[Mapserver-users] errors loading map
Edward Waithaka
e_talis at yahoo.com
Fri Oct 17 07:17:11 EDT 2003
--0-1559152649-1066389431=:91483
Content-Type: text/plain; charset=us-ascii
Try reinstalling (configuring) the newer version using --with-prefix=/usr , ... this is assuming you had installed it using --with-prefix=/usr/local or you didn't indicate where to install (it defaults to /usr/local/) and you installed using the source code.
Do you Yahoo!?
The New Yahoo! Shopping - with improved product search
Content-Type: text/html; charset=us-ascii
<DIV>Try reinstalling (configuring) the newer version using --with-prefix=/usr , ... this is assuming you had installed it using --with-prefix=/usr/local or you didn't indicate where to install (it defaults to /usr/local/) and you installed using the source code.</DIV><p><hr SIZE=1>
Do you Yahoo!?<br>
<a href="http://shopping.yahoo.com/?__yltc=s%3A150000443%2Cd%3A22708228%2Cslk%3Atext%2Csec%3Amail">The New Yahoo! Shopping</a> - with improved product search
--0-1559152649-1066389431=:91483--
