[Mapserver-users] Frames
Palle Due Larsen
palle at mail-online.dk
Tue Sep 9 08:46:56 EDT 2003
Your TEMPLATE should still be demo.html. All mapserver CGI can do is
read a template file, substitute stuff in square brackets with stuff it
knows about, and output the result to the client. In your example you
are not asking mapserver to substitute anything. You can see a frames
example at http://vestamt.carlbro.dk (in Danish). The index.html file is
plain HTML, the header frame is from another site, the menu frame is
generated by a perl script, and the content frame is generated by
mapserver CGI.
Best regards
Palle Due Larsen
Carl Bro GIS&IT
-----Original Message-----
To: mapserver-users at lists.gis.umn.edu
Date: Tue, 09 Sep 2003 09:56:40 +0800
Subject: [Mapserver-users] Frames
> Hi All,
> I've tried (with no luck) to implement a simple mapserver app. using
> frames, but since I am a novice in Javascript, I need your help.
> I have a launching app called demo_init.html that contains -
> <form method=GET name = "mapserv" action="/cgi-bin/mapserv.exe">
> <input type="hidden" name="map" value="C:\Inetpub\wwwroot\demo.map">
> <input type="hidden" name="layer" value="roads">
> <input type="hidden" name="zoomsize" value=2>
> <input type="hidden" name="program" value="/cgi-bin/mapserv.exe">
> <input type="hidden" name="map_web_imagepath"
> value="C:\inetpub\wwwroot\tmp\">
> <input type="hidden" name="map_web_imageurl" value="/tmp/">
> <center><input type="submit" value="Initialize"></center>
> And I have the file Demo.html -
> <form method=GET action="[program]">
> <INPUT NAME="img" TYPE="image" SRC="[img]" width=600 height=600
> border=0>
> and a few other mapserver lines like -
> <option value="roads" [roads_select]> Roads
> <INPUT NAME="ref" TYPE="image" SRC="[ref]" border="0">
> etc.
> In my map file, I have -
> TEMPLATE Demo.html
> Now, I created a Main.html that has two frames (Left and Right)
> <FRAMESET cols="230,*">
> <FRAME src="http://localhost/LeftFrame.html" name="Left" >
> <FRAME src="http://localhost/Demo.html" name="Demo">
> </FRAMESET>
> And changed the map file to -
> TEMPLATE Main.html
> But this does not work. any help would be welcomed!
> Thanks
Få en gratis emailkonto her: www.mail-online.dk
Deltag i en lille konkurrence på nettet, og
vind et gavekort på 50.000 kroner...
KLIK HER: www.directoffice.dk/konkurrence
