[Mapserver-users] Zoom In to a defined area
    Jeff L.
    nf10 at hotmail.com
    Tue Sep  2 06:52:47 PDT 2003
Hi Palle,
I tried your suggestion, but an error is posted:
loadForm(): Web application error. Not enough arguments for imgbox
Thanks
Jeff
You should name your <select> imgbox, not viewarea. Also separate your
your coordinates by +, not ,.
Best regards
Palle Due Larsen
Carl Bro GIS&IT
> > Hi,
> > By knowing the map coordinates of a specific area (xMin, yMin, xMax and
> > yMax), i would like to zoom in to such area. I have a combo box with
>defined
> > areas to zoom in, im using CGI and JavaScript to change map extents,
>but no
> > success so far. My question would be how to pass the map extents and
>may be
> > the center of the image is also required to change? Here is my code
>snippet:
> > <SCRIPT LANGUAGE="JavaScript"><!--
> > function AreaSelected()
> >     if (document.forms[0].ViewArea.selectedIndex != 0 &&
> > 	 document.forms[0].ViewArea.selectedIndex !=1)
> >     	document.forms[0].submit();
> > //--></SCRIPT>
> > <form method=GET action="[program]" name=myform>
> > <SELECT NAME="ViewArea"  onChange="AreaSelected()">
> > <OPTION>Go to</OPTION>
> > <OPTION>- - - - - - - - - - - - - </OPTION>
> > <OPTION VALUE="-180,45,180,90">Area 1</OPTION>
> > <OPTION VALUE="-180,0,180,45">Area 2</OPTION>
> > </SELECT >
> > <input type="hidden" name="imgxy" value="299.5 299.5">
> > <input type="hidden" name="imgext" value="[mapext]">
> > </form>
> > Any help is appreciated
> > Jeff Lacoste
> > _________________________________________________________________
> > Protect your PC - get McAfee.com VirusScan Online
> > http://clinic.mcafee.com/clinic/ibuy/campaign.asp?cid=3963
> > Mapserver-users mailing list
> > Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Add photos to your e-mail with MSN 8. Get 2 months FREE*.
http://join.msn.com/?page=features/featuredemail
More information about the MapServer-users
