[Mapserver-users] layers not staying on
Swaminathan, Gayathri
gayathri at ou.edu
Fri Sep 12 12:24:35 EDT 2003
Can you do something like the following, instead of select box for layers?
<input type="checkbox" name="layer" value="<layer name>"
[yourlyrname_check]> <name that should appear in HTML page><BR>
Define two layers only and comment the rest out. And tell me how this
works...
Thanks
-----Original Message-----
From: Michael Smith [mailto:msmith at sanangelompo.org]
Sent: Friday, September 12, 2003 10:22 AM
To: Swaminathan, Gayathri; mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] layers not staying on
I have posted the map file and am using windows 2000/IIS 5 and mapserver
3.6. Let me know if you need anything else.
[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Swaminathan,
Gayathri
Sent: Friday, September 12, 2003 9:34 AM
To: 'Michael Smith'; mapserver-users at lists.gis.umn.edu
Hi:
Can you post your html page that has mapserver form, mapfile to the list?
Also the version of mapserver?
That will be helpful
Thanks
Gayathri
Sent: Friday, September 12, 2003 8:29 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] layers not staying on
Can someone tell me what causes this. On Mapserver (windows 2000/IIS5),
when I display a map my default layers appear. When I select a layer from
my available layers and hit refresh, the available layer then displays. The
problem I have is if I then change the view (zoom in or out) the available
layer disappears and only my default layers show up. In the demo, if I
select an available layer it stays on until I (or the user) turns it off. I
can post my map file is that is needed. Any help will really be appreciated
as I am on a deadline to show this mapserver demo to my boss. Thanks in
advance.
Michael Smith, Planner II
City of San Angelo
Planning & Development
325.657.4210 Fax: 325.481.2648
Email: msmith at sanangelompo.org
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
