[Mapserver-users] Re: [ms4w-users] Problems with tab files in MapLab
Stephen Wallace
gis at gisrs.com
Sun Nov 30 13:59:27 EST 2003
Daniel
Your advise solved the problem
Thanks
Stephen Wallace
In MapServer 4.0 and 3.6, the OGR connections were *not* relative to the
SHAPEPATH. This has been fixed in version 4.1 (under development). Try
setting absolute paths inyour OGR connections.
Daniel
Stephen Wallace wrote:
> To the list
> I am having difficulties getting MapInfo tab files working with my
> setup
> of Mapserver/MapLab.
> I have set up the map using MapEdit and got the following error when I
> tried to open the map in MapBrowser.
> *Error Parsing DundasSub.map*
> Description
> Open failed for OGR connection `DundasHome.TAB'. File not found or
> unsupported format. in /maplab/common/wrapper/drawmap.php
> Failed to draw layer named 'DundasHomeTab'. in
> In MapEdit I set the following parameters
> Data - left blank
> Type - polygon
> Connection Type - OGR
> Connection - DundasHome.TAB
> The map has 3 other files, two shape files and 1 ecw file which worked
> correctly until the tab file was added.
> I installed MapLab (2.1RC3) using ms4w
> Thanks
> Stephen Wallace
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
