[Mapserver-users] GetFeatureInfo from selected rectangle???
Howard Mark
MHoward at spaceimaging.com
Tue Sep 2 10:21:12 EDT 2003
In the mapfile, set the
toleranceunits = pixels
tolerance = 1000
This will handle the extend of just about any display.
The WMS call should specify the bbox, X,Y and radius.
I'd make sure the radius (in pixels) is set high enough to cover the bbox
extent, although this does not seem to have an effect on the final result.
Make sure &FEATUREDOUNT=[Maximum Expected Features]
Hope this helps,
Mark
-----Original Message-----
From: Josef Stromský [mailto:Josef.Stromsky.hgf at vsb.cz]
Sent: Wednesday, August 27, 2003 7:19 AM
To: MAPSERVER MailingLIST
Subject: [Mapserver-users] GetFeatureInfo from selected rectangle???
Hi folks.
Im trying to prepare my WMS client to get informations about all geofeatures
in selected rectangle. In getFeatureInfo request im able to pick info about
features on coordinates X, Y, but I need all geofeatures in any rectangle.
Thanks so much for any advice.
yours sincerely
Josef Stromsky
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
This message is intended only for the use of the Addressee and may
contain information that is PRIVILEGED and CONFIDENTIAL.
If you are not the intended recipient, you are hereby notified that any
dissemination of this communication is strictly prohibited. If you have
received this communication in error, please erase all copies of the
message and its attachments and notify Space Imaging immediately.
