[Mapserver-users] GeoTIFF's and some FAA Data
Andy Green
green at fboweb.com
Sun Nov 30 23:00:16 EST 2003
This is a multi-part message in MIME format.
------=_NextPart_000_008B_01C3B795.B8C16CC0
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Hi folks.
I just set up the server for the first time, and got it all running
using the demo, so it seems to work great.
I'm trying to use the server as a WMS server, and I'm having a bit of
trouble.
Specifically, I'm trying to use a particular GeoTIFF, available at the
following link:
http://www.naco.faa.gov/index.asp?xml=naco/catalog/charts/digital/Raster
_Sectional_Sample/Raster#3
It includes a .tif file and a .tfw file (which I've renamed sample.wld,
cuz that's what the docs say to do).
When I try to pull the map from the mapserver when specifying a
particular bounding box [that should return a valid map], I always get a
blank image. however when I pull the map from the WMS server and OMIT a
bounding box parameter, I get a big seemingly blank image with a
thumbnail-sized view of the GeoTIFF way down at the bottom image.
My guess is that somehow my projections are messed up, or perhaps the
server is not seeing the .wld file.
If anyone could provide some pointers, I'd greatly appreciate it.!
Andy, green at fboweb.com
PS: Here's my .MAP file.
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 600
#EXTENT 435376.6668 167787.8676 455661.5904 176788.656
# original extent
#EXTENT 388107.634400379 5203120.88405952 500896.339019834
5310243.30613897
# modified extent from andy
EXTENT 455661.5904 167787.8676 435376.6670 5310243.30613897
# entire extent
#EXTENT 0.0 0.0 684000.0 684000.0
#EXTENT 0.0 9999999.9 0.0 9999999.0
#EXTENT -408683.0 512426.0 -408683.0 512426.0
UNITS METERS
SHAPEPATH "data"
IMAGECOLOR 255 255 255
# you may need to change this to match your MapServer build
#IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter
discussion
#PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "no_defs"
# OR:
# "init=epsg:26915"
#END
PROJECTION
"proj=lcc"
"ellps=GRS80"
"lat_1=41.333333"
"lat_2=46.666667"
"lat_0=44.5"
"lon_0=-121.0"
"x_0=0.0"
"y_0=0.0"
END
# Start of web interface definition (including WMS enabling metadata)
WEB
HEADER demo_header.html
TEMPLATE demo.html
FOOTER demo_footer.html
MINSCALE 1000
MAXSCALE 3550000
IMAGEPATH "set in demo_init.html"
IMAGEURL "set in demo_init.html"
METADATA
"wms_title" "Seattle Sectional Demo"
WMS_ABSTRACT "This is just me playing around with the Sectional
.TIFFS to see if I can get them working."
WMS_ACCESSCONSTRAINTS none
# change this value to match your setup
"wms_onlineresource" "http://localhost/ms/map.asp?&"
#WMS_ONLINERESOURECE "http://localhost/ms/dm/itasca/demo_init.html"
#WMS_SRS "EPSG:26915"
"wms_srs" "EPSG:4326"
END
END
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of reference map
REFERENCE
IMAGE graphics/reference.gif
# EXTENT 435376.6668 167787.8676 455661.5904 176788.656
# entire extent
#EXTENT 455661.5904 167787.8676 435376.6670 5310243.30613897
# original extent
#EXTENT 393234.393701263 5205405.16440722 495769.579718949
5307959.02579127
SIZE 120 120
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 80 2
COLOR 255 255 255
UNITS MILES
INTERVALS 1
TRANSPARENT TRUE
STATUS TRUE
END
# Start of layer definitions
LAYER
NAME sectional
DATA sample.tif
TYPE RASTER
STATUS ON
METADATA
WMS_TITLE "sectional"
WMS_SRS "EPSG:4326"
END
END
END # Map File
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3B795.B84ED4D0">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'>Hi folks.<o:p></o:p></span></font></p>
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>I just set up the server for the first time, and got =
it all
running using the demo, so it seems to work =
great.<o:p></o:p></span></font></p>
font-family:Arial'>I’m trying to use the server as a WMS server, =
and I’m
having a bit of trouble.<o:p></o:p></span></font></p>
font-family:Arial'>Specifically, I’m trying to use a particular =
<span
class=3DSpellE>GeoTIFF</span>, available at the following =
link:<o:p></o:p></span></font></p>
font-family:Arial'><a
href=3D"http://www.naco.faa.gov/index.asp?xml=3Dnaco/catalog/charts/digit=
al/Raster_Sectional_Sample/Raster#3">http://www.naco.faa.gov/index.asp?xm=
l=3Dnaco/catalog/charts/digital/Raster_Sectional_Sample/Raster#3</a><o:p>=
font-family:Arial'>It includes a .<span class=3DSpellE>tif</span> file =
and a .<span
class=3DSpellE>tfw</span> file (which I’ve renamed <span =
class=3DSpellE>sample.wld</span>,
<span class=3DSpellE>cuz</span> that’s what the docs say to =
do).<o:p></o:p></span></font></p>
font-family:Arial'>When I try to pull the map from the <span =
class=3DSpellE>mapserver</span>
when specifying a particular bounding box [that should return a valid =
map], I
always get a blank image… however when I pull the map from the WMS =
server
and OMIT a bounding box parameter, I get a big seemingly blank image =
with a thumbnail-sized
view of the <span class=3DSpellE>GeoTIFF</span> way down at the bottom =
image.<o:p></o:p></span></font></p>
font-family:Arial'>My guess is that somehow my projections are messed =
up, or
perhaps the server is not seeing the .<span class=3DSpellE>wld</span> =
file…<o:p></o:p></span></font></p>
font-family:Arial'>If anyone could provide some pointers, I’d =
greatly
appreciate it…!<o:p></o:p></span></font></p>
font-family:Arial'>Andy, <a =
href=3D"mailto:green at fboweb.com">green at fboweb.com</a><o:p></o:p></span></=
font></p>
font-family:Arial'>PS: Here’s my .MAP =
font-family:Arial'>#<o:p></o:p></span></font></p>
font-family:Arial'># Start of map file<o:p></o:p></span></font></p>
font-family:Arial'>NAME DEMO<o:p></o:p></span></font></p>
font-family:Arial'>STATUS ON<o:p></o:p></span></font></p>
font-family:Arial'>SIZE 600 <span =
class=3DSpellE>600</span><o:p></o:p></span></font></p>
font-family:Arial'>#EXTENT 435376.6668 167787.8676 455661.5904 =
176788.656<o:p></o:p></span></font></p>
font-family:Arial'># <span class=3DGramE>original</span> =
extent<o:p></o:p></span></font></p>
font-family:Arial'>#EXTENT 388107.634400379 5203120.88405952 =
500896.339019834
5310243.30613897<o:p></o:p></span></font></p>
font-family:Arial'># modified extent from <span class=3DSpellE><span =
class=3DGramE>andy</span></span><o:p></o:p></span></font></p>
font-family:Arial'>EXTENT 455661.5904 167787.8676 435376.6670 =
font-family:Arial'># <span class=3DGramE>entire</span> =
font-family:Arial'>#EXTENT 0.0 <span class=3DSpellE>0.0</span> 684000.0 =
<span
class=3DSpellE>684000.0</span><o:p></o:p></span></font></p>
font-family:Arial'>#EXTENT 0.0 9999999.9 0.0 =
9999999.0<o:p></o:p></span></font></p>
font-family:Arial'>#EXTENT -408683.0 512426.0 -408683.0 512426.0 =
font-family:Arial'>UNITS METERS<o:p></o:p></span></font></p>
font-family:Arial'>SHAPEPATH =
"data"<o:p></o:p></span></font></p>
font-family:Arial'>IMAGECOLOR 255 <span class=3DSpellE>255</span> <span
class=3DSpellE>255</span><o:p></o:p></span></font></p>
font-family:Arial'># <span class=3DGramE>you</span> may need to change =
this to
match your <span class=3DSpellE>MapServer</span> =
build<o:p></o:p></span></font></p>
font-family:Arial'>#IMAGETYPE PNG<o:p></o:p></span></font></p>
font-family:Arial'># Projection definition, consult the PROJ.4 =
documentation
for parameter discussion<o:p></o:p></span></font></p>
font-family:Arial'>#PROJECTION<o:p></o:p></span></font></p>
<p class=3DMsoNormal><span class=3DGramE><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>#<span
style=3D'mso-spacerun:yes'> =
</span>"</span></font></span><span
class=3DSpellE><font size=3D2 face=3DArial><span =
Arial'>proj</span></font></span><font size=3D2 face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial'>=3D<span =
class=3DSpellE>utm</span>"<o:p></o:p></span></font></p>
face=3DArial><span
Arial'>ellps</span></font></span><font size=3D2 face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>=3DGRS80"<o:p></o:p></s=
pan></font></p>
face=3DArial><span
</span>"</span></font></span><font size=3D2
style=3D'font-size:10.0pt;font-family:Arial'>zone=3D15"<o:p></o:p></=
span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>north"<o:p></o:p></span=
></font></p>
face=3DArial><span
Arial'>no_defs</span></font></span><font size=3D2 face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>"<o:p></o:p></span></fo=
nt></p>
face=3DArial><span
style=3D'mso-spacerun:yes'> </span>OR</span></font></span><font =
size=3D2
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial'>: =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>init=3Depsg:26915"<o:p>=
font-family:Arial'>#END<o:p></o:p></span></font></p>
font-family:Arial'>PROJECTION<o:p></o:p></span></font></p>
font-family:Arial'><span =
style=3D'mso-tab-count:1'>  =
; </span>"<span
class=3DSpellE><span class=3DGramE>proj</span></span><span =
class=3DGramE>=3D</span><span
class=3DSpellE>lcc</span>"<o:p></o:p></span></font></p>
; </span>"<span
class=3DSpellE><span class=3DGramE>ellps</span></span><span =
class=3DGramE>=3D</span>GRS80"<o:p></o:p></span></font></p>
</span>"lat_1=3D41.333333"<o:p></o:p></span></font></p>
</span>"lat_2=3D46.666667"<o:p></o:p></span></font></p>
</span>"lat_0=3D44.5"<o:p></o:p></span></font></p>
</span>"lon_0=3D-121.0"<o:p></o:p></span></font></p>
</span>"x_0=3D0.0"<o:p></o:p></span></font></p>
</span>"y_0=3D0.0"<o:p></o:p></span></font></p>
font-family:Arial'>END<o:p></o:p></span></font></p>
font-family:Arial'># Start of web interface definition (including WMS =
enabling
metadata)<o:p></o:p></span></font></p>
font-family:Arial'>WEB<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>HEADER
demo_header.html<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> =
</span>TEMPLATE
demo.html<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>FOOTER
demo_footer.html<o:p></o:p></span></font></p>
</span>MINSCALE 1000<o:p></o:p></span></font></p>
</span>MAXSCALE
3550000<o:p></o:p></span></font></p>
</span>IMAGEPATH
"set in demo_init.html"<o:p></o:p></span></font></p>
</span>IMAGEURL
</span>METADATA<o:p></o:p></span></font></p>
</span>"<span class=3DSpellE>wms_title</span>" "Seattle =
Sectional
Demo"<o:p></o:p></span></font></p>
</span>WMS_ABSTRACT "This is just me playing around with the =
Sectional
.TIFFS to see if I can get them =
working.”<o:p></o:p></span></font></p>
</span>WMS_ACCESSCONSTRAINTS none<o:p></o:p></span></font></p>
</span>#
change this value to match your setup<o:p></o:p></span></font></p>
</span>"<span class=3DSpellE>wms_onlineresource</span>"
"http://localhost/ms/map.asp?&"<o:p></o:p></span></font></p=
</span>#WMS_ONLINERESOURECE
"http://localhost/ms/dm/itasca/demo_init.html"<o:p></o:p></span=
></font></p>
</span>#WMS_SRS "EPSG<span =
class=3DGramE>:26915</span>"<o:p></o:p></span></font></p>
</span>"<span class=3DSpellE>wms_srs</span>" "EPSG<span
class=3DGramE>:4326</span>"<o:p></o:p></span></font></p>
</span>END<o:p></o:p></span></font></p>
font-family:Arial'>QUERYMAP<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>SIZE =
200 <span
class=3DSpellE>200</span><o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>STATUS =
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>STYLE =
HILITE<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>COLOR =
255 0 <span
class=3DSpellE>0</span><o:p></o:p></span></font></p>
font-family:Arial'># Start of reference map<o:p></o:p></span></font></p>
font-family:Arial'>REFERENCE<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>IMAGE =
graphics/<span
class=3DSpellE>reference.gif</span><o:p></o:p></span></font></p>
face=3DArial><span
</span>EXTENT</span></font></span><font size=3D2
face=3DArial><span style=3D'font-size:10.0pt;font-family:Arial'> =
435376.6668
167787.8676 455661.5904 176788.656<o:p></o:p></span></font></p>
<span
font-family:Arial'>#EXTENT 455661.5904 167787.8676 435376.6670 =
font-family:Arial'>#EXTENT 393234.393701263 5205405.16440722 =
495769.579718949
5307959.02579127<o:p></o:p></span></font></p>
120 <span
class=3DSpellE>120</span><o:p></o:p></span></font></p>
-1 -1 -1<o:p></o:p></span></font></p>
</span>OUTLINECOLOR
255 0 <span class=3DSpellE>0</span><o:p></o:p></span></font></p>
font-family:Arial'># Start of legend<o:p></o:p></span></font></p>
font-family:Arial'>LEGEND<o:p></o:p></span></font></p>
</span>KEYSIZE 18 12<o:p></o:p></span></font></p>
</span>LABEL<o:p></o:p></span></font></p>
</span>TYPE BITMAP<o:p></o:p></span></font></p>
</span>SIZE MEDIUM<o:p></o:p></span></font></p>
</span>COLOR 0 <span class=3DSpellE>0</span> =
89<o:p></o:p></span></font></p>
font-family:Arial'># Start of <span =
class=3DSpellE>scalebar</span><o:p></o:p></span></font></p>
font-family:Arial'>SCALEBAR<o:p></o:p></span></font></p>
</span>IMAGECOLOR 255 <span
class=3DSpellE>255</span> <span =
</span>COLOR 255 <span class=3DSpellE>255</span> <span =
</span>SIZE tiny<span style=3D'mso-spacerun:yes'> =
80 2<o:p></o:p></span></font></p>
255 <span
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>UNITS =
MILES<o:p></o:p></span></font></p>
</span>INTERVALS 1<o:p></o:p></span></font></p>
</span>TRANSPARENT
TRUE<o:p></o:p></span></font></p>
font-family:Arial'># Start of layer =
definitions<o:p></o:p></span></font></p>
font-family:Arial'>LAYER<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>NAME =
sectional<o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>DATA =
<span
class=3DSpellE>sample.tif</span><o:p></o:p></span></font></p>
font-family:Arial'><span style=3D'mso-spacerun:yes'> </span>TYPE =
RASTER<o:p></o:p></span></font></p>
</span>WMS_TITLE "sectional"<o:p></o:p></span></font></p>
</span>WMS_SRS "EPSG<span =
font-family:Arial'>END # Map File<o:p></o:p></span></font></p>
</div>
</body>
</html>
------=_NextPart_000_008B_01C3B795.B8C16CC0--
