[Mapserver-users] GetFeatureInfo problem with getting GML back
bartvde at xs4all.nl
Tue Oct 21 05:02:55 EDT 2003
Hi list,
Daniel's solution did the trick for the default info_format. I just added
a tempate tag to a non-existent blank.html file ( TEMPLATE "blank.html" )
GetFeatureInfo results:
Layer 'Prov'
Feature 8:
PROVCODE = '28'
PROVNR = '28'
PROVNAAM = 'Zuid-Holland'
INWONERS = '3360591'
GROEI = '1680'
NLPR_R98_I = '9'
VALUE = '58.000'
But when I do the same request with info_format=application/vnd.ogc.gml I
get:
<?xml version="1.0" encoding="ISO-8859-1"?>
<msGMLOutput
xmlns:gml="http://www.opengis.net/gml"
xmlns:xlink="http://www.w3.org/1999/xlink"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
</msGMLOutput>
So here my info is missing.
Does anybody have an idea what could be the problem?
BTW: with what kind of info_format does Chameleon use to request
GetFeatureInfo?
Best regards,
Bart
From: Daniel Morissette <morissette at dmsolutions.ca>
To: bartvde at xs4all.nl
Subject: Re: [Mapserver-users] GetFeatureInfo problems
Date: Mon, 20 Oct 2003 11:20:07 -0400
bartvde at xs4all.nl wrote:
Hi list,
I have a problem getting results back from a GetFeatureInfo request to a
Mapserver CGI. My layer is a polygon shapefile.
I always get:
Search returned no results.
This is my GetFeatureInfo request:
http://reserve1/cgi-bin/mapserv_40.exe?map=/ms4w/apps/geoservices02/map/
geostreets.map&SERVICE=WMS&VERSION=1.1.0&LAYERS=prov&QUERY_LAYERS=prov&FORMAT=image/
png&TRANSPARENT=TRUE&bbox=50000,350000,250000,550000&srs=EPSG:28992&width=800&height=800&request=GetFeatureInfo&x=300&y=500
If I perform a map request:
png&TRANSPARENT=TRUE&bbox=50000,350000,250000,550000&srs=EPSG:28992&width=800&height=800&request=GetMap
I get the attached map.
Does anybody have an idea what the problem could be?
Thanks in advance.
Best regards,
Bart
Did you set the 'prov' layer to be queryable in the mapfile? To be
queryable a layer needs to have the
TEMPLATE layer (or class) parameter set. You can also tell if the layer
is queryable by looking at the
capabilities. There will be a queryable=0|1 parameter in the <Layer...> tag.
Daniel
