[Mapserver-users] seg fault
Daniel Morissette
morissette at dmsolutions.ca
Thu Sep 11 15:22:35 EDT 2003
Nick Petersen-Bergeron wrote:
> Aha! I've narrowed down the problem further. It seems that I'm only
> able to open 2 shapefiles in a single instance of a perl program
> running. As soon as I try and open a 3rd, boom! Seg fault.
> Nick
Um... I can open 3 shapefiles using PHP MapScript (4.0 and 3.6) without
any problem. Perhaps it's a Perl-specific issue, or it's realted to the
order in which your script does things?
If you have a way to reproduce this, then you should probably file this
in bugzilla, with sample data and script to reproduce, MapServer
version, OS, etc.
Daniel
>>> To clarify, the file DOES already exist, and seems to be a valid
>>> shapefile.
>> Assuming that you are able to read the shapefile using something like
>> shapelib's shpdump utility, My next suggestion would be to try to
>> isolate the exact lines that cause the problem. Does the following
>> also seg fault?
>> #!/usr/bin/perl
>> use mapscript;
>> use XBase;
>> my $SFile = "/home/httpd/cgi-bin/dm/shapes/S941604";
>> my $SShapeFile = new shapefileObj($SFile,-1);
>> Daniel
>> Daniel Morissette morissette at dmsolutions.ca
>> DM Solutions Group http://www.dmsolutions.ca/
> System Administrator
> ZedX Inc.
> 369 Rolling Ridge Drive
> Bellefonte, PA. 16823
