIV><FONT color=3D#ff3333 size=3D2></FONT> </DIV>
<DIV><SPAN class=3D062304818-28112003><FONT size=3D2>In MapEdit I =
set the=20
following parameters</FONT></SPAN></DIV>
<DIV><SPAN class=3D062304818-28112003><FONT=20
size=3D2></FONT></SPAN> </DIV>
<DIV><SPAN class=3D062304818-28112003><FONT size=3D2>Data - =
left=20
blank</FONT></SPAN></DIV>
<DIV><SPAN class=3D062304818-28112003></SPAN><SPAN=20
class=3D062304818-28112003><FONT size=3D2>Type - =
polygon</FONT></SPAN></DIV>
<DIV><FONT size=3D2>Connection Type<SPAN =
class=3D062304818-28112003> -=20
OGR</SPAN></FONT></DIV>
<DIV><FONT size=3D2><SPAN class=3D062304818-28112003>Connection -=20
DundasHome.TAB</SPAN></FONT></DIV>
<DIV><FONT size=3D2><SPAN=20
<DIV><FONT><SPAN class=3D062304818-28112003></SPAN></FONT><FONT =
size=3D2><SPAN=20
class=3D062304818-28112003>The map has 3 other files, two shape =
files and 1=20
ecw file which worked correctly until the tab file was=20
added.</SPAN></FONT></DIV>
<DIV><FONT=20
size=3D2></FONT> </DIV></TD></TR></TBODY></TABLE></TD></TR></SPAN></=
FONT></DIV>
<DIV><FONT face=3DArial size=3D2><SPAN class=3D062304818-28112003>I =
installed MapLab=20
(2.1RC3) using ms4w</SPAN></FONT></DIV>
class=3D062304818-28112003>Thanks</SPAN></FONT></DIV>
class=3D062304818-28112003></SPAN></FONT><FONT=20
face=3DArial size=3D2>Stephen Wallace</FONT></DIV>
<DIV align=3Dleft>
<DIV align=3Dleft><FONT face=3DArial size=3D2></FONT></DIV><FONT =
face=3DArial=20
size=3D2></FONT></DIV></BODY></HTML>
------=_NextPart_000_0053_01C3B5BA.A641A3D0--
More information about the MapServer-users
