[Mapserver-users] Beginner -- What's wrong?
Swaminathan, Gayathri
gayathri at ou.edu
Tue Sep 2 13:19:31 EDT 2003
Mike,
See that you have only one "PROJECTION" definition and that is commented
out....
Is this how the map file is on demo?
Thanks,
-----Original Message-----
From: Michael Smith [mailto:msmith at sanangelompo.org]
Sent: Tuesday, September 02, 2003 11:55 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Beginner -- What's wrong?
I have installed a got working the 3.6 demo of MapServer (windows 2000/IIS
5). When I change the files to insert my shapefiles (tgrds and usa) nothing
appears on the demo screen but I do get the reference map. Here are my
files used can anyone see what I am doing wrong. Thanks.
COSADEMO_INIT.HTML file:
<html>
<head><title>MapServer Demo Interface</title></head>
<body bgcolor="#FFFFFF">
<center><h2>MapServer Demo Interface</h2></center>
<p><hr><p>
Click on the initialize button to fire up the demo with 3 layers turned on
will be accessible for browsing. The data are of Itasca County, MN and were
derived, for the most part, from USGS 1:24,000 quadrangles. Some things to
note are:
<form method=GET action="/scripts/mapserv.exe">
<input type="hidden" name="map"
value="c:\Inetpub\wwwroot\itasca\cosademo.map">
<input type="hidden" name="layer" value="usa">
<input type="hidden" name="layer" value="tgrds">
<input type="hidden" name="zoomsize" value=2>
<input type="hidden" name="program" value="/scripts/mapserv.exe"> <input
type="hidden" name="map_web_imagepath" value="C:\Inetpub\wwwroot\tmp\">
<input type="hidden" name="map_web_imageurl"
value="http://192.168.110.21/tmp/">
<center><input type="submit" value="Initialize"></center>
</form>
<p><hr><p>
</body></html>
COSADEMO.MAP file the last 2 layers are what I added (tgroads and USA): MAP
# Start of map file
NAME "DEMO"
STATUS ON
EXTENT -180.00 -90.0 180.00 90.0
#EXTENT -180.0 -90.0 180.0 90.0
SIZE 600 600
SHAPEPATH "data"
IMAGECOLOR 255 255 255
UNITS DD
# you may need to change this to match your MapServer build
#IMAGETYPE PNG
# Projection definition, consult the PROJ.4 documentation for parameter
discussion
#PROJECTION
# "proj=utm"
# "ellps=GRS80"
# "zone=15"
# "north"
# "no_defs"
# OR:
# "init=epsg:26915"
#END
# Start of web interface definition (including WMS enabling metadata)
WEB
MINSCALE 1000
MAXSCALE 5550000
IMAGEPATH "set in cosademo_init.html"
IMAGEURL "set in cosademo_init.html"
HEADER "demo_header.html"
FOOTER "demo_footer.html"
TEMPLATE "cosademo.html"
METADATA
"WMS_TITLE" "UMN MapServer Itasca Demo"
"WMS_ABSTRACT" "This is the UMN MapServer demonstration application
for Itasca County located in north central Minnesota."
"WMS_ACCESSCONSTRAINTS" "none"
"WMS_ONLINERESOURCE" "http://192.168.110.21/itasca/cosademo_init.html"
"WMS_SRS" "EPSG:26915"
END
END
# Start of reference map
REFERENCE
STATUS ON
IMAGE "graphics/cosarefer.gif"
SIZE 120 120
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END
QUERYMAP
STATUS ON
SIZE 200 200
COLOR 255 0 0
STYLE HILITE
END
# Start of legend
LEGEND
STATUS ON
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
END
# Start of scalebar
SCALEBAR
STATUS TRUE
COLOR 255 255 255
UNITS MILES
INTERVALS 1
SIZE 80 2
STYLE 1
LABEL
SIZE tiny
COLOR 255 255 255
END
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME "circle"
TYPE ELLIPSE
FILLED TRUE
POINTS
1 1
END
END
# Start of layer definitions
LAYER
NAME "ctybdpy2"
STATUS OFF
DATA "ctybdpy2"
TYPE POLYGON
CLASSITEM "cty_name"
METADATA
"WMS_TITLE" "County Boundary"
"WMS_ABSTRACT" "Itasca County boundary shapefile. See
http://deli.dnr.state.mn.us/metadata/full/ctybdne2.html for more
information."
END
CLASS
EXPRESSION "Itasca"
COLOR 225 225 185
OUTLINECOLOR 128 128 128
END
CLASS
# every other county in the state
EXPRESSION /./
COLOR 255 255 255
END
END
LAYER
NAME "mcd90py2"
GROUP "cities"
STATUS OFF
DATA "mcd90py2"
TYPE POLYGON
CLASSITEM "city_name"
HEADER "mcd90py2_header.html"
FOOTER "mcd90py2_footer.html"
# allow GML export
METADATA
"WMS_TITLE" "Minor Civil Divisions"
"WMS_ABSTRACT" "Minor civil divisions for Itasca County.
(boundaries only)"
END
CLASS
NAME "Cities & Towns"
EXPRESSION /./
COLOR 255 225 90
TEMPLATE "mcd90py2.html"
END
END
LAYER
NAME "twprgpy3"
STATUS OFF
DATA "twprgpy3"
TYPE POLYGON
METADATA
"WMS_TITLE" "Township Boundaries"
"WMS_ABSTRACT" "Pulic Land Survey (PLS) township boundaries for
Itasca County. See http://deli.dnr.state.mn.us/metadata/full/twprgne2.html
for more information."
END
CLASS
NAME "Townships"
SYMBOL "circle"
OUTLINECOLOR 181 181 145
SIZE 2
END
END
LAYER
NAME "lakespy2"
STATUS OFF
DATA "lakespy2"
TYPE POLYGON
TOLERANCE 3
HEADER "lakespy2_header.html"
FOOTER "lakespy2_footer.html"
# allow GML export
METADATA
"WMS_TITLE" "Lakes and Rivers"
"WMS_ABSTRACT" "DLG lake and river polygons for Itasca County. See
http://deli.dnr.state.mn.us/metadata/full/dlglkpy2.html for more
information."
END
CLASS
NAME "Lakes & Rivers"
COLOR 49 117 185
TEMPLATE "lakespy2.html"
END
END
# lakes
LAYER
NAME "dlgstln2"
STATUS OFF
DATA "dlgstln2"
TYPE LINE
TOLERANCE 5
HEADER "dlgstln2_header.html"
FOOTER "dlgstln2_footer.html"
# allow GML export
METADATA
"WMS_TITLE" "Streams"
"WMS_ABSTRACT" "DLG streams for Itasca County. See
http://deli.dnr.state.mn.us/metadata/full/dlgstln2.html for more
information."
END
CLASS
NAME "Streams"
COLOR 49 117 185
TEMPLATE "dlgstln2.html"
END
END
# streams
LAYER
NAME "ctyrdln3"
GROUP "roads"
STATUS OFF
DATA "ctyrdln3"
TYPE LINE
MAXSCALE 300000
METADATA
"WMS_TITLE" "County Roads"
"WMS_ABSTRACT" "County roads. (lines only) Derived from MNDOT
roads layer, see http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for
more information."
END
CLASS
COLOR 0 0 0
END
END
# county roads
LAYER
NAME "ctyrdln3_anno"
GROUP "roads"
STATUS OFF
DATA "ctyrdln3"
TYPE ANNOTATION
MAXSCALE 300000
LABELITEM "road_name"
METADATA
"WMS_ABSTRACT" "County roads. (shields only) Derived from MNDOT
more information."
END
CLASS
SYMBOL "symbols/ctyhwy.gif"
COLOR 255 255 255
LABEL
SIZE TINY
POSITION CC
MINDISTANCE 150
MINFEATURESIZE 40
COLOR 0 0 0
END
END
END
# county road annotation
LAYER
NAME "majrdln3"
GROUP "roads"
STATUS OFF
DATA "majrdln3"
TYPE LINE
MAXSCALE 600000
METADATA
"WMS_TITLE" "Highways"
"WMS_ABSTRACT" "Highways- state, US and interstate. (lines only)
Derived from MNDOT roads layer, see
http://deli.dnr.state.mn.us/metadata/full/dotrdln2.html for more
information."
END
CLASS
NAME "Roads"
COLOR 0 0 0
END
END
# highways
LAYER
NAME "majrdln3_anno"
GROUP "roads"
STATUS OFF
DATA "majrdln3"
TYPE ANNOTATION
CLASSITEM "road_class"
MAXSCALE 600000
LABELITEM "road_num"
METADATA
"WMS_ABSTRACT" "Highways- state, US and interstate. (shields only)
information."
END
CLASS
EXPRESSION "3"
# dummy color
SYMBOL "symbols/sthwy.gif"
COLOR 0 0 0
LABEL
SIZE TINY
POSITION CC
MINDISTANCE 150
MINFEATURESIZE 50
COLOR 0 0 0
END
END
CLASS
EXPRESSION "2"
# dummy color
SYMBOL "symbols/ushwy.gif"
COLOR 0 0 0
LABEL
SIZE TINY
POSITION CC
MINDISTANCE 150
MINFEATURESIZE 50
COLOR 0 0 0
END
END
CLASS
EXPRESSION "1"
# dummy color
SYMBOL "symbols/interstate.gif"
COLOR 0 0 0
LABEL
SIZE TINY
POSITION CC
MINDISTANCE 150
MINFEATURESIZE 50
COLOR 255 255 255
END
END
END
# highway annotation
LAYER
NAME "airports"
STATUS OFF
DATA "airports"
TYPE POINT
TOLERANCE 5
HEADER "airports_header.html"
FOOTER "airports_footer.html"
METADATA
"WMS_TITLE" "Airports"
"WMS_ABSTRACT" "Airport runways for Itasca County."
END
CLASS
NAME "Airports"
SYMBOL "circle"
COLOR 128 255 164
SIZE 7
TEMPLATE "airports.html"
END
END
LAYER
NAME "cities"
STATUS OFF
DATA "mcd90py2"
TYPE ANNOTATION
LABELITEM "city_name"
LABELMAXSCALE 500000
METADATA
(annotation only)"
END
CLASS
EXPRESSION /./
COLOR -1 -1 -1
LABEL
TYPE BITMAP
SIZE MEDIUM
POSITION CC
BUFFER 2
COLOR 0 0 0
SHADOWCOLOR 218 218 218
SHADOWSIZE 2 2
PARTIALS FALSE
END
END
END
LAYER
NAME "tgroads"
STATUS ON
DATA "tgrds"
TYPE LINE
CLASSITEM "Street"
UNITS DD
END
LAYER
NAME "usa"
STATUS DEFAULT
DATA "usa"
TYPE POLYGON
UNITS DD
END
END
COSADEMO.HTML template file:
<html>
<body bgcolor=#FFFFFF>
<center><h1>MapServer Demo Interface</h1></center>
<hr>
<form method=GET action="[program]">
<center>
<table border=0 cellspacing=0 cellpadding=4 bgcolor="#000000"> <tr> <td
valign="top" align=center>
<table cellpadding="0" cellspacing="0" border="0">
<tr><td colspan="2"><INPUT NAME="img" TYPE="image" SRC="[img]" width=600
height=600 border=0></td></tr>
<tr>
<td> <font size=-1 face="arial,helvetica"
color="#FFFFFF"><b>Powered by MapServer</b></font></td>
<td align="right"><img src="[scalebar]"></td>
</tr>
</table>
</td>
<td valign="top" bgcolor=#ffffff>
<table cellpadding="5" cellspacing="0" border="0" bgcolor="#ffffff">
<tr><td>
<center><input type="submit" value="Refresh/Query"></center>
<p>
<input type="radio" name="mode" value="browse" checked> <b>Browse
map</b><br>
<input type="radio" name="mode" value="query"> <b>Query
feature</b><br>
<input type="radio" name="mode" value="nquery"> <b>Query multiple
features</b>
<hr>
<p>
<b>Select Layers to Display: </b><br>
<select multiple name="layer" size=3>
<option value="airports" [airports_select]> Airports
<option value="cities" [cities_select]> Cities
<option value="lakespy2" [lakespy2_select]> Lakes & Rivers
<option value="dlgstln2" [dlgstln2_select]> Streams
<option value="tgrds" [tgrds_select]> Roads
<option value="usa" [usa_select]> USA
</select>
<p>
Zoom In <input type=radio name=zoomdir value=1 [zoomdir_1_check]>
Pan <input type=radio name=zoomdir value=0 [zoomdir_0_check]>
Zoom Out <input type=radio name=zoomdir value=-1 [zoomdir_-1_check]>
<p>
Zoom Size <input type=text name=zoomsize size=4 value=[zoomsize]>
<p>
<font size=+1><b>Legend</b></font><br><hr>
<img src="[legend]"><hr>
<p>
<center><INPUT NAME="ref" TYPE="image" SRC="[ref]"
border="0"></center>
</td></tr></table>
</td></tr>
</table>
</center>
<input type="hidden" name="imgxy" value="299.5 299.5">
<input type="hidden" name="imgext" value="[mapext]">
<input type="hidden" name="map" value="[map]">
<input type="hidden" name="savequery" value="true">
<input type="hidden" name="program" value="[program]">
<input type="hidden" name="map_web_imagepath" value="[map_web_imagepath]">
<input type="hidden" name="map_web_imageurl" value="[map_web_imageurl]">
</form>
<p><hr><p>
</body></html>
Michael Smith, Planner II
City of San Angelo
Planning & Development
325.657.4210 Fax: 325.481.2648
Email: msmith at sanangelompo.org
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
