[Mapserver-users] PHP MapScript problem (use of undefined constant)
Geoffrey Rowland
geoffrey.rowland at noaa.gov
Tue Sep 2 14:46:40 EDT 2003
This is a multi-part message in MIME format.
--------------020104020707010103090708
Content-Type: text/plain; charset=us-ascii; format=flowed
Content-Transfer-Encoding: 7bit
Notice: Use of undefined constant MS_SWF - assumed 'MS_SWF' in
D:\Inetpub\CIP ROOT BETA\wnv\wnv_pop.php on line 4
this will have the same notice no matter what type of file i try to
output...and the image doesn't output (nothing is written in the
directory that i specified to use in my map file). any idea what may be
causing this?
$map = ms_newMapObj("pop.map");
$image=$map->draw();
$image_url=$image->saveWebImage(MS_SWF,1,1,0);
<HTML>
<HEAD>
<TITLE>Example 1: Displaying a map</TITLE>
</HEAD>
<BODY>
<IMG SRC=<?php echo $image_url; ?> >
</BODY>
</HTML>
map file
# Start of map file
NAME "PopTest"
STATUS ON
SIZE 600 600
EXTENT -178.227822 18.913826 -66.949831 71.38269
UNITS dd
SHAPEPATH "data"
IMAGECOLOR 255 255 255
#IMAGETYPE PNG
OUTPUTFORMAT
NAME swf
MIMETYPE "application/x-shockwave-flash"
DRIVER swf
IMAGEMODE PC256
FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
END
#PROJECTION
# "proj=latlong"
#END
WEB
HEADER us_header.html
TEMPLATE temp.html
FOOTER us_footer.html
LOG popmapserver.log
MINSCALE 1
MAXSCALE 36335600
IMAGEPATH "d:/Inetpub/pop/swf/"
IMAGEURL "http://localhost/pop/swf/"
METADATA
WMS_TITLE "United States County Data"
WMS_ABSTRACT "This is a demonstration of using Mapserver to display
the County data set."
WMS_ACCESSCONSTRAINTS none
WMS_SRS "EPSG:4269"
END # End Metadata
END # End Web
QUERYMAP
SIZE 200 200
STATUS ON
STYLE HILITE
COLOR 255 0 0
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
LABEL
COLOR 255 255 255
SIZE tiny
END
STYLE 1
SIZE 80 2
COLOR 255 255 255
UNITS MILES
INTERVALS 1
TRANSPARENT TRUE
STATUS TRUE
END
LAYER
NAME states
METADATA
"DESCRIPTION" "States"
"RESULT_FIELDS" "State_Name Pop1999"
"SWFDUMPATTRIBUTES" "State_Name,Pop1999"
END
TYPE POLYGON
STATUS ON
DATA states
CLASSITEM 'Pop1999'
NAME Pop1999
TEMPLATE us_pop.html
CLASS
EXPRESSION ([Pop1999] > 0 and [Pop1999] < 2135252)
COLOR 254 240 217
OUTLINECOLOR 128 128 128
END
CLASS
EXPRESSION ([Pop1999] > 2135251 and [Pop1999] < 4970311)
COLOR 253 212 158
END
CLASS
EXPRESSION ([Pop1999] > 4970310 and [Pop1999] < 9866640)
COLOR 253 187 132
END
CLASS
EXPRESSION ([Pop1999] > 9866639 and [Pop1999] < 20127338)
COLOR 252 141 89
END
CLASS
EXPRESSION ([Pop1999] > 20127337 )
COLOR 227 74 51
END
END # end class
END # end layer
END # end Map File
Geoffrey Rowland
Technical Officer
Climate Information Project
NOAA Research
Office of Global Programs
http://www.cip.ogp.noaa.gov
Contractor,
RGII Technologies, Inc., a Computer Horizons Company
http://www.rg2.com
Phone: 301-427-2089x186
Fax : 301-427-2082
Content-Type: text/html; charset=us-ascii
<!DOCTYPE html PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta http-equiv="Content-Type" content="text/html;charset=ISO-8859-1">
<title></title>
</head>
<body text="#000000" bgcolor="#ffffff">
<b>Notice</b>: Use of undefined constant MS_SWF - assumed 'MS_SWF' in <b>D:\Inetpub\CIP
ROOT BETA\wnv\wnv_pop.php</b> on line <b>4<br>
<br>
</b>this will have the same notice no matter what type of file i try to
be causing this?<br>
<br>
<?<br>
$map = ms_newMapObj("pop.map");<br>
$image=$map->draw();<br>
$image_url=$image->saveWebImage(MS_SWF,1,1,0);<br>
<br>
?><br>
<br>
<HTML><br>
<HEAD><br>
<TITLE>Example 1: Displaying a map</TITLE><br>
</HEAD><br>
<BODY><br>
<IMG SRC=<?php echo $image_url; ?> ><br>
</BODY><br>
</HTML><br>
<br>
map file<br>
<br>
#<br>
# Start of map file<br>
#<br>
NAME "PopTest"<br>
STATUS ON<br>
SIZE 600 600<br>
EXTENT -178.227822 18.913826 -66.949831 71.38269<br>
UNITS dd<br>
SHAPEPATH "data"<br>
IMAGECOLOR 255 255 255<br>
<br>
<br>
#IMAGETYPE PNG<br>
<br>
OUTPUTFORMAT <br>
NAME swf <br>
MIMETYPE "application/x-shockwave-flash" <br>
DRIVER swf <br>
IMAGEMODE PC256 <br>
FORMATOPTION "OUTPUT_MOVIE=MULTIPLE" <br>
END <br>
<br>
<br>
#PROJECTION<br>
# "proj=latlong"<br>
#END<br>
<br>
WEB<br>
HEADER us_header.html<br>
TEMPLATE temp.html<br>
FOOTER us_footer.html<br>
LOG popmapserver.log<br>
MINSCALE 1<br>
MAXSCALE 36335600 <br>
IMAGEPATH "d:/Inetpub/pop/swf/"<br>
IMAGEURL <a class="moz-txt-link-rfc2396E" href="http://localhost/pop/swf/">"http://localhost/pop/swf/"</a><br>
METADATA<br>
WMS_TITLE "United States County Data"<br>
the County data set."<br>
WMS_ACCESSCONSTRAINTS none<br>
<br>
WMS_SRS "EPSG:4269"<br>
END # End Metadata<br>
END # End Web <br>
<br>
QUERYMAP<br>
SIZE 200 200<br>
STATUS ON<br>
STYLE HILITE<br>
COLOR 255 0 0<br>
END<br>
<br>
<br>
#<br>
# Start of legend<br>
#<br>
LEGEND<br>
KEYSIZE 18 12<br>
LABEL<br>
TYPE BITMAP<br>
SIZE MEDIUM<br>
COLOR 0 0 89<br>
END<br>
STATUS ON<br>
END<br>
<br>
#<br>
# Start of scalebar<br>
#<br>
SCALEBAR<br>
LABEL<br>
SIZE tiny <br>
END<br>
STYLE 1<br>
SIZE 80 2<br>
UNITS MILES<br>
INTERVALS 1<br>
TRANSPARENT TRUE<br>
STATUS TRUE<br>
END<br>
<br>
<br>
<br>
<br>
LAYER<br>
NAME states<br>
METADATA<br>
"DESCRIPTION" "States"<br>
"RESULT_FIELDS" "State_Name Pop1999"<br>
"SWFDUMPATTRIBUTES" "State_Name,Pop1999"<br>
END<br>
TYPE POLYGON<br>
STATUS ON<br>
DATA states<br>
<br>
<br>
CLASSITEM 'Pop1999'<br>
NAME Pop1999<br>
TEMPLATE us_pop.html<br>
CLASS<br>
EXPRESSION ([Pop1999] > 0 and [Pop1999] < 2135252)<br>
COLOR 254 240 217<br>
OUTLINECOLOR 128 128 128<br>
END<br>
<br>
CLASS<br>
EXPRESSION ([Pop1999] > 2135251 and [Pop1999] < 4970311)<br>
COLOR 253 212 158<br>
END<br>
<br>
CLASS<br>
EXPRESSION ([Pop1999] > 4970310 and [Pop1999] < 9866640)<br>
COLOR 253 187 132<br>
END<br>
<br>
CLASS<br>
EXPRESSION ([Pop1999] > 9866639 and [Pop1999] < 20127338)<br>
COLOR 252 141 89<br>
END<br>
<br>
CLASS<br>
EXPRESSION ([Pop1999] > 20127337 )<br>
COLOR 227 74 51<br>
END<br>
<br>
<br>
<br>
END # end class<br>
<br>
END # end layer<br>
<br>
<br>
END # end Map File<br>
<pre class="moz-signature" cols="72">--
Geoffrey Rowland
Technical Officer
NOAA Research
<a class="moz-txt-link-freetext" href="http://www.cip.ogp.noaa.gov">http://www.cip.ogp.noaa.gov</a>
Contractor,
<a class="moz-txt-link-freetext" href="http://www.rg2.com">http://www.rg2.com</a>
Fax : 301-427-2082
<a class="moz-txt-link-abbreviated" href="mailto:geoffrey.rowland at noaa.gov">geoffrey.rowland at noaa.gov</a>
</pre>
</body>
</html>
--------------020104020707010103090708--
