[Mapserver-users] setting layers on/off using phpmapscript
Vinko Vrsalovic
vinko at cprsig.cl
Tue Sep 9 12:36:29 EDT 2003
On Tue, Sep 09, 2003 at 11:31:20AM -0400, Geoffrey Rowland wrote:
> Am I doing something wrong? The following code gives me an error.
> Since I don't have 78 lines of code in my php file, I'm assuming
> something in my .map file may be causing this error. However if I take
> out the php code trying to set the layer status, the map will render fine.
> Fatal error: Object expected as argument. in
> D:\Inetpub\rootbeta\map_engine\wnvfetchmap.php on line 78
> $myMap = ms_newMapObj("wnv.map");
> $countyLayer = $myMap->getlayerbyname(counties);
$countyLayer = $myMap->getlayerbyname('counties'); <-- As STRING
Vinko Vrsalovic <el[|- at -|]vinko.cl>
http://www.cprsig.cl
