[Mapserver-users] LabelAngleItem
Daniel Morissette
morissette at dmsolutions.ca
Wed Sep 10 13:32:58 EDT 2003
We've seen this problem before, and the solution is somewhere in the
list archives but I can't track it down. You're using a recent RedHat
release, right? If I remember correctly, the problem was solved by
removing the freetype-devel RPMs on the system, then downloading and
installing the latest freetype release from source and rebuilding GD
2.0.x using it, and finally rebuilding MapServer with this new GD.
Daniel
Manuel Marichal Pérez wrote:
> Hi all. I'm having some troubles using the LABELANGLEITEM
> property.
> As far as I know, this propoterty allow you to rotate the text
> labels using a field which is in the ".dbf" file.
> My problem is that not only the text rotate but also letters
> itself. You can see what I mean if you look at to the attachment
> file.
> Anybody can help me?
> Here is an extract of my .map file
> LAYER TEXTSAMPLE
> NAME "street"
> DATA txt_street
> STATUS ON
> TYPE ANNOTATION
> LABELITEM "NAME"
> LABELANGLEITEM "DEGREES"
> CLASS
> LABEL
> COLOR 0 0 0
> SHADOWSIZE -1 -1
> POSITION CC
> PARTIALS FALSE
> BUFFER 1
> SHADOWCOLOR 255 255 255
> SIZE 12
> MINSIZE 7
> MAXSIZE 10
> TYPE TRUETYPE
> FONT arial
> ANTIALIAS TRUE
> ANGLE AUTO
> FORCE TRUE
> END
> END
> END
> Thanks a lot in advance,
> Manolo
> marichalperez at yahoo.es
