[Mapserver-users] legend question
Charlton Purvis
cpurvis at asg.sc.edu
Wed Sep 10 15:07:07 EDT 2003
This is a multi-part message in MIME format.
------_=_NextPart_001_01C377CE.BA9FE116
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Hi, Damian:
That's not as easy to do, but I do it frequently. But let me make sure
I understand what you want to do:
[x] Group1Name
Class1
Class2
Class3
[x] Group2Name
Is that right?
If so, I do it by sneaking in a few METADATA variables inside my LAYER
and also making the legend use fixed images (i.e. don't allow MapServer
to use the ones it creates on-the-fly). To go into all the gory detail
would be, well, gory. So I'll just throw some code at you and give you
a few points.
.map
# I want to show=20
# [x] speed bari absolute diff power2
# color_block class 1
# color_block class 2
# etc.
LAYER
NAME "speed_bari_absolute_diff"
GROUP "speed_bari_absolute_diff"
STATUS OFF
DATA "the_geom from domain_intersect"
TYPE POINT
CONNECTIONTYPE POSTGIS
CONNECTION "user=3Dpostgres dbname=3DmyGISdb host=3Dlocalhost"
SYMBOLSCALE 10000000
TOLERANCE 4000
TOLERANCEUNITS meters
TEMPLATE "ttt"
METADATA
no_icon "ttt"
list_icons "ttt"
query_cols "xi yi unc_speed_bari um_speed_bari usf_speed_bari
speed_bari_dif_abs speed_bari_dif_per"
END
Now look at the attached .html file. It's ugly! And the resulting html
(after it is parsed) is even worse! I'm going to have to think of
something slicker before I use it real-time. As a matter of fact, I
don't think I'll use this solution, at all.
But until then . . .
* Usual checkbox if/then stuff, but I look for a metadata variable,
no_icon, to see if it is set. If it is, then I don't want this group to
have an icon at the group checkbox level. Just the checkbox, please.
(use_icon means I do want a group-level icon. Follow the use_icon isset
stuff to see that the image URL is placed at this point. All the
javascript junk is to remove the underscores.
* Write the group name. Same javascript underscore junk.
* Now in the class level, I have hard coded checks for layer names. So
if we're looking at the speed_bari_percent_diff layer, show the class
icons which are hard coded the same way as the group icons in the first
bullet.
I realize that I'm just throwing stuff at you, and that's not completely
helpful. If you want more details, say the word.
Charlton
> -----Original Message-----
> From: Map Surfers [mailto:map_surfer at yahoo.com]
> Sent: Tuesday, September 09, 2003 3:32 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] legend question
>=20
> How would I make it so that the classes only displayed
> if a user selected the layer/group to display?
>=20
> [leg_group_html]
> <tr>
> <td colspan=3D"2" bgcolor=3D"#CCCCCC"><font
> face=3D"Verdana, Arial, Helvetica" size=3D"-1">
> <input type=3D"checkbox" name=3D"layer_status[]"
> value=3D"[layer_group_name]" [if name=3Dlayer_status
> oper=3Deq value=3D1]CHECKED[/if][if name=3Dlayer_status
> oper=3Deq value=3D2]CHECKED[/if]>
> <b>[leg_group_name]</b>
> </font></td>
> </tr>
> [/leg_group_html]
>=20
> [leg_class_html]
> <tr>
> <td align=3D"center" valign=3D"top"><font face=3D"Verdana,
> <img src=3D"[leg_icon width=3D18 height=3D10]"
> width=3D"20" height=3D"10">
> </font></td>
> <td><font face=3D"Verdana, Arial, Helvetica"
> size=3D"-1">
> [leg_class_name]
> </font></td>
> </tr>
> [/leg_class_html]
>=20
> TIA,
>=20
> Damian
name="legend_template.html.txt"
Content-Transfer-Encoding: base64
Content-Description: legend_template.html.txt
Content-Disposition: attachment;
filename="legend_template.html.txt"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------_=_NextPart_001_01C377CE.BA9FE116--
