[Mapserver-users] RE: Mapserver-users] raster
Steve Lime
steve.lime at dnr.state.mn.us
Wed Sep 10 18:23:18 EDT 2003
Not quite true. Native tiff supports geotiff too. The key is that
non-geotiff tiff images
require some sort of a world file regardless of the raster engine. GDAL
may support
other forms of providing that georeferencing information. Otherwise
neither
GDAL or MapServer can know how to place the image in the world.
Steve
>>> Paul Ramsey <pramsey at refractions.net> 09/10/03 04:47PM >>>
Hi Ann,
If you are using GDAL, no world file required.
If you are using the Mapserver native TIFF support, you will need a
world file.
Mapserver image support can be quite confusing because of the different
ways (GDAL, not-GDAL) available for doing the same thing (read a
TIFF).
Yours,
Paul
Ann Keane wrote:
> Michael-
> I don't know if your file needs a world file, I'm very new to this as
> well. The world file is described at the bottom of:
> http://mapserver.gis.umn.edu/doc40/raster-howto.html
> I have gdal installed and used gdalinfo <datafile.tif> to determine
the
> file's coordinates. This will also show you if the EXTENT setting in
> the map file is correct.
> Would any of the wizards let us know if mapserver requires a world
file
> if the file is not a geotiff?
> -Ann
__
| Paul Ramsey
| Refractions Research
| Email: pramsey at refractions.net
| Phone: (250) 885-0632
\_
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
