[Mapserver-users] SWF Output formatoption Single vs Multiple
Yewondwossen Assefa
assefa at dmsolutions.ca
Thu Sep 4 13:37:24 EDT 2003
I have put a new mapserver/php-mapscript windows binaries with the
latest mapserver source code at :
http://www.maptools.org/php_mapscript/index.phtml?page=downloads.html
(in section developpment version)
Later,
Geoffrey Rowland wrote:
> great, that fixed the problem..thanks!!
> Geoff
> Yewondwossen Assefa wrote:
>> I will do an update with the latest source code and let you know. It
>> should be working then (at least tha specific bug is working with my
>> test data). I have attached a php_mapscript_40.dll (build for
>> php4.3.2) that I use so you can give it a try while I build the full
>> package.
>> Later,
>>> I'm using the latest windows binaries.
>>>> There was a bug corrected August 8 on that. Are you using the latest
>>>> version ?
>>>> Later,
>>>>> Hello,
>>>>> In my .map file, if have the FORMATOPTION "OUTPUT_MOVIE=MULTIPLE",
>>>>> my php script generates the SWF correctly. However if I change
>>>>> MULTIPLE to SINGLE, then I get a Fatal Error saying it failed
>>>>> writing the image. Am I missing something?
>>>>> OUTPUTFORMAT
>>>>> NAME swf
>>>>> MIMETYPE "application/x-shockwave-flash"
>>>>> DRIVER swf
>>>>> IMAGEMODE PC256
>>>>> FORMATOPTION "OUTPUT_MOVIE=SINGLE"
>>>>> END
>>>>> $map_path="d:/inet/site/pop/";
>>>>> $map = ms_newMapObj($map_path."swf_pop.map");
>>>>> $map->selectOutputFormat("SWF");
>>>>> $image=$map->draw();
>>>>> $image_url=$image->saveWebImage();
>>>>> _______________________________________________
>>>>> Mapserver-users mailing list
>>>>> Mapserver-users at lists.gis.umn.edu
>>>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
