[Mapserver-users] MapServer and CGI Error under IIS 5
Steve Lime
steve.lime at dnr.state.mn.us
Mon Sep 8 10:50:42 EDT 2003
Stable yes, but not free of bugs. If you can make note of exactly what
was going on that would help. If you are just running the demo then
simply saving the URL would suffice.
Steve
>>> "Jeff L." <nf10 at hotmail.com> 09/08/03 08:27AM >>>
The demo is working, but not all the times. When I tried it some times
it
works. Other times it give me the header CGI error. I'm using the same
demo
with the same commands. Randmoly it's works but also randomly it's
produces
header CGI error. As MapServer 4.0 is taged stable, probably this error
is
the result of the IIS. I'm not sure.
Jeff Lacoste
>From: "Swaminathan, Gayathri" <gayathri at ou.edu>
>To: "'Jeff L.'" <nf10 at hotmail.com>
>CC: "'mapserver-users at lists.gis.umn.edu'"
><mapserver-users at lists.gis.umn.edu>
>Subject: RE: [Mapserver-users] MapServer and CGI Error under IIS 5
>Date: Mon, 8 Sep 2003 08:15:13 -0500
>Hi,
>Did you check if it ran well under command prompt?
>When you enter in command prompt, "mapserv -v" it should give version
and
>other details. If it is missing dlls in C:\<windows dir>\system32 it
will
>tell you at this stage. And this is one reason for it to give the
error
>message, "CGI Error
>The specified CGI application misbehaved by not returning a complete
set of
>HTTP headers. The headers it did return are:".
>Good luck,
>Gayathri
>-----Original Message-----
>From: Jeff L. [mailto:nf10 at hotmail.com]
>Sent: Sunday, September 07, 2003 7:17 PM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] MapServer and CGI Error under IIS 5
>Hi,
>I installed MapServer 4 on a windows 2000 machine with IIS 5. I edited
the
>demo path.
>Whe I run the demo, some times it works (an image is produced), but
some
>times i have an error:
>"CGI Error
set of
>This error occurs randomly and i was wondering if any one had this
kind of
>error. What would be the cause and eventuelly if there is any way to
fix
>it.
>Thanks in advance for any information
>Jeff Lacoste
>_________________________________________________________________
>Add photos to your messages with MSN 8. Get 2 months FREE*.
>http://join.msn.com/?page=features/featuredemail
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
The new MSN 8: smart spam protection and 2 months FREE*
http://join.msn.com/?page=features/junkmail
