[Mapserver-users] RE: WMS problems
Daniel Morissette
morissette at dmsolutions.ca
Tue Sep 9 09:55:43 EDT 2003
If I remember correctly, Ed's problem with the SRS parameter (a buffer
overflow) was fixed in version 3.6.4, so you are quite likely already
running the fixed verison and may have run into something else.
Daniel
Ed McNierney wrote:
> Gayathri -
> Then you'll benefit from the same bug fix that I did <g>. This was fixed (by Daniel, I think) quite some time ago - you'll need to update your MapServer build to get the bug fix.
> - Ed
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com
> -----Original Message-----
> From: Swaminathan, Gayathri [mailto:gayathri at ou.edu]
> Sent: Tue 9/9/2003 7:53 AM
> To: Ed McNierney
> Cc: 'mapserver-users at lists.gis.umn.edu'
> Subject: WMS problems
> Hi:
> I am having the problems, Ed was having sometime ago,to project WMS right
> with SRS...the same problem as mentioned by Ed in this link below :
> http://lists.dmsolutions.ca/pipermail/mapserver-users/2002-October/004741.ht
> ml
> I am using mapserver-3.6.5 with WMS server and client.Please let me know,
> how to, overcome this error.
> Thanks,
> Gayathri
