[Mapserver-users] Weather / Climate information using MapServer
Gerry Creager N5JXS
gerry.creager at tamu.edu
Thu Sep 4 23:49:48 EDT 2003
http://mesonet.tamu.edu/currentwx.html
And, then check out the links to the left side of the page...
Gerry
Frank Warmerdam wrote:
> Geoffrey Rowland wrote:
>> Anyone doing this? Specifically I'm trying to get min/max temps and
>> precip layers on top of a shp file I am using. I have some data from
>> NOAA, however I'm not familair with it's format. I can open it up in
>> GrADS and view the data on a map, so I would think *in theory* I
>> should be able to get this data into a format that mapserver can work
>> with, I'm just not sure how to go about doing that. I also have access
>> to safe softwares feature manipulation engine if that would be of any
>> help (for translations). Can anyone point me in the right direction?
>> I am getting the data from the following locations
>> precip
>> ftp://ftpprd.ncep.noaa.gov/pub/precip/wd52ws/us_daily/
> Geoffrey,
> The data files are "raw" floating point according to the README. It would
> be pretty easy to write a GDAL compatible .aux file describing them. I
> can
> help with that offline if you can't find enough info in the GDAL "PAux"
> format
> page.
> But because the data is not 8bit raster there are issues with how it will
> get displayed in MapServer. You can let MapServer rescale the data to 8bit
> on the fly, but depending on how exact you want to be you might be
> better off
> reclassifying it outside mapserver first. Note that MapServer does not
> currently support raster classes for raster values outside the range 0-255
> even though that might be ideal for situations like this.
> Best regards,
Gerry Creager -- gerry.creager at tamu.edu
Texas Mesonet -- AATLT, Texas A&M University
Cell: 979.229.5301 Office: 979.458.4020 FAX: 979.847.8578
Page: 979.228.0173
Office: 903A Eller Bldg, TAMU, College Station, TX 77843
