[Mapserver-users] How to view the query results in a separate
frame.
Michael Schulz
mschulz at webgis.de
Tue Oct 21 05:25:30 EDT 2003
i am not sure if a howto exists on this topic.
One way is to use javascript in the query-template, that writes the
attribute results to your other frame when the page is loading (with
onLoad() funtion in the body-tag).
Another way is to redirect the result of the query to the other frame.
Change the target (also via javascript) of your main mapserver form to
your result frame for queries only. But then you don't have the hilited
map in your main frame.
Cheers, Michael
Guillaume MOCCAND wrote:
> Hi List !
> i wonder how i could see the result of an identify query in a diffrent frame
> from the map frame ... i want to still see the map while the data are displayed.
> does anyone have a "howto" on this tips ?
> thanks
> Guillaume MOCCAND
> moccand at ensg.ign.fr
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Michael Schulz in medias res
Dipl.-Geologe Gesellschaft für
Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
0761 55695-95 (Fax 96)
mschulz at webgis.de www.webgis.de/www.zopecms.de
