[Mapserver-users] RE: Problem in setting Mapserver up on windows 2003
Richard Greenwood
Rich at GreenwoodMap.com
Fri Sep 12 10:45:39 EDT 2003
Chris,
I am copying the mapserver-user list with this email as someone may have a
better answer than I do. (List - this thread reads from the bottom up).
It sounds like your problem is with IIS configuration then. Did you grant
the two additional privileges to the IIS_WPG as described in:
http://www.microsoft.com/technet/treeview/default.asp?url=/technet/prodtechnol/windowsserver2003/proddocs/standard/ca_configcgi.asp
Rich
At 10:39 PM 9/12/2003 +0800, Chris Fung wrote:
>Hi Rich,
>Thanks for you help. The below two tests work, but I get the same error. I
>have do the below things:
>1. set the properties of folder cgi-bin to be executed
>2. allow CGI and ISAPI extensions.
>3. grant everyone, IUSR and IIS_WPG to read and execute right
>What else I should set?
>Regards,
>Chris
>-----Original Message-----
>From: Richard Greenwood [mailto:Rich at GreenwoodMap.com]
>Sent: Friday, September 12, 2003 9:31 PM
>To: Chris Fung
>Subject: Re: Problem in setting Mapserver up on windows 2003
>First check that mapserv can run at all: at a command propmt (DOS prompt) try:
> mapserv -v
>It should show version information. Then try:
> mapserv QUERY_STRING="map=c:\path\to\mapfile.map"
>It should display the HTML for your page.
>If the above two tests work, then mapserv is working and you have a problem
>with IIS, if the tests do not work, mapserv is not installed correctly.
>Rich
>At 03:59 PM 9/12/2003 +0800, Chris Fung wrote:
> >Dear Sir,
> >I read your message in the MapServer and I know you can install it on
> >windows 2003 successfully. So I would like to ask you some questions. It
> >is because I found the below error message when type
> >http://localhost/cgi-bin/mapserv.exe in IE as below
> >CGI Error
> >The specified CGI application misbehaved by not returning a complete set
> >of HTTP headers.
> >I have allowed the web service extension but still failed to run the
> >execution file. How can I solved this? Thanks for your help.
> >Regards,
> >Chris Fung
Richard W. Greenwood, PLS
Greenwood Mapping, Inc.
Rich <at> GreenwoodMap <dot> com
(307) 733-0203
http://www.GreenwoodMap.com
