[Mapserver-users] Corollary to the McNierney Principal (or setting up Windows
2003)
Richard Greenwood
Rich at GreenwoodMap.com
Fri Sep 5 21:32:52 EDT 2003
Ed McNierney always points out the best way to achieve high performance is
to serve (and process) little or no data. In Ed's own words: "Absolutely,
guaranteed the fastest - no data at all. It renders in zero time on even
the slowest machines!" (see
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0301/msg00023.html).
Words of wisdom, and I have respectfully dubbed this the "McNierney Principal".
I suspect that someone at Microsoft has followed Ed's logic and applied it
to the security features in Windows 2003 Server / IIS 6.0. Here's the
story. Earlier this week I had the displeasure of setting up Mapserver on a
Windows 2003 / IIS 6.0 server. I've setup Mapserver on IIS enough times to
be confident with the process, and I had a laptop with a functioning IIS /
Mapserver installation at my side. But all I could get from the Windows
2003 / IIS 6.0 server was 404 errors.
To make a long story short, Server 2003 and/or IIS 6 has a new top level
"Web Service Extensions node" which has all dynamic content turned off by
default. (A server that servers little or nothing is secure, hence the
corollary to the McNierney Principal (and I think that a computer that is
turned off may be even more secure)).
You can enable scripting and executables in all the usual IIS places for
individual virtual directories or entire web sites, but the top level
default setting for the computer will over-ride your settings for all web
sites and virtual directories. And IIS Service Manager will give you no
clue that that it is doing this aside from generating 404 errors. The
relevant MS pages are:
http://www.microsoft.com/technet/treeview/default.asp?url=/technet/prodtechnol/windowsserver2003/proddocs/standard/ca_enabledynamiccontent.asp
http://www.microsoft.com/technet/treeview/default.asp?url=/technet/prodtechnol/windowsserver2003/proddocs/standard/ca_configcgi.asp
If you have read this far, I hope you realize that:
1. I am ranting (and I have a 12 oz aluminum can at hand)
2. I have the upmost respect for Ed McNierney
3. I have some disdain for Microsoft
Have a good weekend,
Rich
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
